Zyst2 Posted September 25, 2019 Share Posted September 25, 2019 Hi all, Long time PDN user. But I'm kind of stumped on this. The Clone Stamp is great for a quick copy and paste directly where you want it. (All pasting seems to default to the top left corner of the layer, which then needs manual relocation...) I have combined it with AutoHotkey to create a macro where I will re-anchor the stamp with the source location. That is, it will click in the same coordinates on screen while holding down ctrl, automating half of the process for me. I can then move my mouse and click once to put the stamp where I want it. Like, I am literally using this as a stamp. If I had a stamp in my physical hand and were putting it on paper, it would repeat the same image over and over. The "Clone Stamp" tool is really more of a "Clone Brush" tool as you can drag it around and grab a changing image to put in a new spot. Is there any way to truly have a Stamp? I've seen the messy plugins for a signature that is just a shell to add in a new layer basically, perhaps with autoset transparency OR for a "dynamic brush" which is closer to what I want (if I just click and not click and drag) but still comes in kind of messy trying to load in a black and white/transparent image when I truly just want the source image with the original colors and such. Thank you in advance! Quote Link to comment Share on other sites More sharing options...
BoltBait Posted September 25, 2019 Share Posted September 25, 2019 If you want to "lock in place" the clone stamp, then what you want is a custom brush. Try that: https://forums.getpaint.net/topic/110673-brush-factory-v18-dec-10th-2018/ Quote Download: BoltBait's Plugin Pack | CodeLab | and a Computer Dominos Game Link to comment Share on other sites More sharing options...
Zyst2 Posted September 25, 2019 Author Share Posted September 25, 2019 Hi BoltBait, I did already have that plugin it seems. Unfortunately, it doesn't do what I want because you can only work on one layer at a time and not see what is below. I have a large "grid" of sprites that I'm placing checkmarks on. If I can't see the layer below, I don't know what I'm checking off or if it's even near center in a "cell". Quote Link to comment Share on other sites More sharing options...
Zyst2 Posted September 25, 2019 Author Share Posted September 25, 2019 (edited) Copying the sprites to clipboard? That sounds like it might be the same issue as the previously suggested. I don't want a merged image, I want to be able to toggle on and off different checkmark layers that have different meanings, ultimately. I'll install it to give it a go just in case it does accomplish what I hope. Edit: Does not work at all for what I am doing. I can load up the "checkmark" just fine. But when I click on the image, it locks me to certain points on the image, not at all where I want to go. I could refine the source image size to directly match the sprites I am overlaying and maybe adjust the tile sizes to make that work, but as is that's a lot of hassle for an end result that I still wouldn't want: it is still creating a "merged layer" -- I can't place these "checkmarks" on their own layer without further advanced manipulation like using XOR or something on a duplicate layer. I am honestly impressed there isn't a tool created after 15 or so years that just keeps the anchor in place for the clone stamp. That's like 99% of the way to what I want, just needs the 1% change to not move the anchor. These other plugins suggested are huge workarounds. Even a custom brush tool, if it didn't require launching its own miniwindow, could have worked if I could see the layers below. Genuinely curious: does Photoshop even have a feature like this? If not, I am surprised I'd be in such a severe minority of people that could want this that no one has had a desire to develop it. Edited September 25, 2019 by Zyst2 Quote Link to comment Share on other sites More sharing options...
