Cremator Posted June 29, 2019 Share Posted June 29, 2019 So, today, I re-installed paint.net after several issues i've been having. Installation worked fine, no errors or anything. Then, I launched paint.net, and I found this pretty glaring problem.. I am not able to create images in it. The UI is there, but not the background. I'll show you what I mean by this. Is there any way I can fix this? Quote Link to comment Share on other sites More sharing options...
SodiumEnglish Posted June 29, 2019 Share Posted June 29, 2019 I am able to reproduce this by resizing the window from the bottom and dragging it all the way to the top. It then becomes uninteractable and even difficult to close. There may be ways it can be prevented, however there is some Windows magic you can do to fix it! It seems you are on Windows 10 which is good. Shift + Right click on Paint.NET in the taskbar and select Size. Then your cursor will appear on the window with the arrow cursor. Then click, hold, and drag down. 1 Quote Link to comment Share on other sites More sharing options...
Cremator Posted June 29, 2019 Author Share Posted June 29, 2019 (edited) Nothing happened to fix it. Wait, forget it, it works! Thank you! Edited June 29, 2019 by Cremator Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 29, 2019 Share Posted June 29, 2019 2 hours ago, SodiumEnglish said: Shift + Right click on Paint.NET in the taskbar and select Size. Pure gold that is! Thanks @SodiumEnglish 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Zagna Posted June 29, 2019 Share Posted June 29, 2019 Interesting and amusing behaviour 😛 Quote Link to comment Share on other sites More sharing options...
TrevorOutlaw Posted June 29, 2019 Share Posted June 29, 2019 What in the world? 😳 Quote Paint.NET Gallery | Remove Foreground Object Tutorial | Dispersion Effect Tutorial Link to comment Share on other sites More sharing options...
