Roi Playz Posted September 17, 2019 Share Posted September 17, 2019 So, when the first part of the setup, when it reaches Green Bar, it doesn't continue and that's my problem, i have a lot of work to do with paint.net but i can't do it because i cannot even install it. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted September 17, 2019 Share Posted September 17, 2019 Please install the .NET Framework first: https://dotnet.microsoft.com/download/thank-you/net48 Once that has been installed, try to install paint.net again. Let us know how it goes. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Cubit Posted October 11, 2019 Share Posted October 11, 2019 I was using 4.2.1 without any problem. Then the other day a window popped up when I opened the software, making me aware of an update. I selected to have the update downloaded once I closed the program. After I exited, the download began. However, the installation did not complete. I downloaded the newest net framework, but the program will still not work. The message says that the program cannot open. I tried to restore to the older version, but I was not able to--probably because during the new installation attempt it erased the older installation. Although I see the icon for the older installation, it will not open when I click it. I tried to download and install another fresh version and it failed. I tried to install an older version and it too failed. My operation system is Windows 7. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 11, 2019 Share Posted October 11, 2019 If your current Paint.NET installation is broken, please use this utility to remove it: https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-installed-or-removed Afterwards, try to install the latest version of Paint.NET again. Let us know how it goes. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Cubit Posted October 15, 2019 Share Posted October 15, 2019 Thanks for replying. I did try that before, having looked for solutions. For some reason nothing happens at all when I try to use the tool. Quote Link to comment Share on other sites More sharing options...
Cubit Posted October 15, 2019 Share Posted October 15, 2019 Update: The Program Install and Uninstall troubleshooter finally started working. I don't know if my virus protector was holding it up or what. The troubleshooter did uninstall the old installation fragment for paint.net. However, I re-downloaded the newest version and tried to install, but the same problem occurred. Click details in the setup wizard showed this the first time: Setup Wizard has stopped working Problem signature: Problem Event Name: APPCRASH Application Name: SetupFrontEnd.exe Application Version: 4.205.7213.32560 Application Timestamp: 5d9395b9 Fault Module Name: KERNELBASE.dll Fault Module Version: 6.1.7601.24441 Fault Module Timestamp: 5cb935a7 Exception Code: e0434352 Exception Offset: 000000000000bdfd OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 1033 Additional Information 1: 7ccb Additional Information 2: 7ccb2fa98342573c8a26d5624a3b51e6 and this the 2nd time: Problem signature: Problem Event Name: APPCRASH Application Name: SetupFrontEnd.exe Application Version: 4.205.7213.32560 Application Timestamp: 5d9395b9 Fault Module Name: KERNELBASE.dll Fault Module Version: 6.1.7601.24441 Fault Module Timestamp: 5cb935a7 Exception Code: e0434352 Exception Offset: 000000000000bdfd OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 1033 Additional Information 1: 7ccb Additional Information 2: 7ccb2fa98342573c8a26d5624a3b51e6 Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 15, 2019 Share Posted October 15, 2019 2 minutes ago, Cubit said: Fault Module Version: 6.1.7601.24441 I think you need to run Windows Update, that's fairly old version for this DLL on Windows 7. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
