AntonisKazanas Posted April 24, 2019 Share Posted April 24, 2019 So I want to install paint.net but when I am on the final stage of the installation it says it can't find a package named: PaintDotNet_x64_161191380. But when I check the Staging folder with the installation packages I find installation packages with smilar names that do not work like PaintDotNet_x64_305908303. Does anyone know what I can do to install paint.net? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted April 24, 2019 Share Posted April 24, 2019 Sounds like you have an existing paint.net installation that has become broken. You can use this utility to remove the broken installation: https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed Afterwards, you can install paint.net anew. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
