Problem. Shape type: Rounded rectangle
I wanted to create Rounded rectangle.
But the result surprised me. It looks very bad. Angles are curves.
tested on Paint.Net 4.1.2, 4.1.6, and alpha 4.1.7
Select Shapes tool and set:
- Shape type: Rounded rectangle
- Brush width: 1
- Corner size: 1
- Antialiasing Disabled
and create a shape on canvas
Problem - only two corners will be rounded
Spoiler
then increase Corner Size - 2
Problem - corners look very bad, they are all different
Spoiler
and increase Corner size a little more - 6
look at this
Spoiler
However, the corners are displayed correctly if Antialiasing is Enabled.
look at gif
Spoiler
but even when using Antialiasing, the corners are not 100% identical, you can make sure to compare the color at the smoothing points
compare points at top and bottom
Spoiler
Edited by PaintNetRus
update for screenshot 2
I just had a quick look at this 'problem' and whilst it does appear to be real I'd point out it only seems to occur when you use a one pixel brush width.
AA off I drew a rounded square with a one pixel brush and two out of the four corners did indeed have a slightly different shapes similar to the third picture above. Unsurprisingly switching AA on resulted in two identical and two slightly different corners as well.
Trying with different corner sizes only exacerbated the 'problem'.
But the moment you switch to the default 2 pixels brush width all looks good and 100% matching whatever the corner size, AA off or on, as far as I've tested it.
My question would be: when are you actually going to require a critically perfect one pixel width rounded corner square/rectangle? I'm sure there are niche purposes, like the creation of small icons 32x32 or something similar, but for most users this imperfection is practically irrelevant.
I just wanted to create a button like that
and I chose a simple way to do it, as it seemed to me - Shape type: Rounded rectangle
but the final result was not as I expected, and I decided to report it.
Similar problem with - Shape type: Ellipse
but most likely it should be so
Spoiler
