BDMinis Posted August 20, 2008 Share Posted August 20, 2008 Hi Is there a water reflection tutorial as ive looked and i cant seem to find one. And im having no luck with trying to get it to work.I am new at paint net and just trying to do a couple simple things. If anyone could help that would be great. Thanks in advance Lee Quote Link to comment Share on other sites More sharing options...
-Expiration- Posted August 20, 2008 Share Posted August 20, 2008 Even better. There's a water reflection plugin, which automates the process for you! Use the forum's search function set to the Plugins forum to find it. Quote Call me expired. Please. Don't go counting your chickens before the pack of rabid ravaging foxes attacks. -Sozo Link to comment Share on other sites More sharing options...
BDMinis Posted August 20, 2008 Author Share Posted August 20, 2008 Yes i have the plugin but i just don't know how to make it work as isaid im very new to pn and i jst dont know what to do thats why i wanted a tutioral on it so maybe i could learn Quote Link to comment Share on other sites More sharing options...
topezia Posted August 20, 2008 Share Posted August 20, 2008 You might want to get a look here: viewtopic.php?f=16&t=2911&start=0&st=0&sk=t&sd=a In the plug-in section for each plug-in there is also a short explanation on how it works, Ciao Quote Link to comment Share on other sites More sharing options...
bEPIK Posted August 20, 2008 Share Posted August 20, 2008 The picture below shows you how to use the plugin. Quote Water, Wood and Hair Tutorial Link to comment Share on other sites More sharing options...
BDMinis Posted August 20, 2008 Author Share Posted August 20, 2008 The picture below shows you how to use the plugin. I would like to use it on a image Quote Link to comment Share on other sites More sharing options...
Kat Posted August 20, 2008 Share Posted August 20, 2008 Being a PDN newbie myself I found that experimenting with things is the best way to get to know how they work - however I must admit it doesn't necessarily teach me the most effective way to using plugins etc. When I do something like that, first I make sure that I leave my original layer intact, by copying it and then on the copied layer trying and experimenting with things. Maybe you would just do it that way? Because there is no more effective way of learning than by doing (just my own opinion). Have fun! Quote Link to comment Share on other sites More sharing options...
