mingw Posted August 19, 2019 Share Posted August 19, 2019 Hello!I would like to know from the author. Does the author plan to implement a custom grid?+ It would be nice to add the ability to scale the image through the mouse wheel in the settings. Link to comment Share on other sites More sharing options...
FanofSMBX Posted August 26, 2019 Share Posted August 26, 2019 You can indeed use the mouse wheel to zoom. At least, when I pinch and move on my laptop trackpad, it zooms the image in and out. Link to comment Share on other sites More sharing options...
BoltBait Posted August 26, 2019 Share Posted August 26, 2019 Hold the Ctrl key while scrolling with the mouse wheel in order to change your zoom level. Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
mingw Posted August 26, 2019 Author Share Posted August 26, 2019 (edited) This makes it difficult to navigate the image. When I work with pixels, I often have to scroll and zoom the canvas, it’s convenient to drag with the mouse without using the keyboard. I would like without the ctrl key. Mouse wheel *only*. Now this function scrolls the image up and down - which does not fit with the graphics editor, it is rather for a text editor.Does also know anything about custom grid implementation? When are you planning to introduce it? And will she be at all? Without a grid, it is inconvenient to draw tilesets. Edited August 26, 2019 by mingw Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 27, 2019 Share Posted August 27, 2019 The behavior you request is already assigned to scrolling. That's logical IMO. You can pan the canvas by using the mouse wheel as a button. Pan while zoomed Click and drag with Middle Mouse Button or Mouse Wheel See https://www.getpaint.net/doc/latest/KeyboardMouseCommands.html#4 Adding the Ctrl key modifier to the mouse wheel is commonly assigned to zooming/view size. You'll find it in a great many apps (browsers, Office, Google Docs....) 1 ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
mingw Posted August 30, 2019 Author Share Posted August 30, 2019 On 8/27/2019 at 5:27 AM, Ego Eram Reputo said: Adding the Ctrl key modifier to the mouse wheel is commonly assigned to zooming/view size. You'll find it in a great many apps (browsers, Office, Google Docs....) A highly controversial statement. Photoshop sends hi 😃 In graphics programs, there is such specificity - often change the size of the canvas. I do not require changing anything ... just ask to add the ability to remove the modifier for changing the size of the canvas. Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 30, 2019 Share Posted August 30, 2019 1 hour ago, mingw said: A highly controversial statement. No it isnt. I gave several VERY common examples. Get used to using the Ctrl key? ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
mingw Posted August 31, 2019 Author Share Posted August 31, 2019 11 hours ago, Ego Eram Reputo said: Get used to using the Ctrl key? My workspace is arranged so that the keyboard is at a distance of two meters. Therefore, only a mouse is at hand.But that is not the point. This raises the question of ergonomics. We can scroll the canvas by clicking the middle mouse button. So why duplicate this function with the wheel?Personally, when working with the program, the mouse wheel becomes a useless device.Paint. Net is a good program. Many things are awesome. But such minor flaws spoil the impression. Link to comment Share on other sites More sharing options...
mingw Posted August 31, 2019 Author Share Posted August 31, 2019 43 minutes ago, welshblue said: Don't forget - one developer trying to keep everyone happy ? Impossible Possible. Full customization of hot keys. As it is, for example, implemented in Krita. Link to comment Share on other sites More sharing options...
BoltBait Posted August 31, 2019 Share Posted August 31, 2019 I can imagine an easy solution: move your keyboard within reach. Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
BoltBait Posted August 31, 2019 Share Posted August 31, 2019 2 hours ago, mingw said: Possible. Full customization of hot keys. As it is, for example, implemented in Krita. If you're completely happy with Krita, use Krita. Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
mingw Posted September 1, 2019 Author Share Posted September 1, 2019 (edited) 13 hours ago, welshblue said: You must have awfully long arms ... you said your keyboard was 2 metres away from your mouse 😊 What for? Hotkeys can be assigned to the mouse. So I have the Middle mouse button + left button assigned to the undo. Middle + right is assigned to the context menu. The left + wheel is assigned to reduce-increase the size of the brush. Right + wheel - select the next \ previous tool. )) 11 hours ago, BoltBait said: I can imagine an easy solution: move your keyboard within reach. Not an option.I work standing in front of the desk. In this position, the keyboard is extremely uncomfortable. Incidentally, it is very good for overall health. 11 hours ago, BoltBait said: If you're completely happy with Krita, use Krita. I did not say that. I just gave an example of the successful implementation of this feature. You urge me to get used to the CTRL modifier, move the keyboard, and generally move to another program.You offer to put up with inconvenience or go to hell. No ... I’m still digging your brains)) If the author has taken it, then let him do it humanly. He has a talent. Only sometimes, instead of the usual right-hand thread, for some reason, he twisted the left ... 🙃 Upd: Key Remapper solved the problem. All that remains is a custom grid. Edited September 1, 2019 by mingw Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 1, 2019 Share Posted September 1, 2019 You'll need to use a keyboard to get the most out of Paint.NET. I'm not changing Paint.NET to accommodate this type of arrangement, especially when you're the only person to ever ask for it. You've got the answers you came here for, and you're being very argumentative, so I'm locking this post. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
