📢⚠⚠⚠ REMINDER: Please upgrade to Win10 and 64-bit. Win7/8.1 and 32-bit/x86 support being removed
Update, 2021-11-21:
Paint.NET v4.3.x is the last version that will work for Windows 7, Windows 8.1, or any 32-bit x86 version of Windows.
Paint.NET v5.0 will require Windows 10 or newer (including Windows 11), and will be 64-bit only (x64 and ARM64).
(original post)
https://www.microsoft.com/en-us/windowsforbusiness/end-of-windows-7-support
This means no more updates, especially security updates. This will put it in the same place as XP and Vista, which nobody should be using anymore.
I don't yet have a concrete plan for when Paint.NET will stop supporting Windows 7, which is when Windows 10 will become the minimum OS version*, but the clock is ticking. Maybe 1 year after, maybe 2 or even 3, it's not set in stone yet, but I'm not going to be able to support Windows 7 indefinitely.
Please upgrade to Windows 10. I know a lot of you really like Windows 7, and that's a perfectly fine opinion, but supporting it does hold back Paint.NET's long-term progression and you have to know I can't support it indefinitely. Windows 7 has had a great run! It's currently 10 years old! Celebrate that, and then upgrade to 10 :) You've got time, so don't panic, but definitely include this in your planning.
* let's just forget Windows 8/8.1 ever happened, just like we never say the word "Vista" out loud ...
  • Like 2
  • Upvote 3
BTW, this transition has already begun...
Starting with Paint.NET v4.2, Windows 10 will be required for HEIF/HEIC file support.
  • 3 weeks later...
I haven't tested this, but Windows 10 seems to still be a free upgrade for Win7 holdouts: https://wccftech.com/how-to/upgrade-windows-7-download-windows-10-free/
As a reminder, January 14th is coming quickly. Upgrade to Win10 soon :)
https://www.microsoft.com/en-us/microsoft-365/windows/end-of-windows-7-support
One week left!
IT'S TIME TO UPGRADE EVERYONE :)
It should still be free ... https://wccftech.com/how-to/upgrade-windows-7-download-windows-10-free/
And via ZDNet: https://www.zdnet.com/article/heres-how-you-can-still-get-a-free-windows-10-upgrade/
  • 9 months later...
NOTE: If you're using Windows 7 with an AMD Ryzen CPU, Paint.NET may randomly crash at startup. (It may also crash at other times, I can't say for sure)
This is an unsupported combination: Win7 is out of support, and AMD has never supported Ryzen on Win7 (they don't supply drivers for it).
Unfortunately I cannot fix this. If you're experience trouble with Win7 + Ryzen, you will simply need to upgrade to Windows 10.
(This seems to affect ALL generations of Ryzen, old 1000 series and even brand new 5000s)
  • 7 months later...
I'm currently finalizing my plans for ending support for Windows 7. It probably won't be much longer, maybe end-of-year at the latest.
If you're still on Windows 7, upgrade now. You've had plenty of time to do so.
  • 4 months later...
See here:
  • Rick Brewster changed the title to 📢⚠⚠⚠ REMINDER: Please upgrade to Win10 and 64-bit. Win7/8.1 and 32-bit/x86 support being removed
  • 3 months later...
