CsyeCok The Soldier Posted November 15, 2019 Share Posted November 15, 2019 Hello. I have a problem with copying and pasting in paint.net The program pastes transperancy and the following happens: 1. I select an object I want to copy and paste and I also select some free space 2. I copy and paste it and when I move it to the object to the left, this happens! How can I paste an object with free space not like this? Quote Link to comment Share on other sites More sharing options...
HyReZ Posted November 15, 2019 Share Posted November 15, 2019 Greetings, You will achieve success if you create a new transparent layer to paste and move the weapon. You will want to have the new layer underneath the first layer. Then you can merge down if you like. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 15, 2019 Share Posted November 15, 2019 What @HyReZ said. This is what layers are for. Use them! 😁 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 15, 2019 Share Posted November 15, 2019 ^ what he said 😀 The reason you see what you do is you are copying the rectangular area including the surrounding transparency. Ctrl + C then Ctrl + Shift + V is the keyboard shortcut you want to memorize. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
CsyeCok The Soldier Posted November 15, 2019 Author Share Posted November 15, 2019 Thought it was GIMP-like (yes I migrated from GIMP to P.N). Thanks for the tip Quote Link to comment Share on other sites More sharing options...
gerkm Posted November 16, 2019 Share Posted November 16, 2019 I'm having this problem too and all of your suggestions are illogical. Copying transparency shouldn't be an issue. It's transparent. You're all treating the transparency "background" as a legitimate solid color or checkered background, when it should be non existent. 0 on the alpha scale. This has never been an issue for me, but all of a sudden paint.net is doing this odd behavior. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted November 16, 2019 Share Posted November 16, 2019 8 minutes ago, gerkm said: This has never been an issue for me, but all of a sudden paint.net is doing this odd behavior. You may be confusing MS Paint with Paint.NET. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
gerkm Posted November 16, 2019 Share Posted November 16, 2019 (edited) 5 minutes ago, BoltBait said: You may be confusing MS Paint with Paint.NET. Funny, but really. This started yesterday, and the only thing I've changed was downloading and installing the PSD.dll into the filetypes folder. Do you all actually think "copying transparency" that OCCLUDES things behind it is acceptable behavior? Edited November 16, 2019 by gerkm Quote Link to comment Share on other sites More sharing options...
BoltBait Posted November 16, 2019 Share Posted November 16, 2019 Paint.NET has always worked this way and MS Paint has always worked the other way. So, either you’re mixing them up or you’ve forgotten how to utilize layers in Paint.NET. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
HyReZ Posted November 16, 2019 Share Posted November 16, 2019 MS Paint has never utilized layers. Quote Link to comment Share on other sites More sharing options...
gerkm Posted November 16, 2019 Share Posted November 16, 2019 7 minutes ago, gerkm said: Do you all actually think "copying transparency" that OCCLUDES things behind it is acceptable behavior? 4 minutes ago, BoltBait said: So, either you’re mixing them up or you’ve forgotten how to utilize layers in Paint.NET. I know exactly how layers should work. Maybe you all just forgot the actual definition of the word transparent? Quote Link to comment Share on other sites More sharing options...
HyReZ Posted November 16, 2019 Share Posted November 16, 2019 (edited) I have using Paint.NET since 2008 so I am sure that you are wrong about that. It is obvious that you have become aware that Paint.NET handles Layers and Objects in its own way, but I have learned how it works and use it for ~90% of my graphics work. I prefer the graphics engine in Microsoft's products such as PowerPoint and the defunct Expression Design which uses a single 'stage' that image and text layers are applied. Edited November 16, 2019 by HyReZ Quote Link to comment Share on other sites More sharing options...
BoltBait Posted November 16, 2019 Share Posted November 16, 2019 1 hour ago, gerkm said: I know exactly how layers should work. Maybe you all just forgot the actual definition of the word transparent? In Paint.NET, when working on a single layer, you can move transparent pixels just like you can move opaque pixels. MS Paint can’t do that. It is a serious limitation. The point is, if you want to move transparent pixels and don’t want them to affect the pixels below them, they must be on their own layer. Don't fight it... just learn the power of Paint.NET. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 16, 2019 Share Posted November 16, 2019 2 hours ago, gerkm said: I know exactly how layers should work. Maybe you all just forgot the actual definition of the word transparent? I'm the author of Paint.NET. You clearly do not know how layers should work. You are wrong. Now that you know this, you can learn and make progress, and we're happy to help. 2 2 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
