Kuuhaku5417 Posted September 28, 2019 Share Posted September 28, 2019 (edited) Hello there I'm new to paint.net. I have two images, the first picture got some transparency, while the second one don't. So basically I want to recolor only the alpha channel from the first one to the second one, while keeping the color. I got some work by copy pasting the alpha value of each pixel to the second image but that's take a lot of time. So are there any ways or plugins to help me with the problem? Edited September 28, 2019 by Kuuhaku5417 Quote Link to comment Share on other sites More sharing options...
Pixey Posted September 28, 2019 Share Posted September 28, 2019 Hello @Kuuhaku5417 and Welcome to the forum Can you post (you can use a secondary site for the images, then copy the URL and post here - like https://postimages.org/ ) so that we can see just how much of an area you are talking about. You may be able to use the re-color tool for this, or you may have to erase and then paste. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
MJW Posted September 28, 2019 Share Posted September 28, 2019 If you want to transfer the alpha values from one image to another, you can use Paste Alpha from BoltBait's plugin pack. Copy the image whose alpha you want to copy to the clipboard, then, on the image you want to modify, run Paste Alpha with the Alpha Source set to Clipboard alpha. Quote Link to comment Share on other sites More sharing options...
Kuuhaku5417 Posted September 29, 2019 Author Share Posted September 29, 2019 12 hours ago, Pixey said: Hello @Kuuhaku5417 and Welcome to the forum Can you post (you can use a secondary site for the images, then copy the URL and post here - like https://postimages.org/ ) so that we can see just how much of an area you are talking about. You may be able to use the re-color tool for this, or you may have to erase and then paste. Sorry but I don't have my images with me right now because im not home and I can't find any similar one to my images. But basically I want to copy the alpha value from one image to another while keeping the color value. 11 hours ago, MJW said: If you want to transfer the alpha values from one image to another, you can use Paste Alpha from BoltBait's plugin pack. Copy the image whose alpha you want to copy to the clipboard, then, on the image you want to modify, run Paste Alpha with the Alpha Source set to Clipboard alpha. Thanks, I will try it later when I got home. Quote Link to comment Share on other sites More sharing options...
Kuuhaku5417 Posted September 29, 2019 Author Share Posted September 29, 2019 On 9/29/2019 at 2:18 AM, MJW said: If you want to transfer the alpha values from one image to another, you can use Paste Alpha from BoltBait's plugin pack. Copy the image whose alpha you want to copy to the clipboard, then, on the image you want to modify, run Paste Alpha with the Alpha Source set to Clipboard alpha. Thanks I tried the Paste Alpha and it worked. Quote Link to comment Share on other sites More sharing options...
