Issue with Uninstallation
Hello @Existence and Welcome to the forum :)
This may be relevant to you:
" The paint.net installer prevents you from installing directly onto removable media. This is to prevent all kinds of problems. You'll need to install to a harddrive first, then copy the installed directory to your removable media if you want a portable copy. "
You mean on a secure digital card?
I would wait for RB's advice on this but I suspect you'd just treat like if it was any other portable app that had been installed on a flash drive or other external storage drive and just delete whatever is there in the normal way.
I'm surprised it installed on the SD card at all, if that is what you do mean, for the reason Pixey has just posted.
Edited by IHaveNoName
Hello. The SD drive is an additional drive built into my system. It is not removable. I believe the Paint.NET app on my system is installed, not portable. It is installed on my E drive.
toe_head2001 I downloaded the windows uninstaller. Paint.NET isn't listed, so I clicked on 'Not Listed' and it asks for a product code. What is it I have to enter here. I have no idea what a product code is. I thought it may be something like a product key that comes with paid software. What exactly do I type in here?
Pixey I am uncertain exactly what you mean. It isn't a portable copy I am after. My solid state drive isn't removable. My computer had a ordinary C drive and 2 additional solid state drives. It is one of these solid state drives that the Paint.NET app is installed on. I believe that is why it isn't listed in the usual way of uninstalling (programs and features).
IHaveNoName No, it is an SSD (solid state drive). It isn't portable and the Paint.NET app is installed. Yet it is not listed in programs and features.
Any other ideas?
I don't think it should be on your E drive either.  Have you tried downloading to C drive?
Also:
One of the easiest ways to clean up files you no longer need is by using Disk Cleanup.
  1. Open Disk Cleanup by clicking the Start button . ...
  2. If prompted, select the drive that you want to clean up, and then select OK.
  3. In the Disk Cleanup dialog box in the Description section, select Clean up system files.
Thankyou Pixey. I installed on E drive because of space. And thanks for the advice on Disk Cleanup. But it makes no difference to getting the app uninstalled. The issue is that it is not listed in programs and features, so I have no way of uninstalling.
It's looking for an MSI GUID. Don't worry about that though.
If it's not listed, then as far as Windows Installer (MSI) is concerned, it's not installed.
You can just delete the program files.  Or if you want to be 101% sure, you can reinstall Paint.NET to the same location, and then you should be able to officially uninstall it.
toe_head2001 Hello. Thanks for that. I have reinstalled Paint.NET on my E drive. It now appears in programs and features.
So are you sure it is safe to just delete the old Paint.NET folder (See attached). The Paint.NET folder in the snip is the old folder that was there BEFORE I installed it again.
Thx v much.
