MPS Posted March 2, 2019 Share Posted March 2, 2019 (edited) Hello I have problem with fonts. I have installed Oswald with 4 styles. All apps (without paint.net) is using style which I want in paint.net - Oswald Regular v2.002. But paint.net isn't using this style. It's using Oswald Light. What I can do to change style of font? Edited March 2, 2019 by MPS Quote Link to comment Share on other sites More sharing options...
Pixey Posted March 2, 2019 Share Posted March 2, 2019 @MPS Welcome to the forum In order for Paint.net to use fonts, they must be stored in the Windows Font Folder on your system. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
IHaveNoName Posted March 2, 2019 Share Posted March 2, 2019 (edited) My simple solution would just to try deleting, specifically, Oswald-Light from your Font folder. If it is not there it can't be used so, in theory, you should get the regular version being used as default. EDIT: I've just done that myself and it works. As I described below the problem is the font name: all three family font members are named "Oswald" and presumably the first alphabetically is what is used by default. Just go to Control Panel > Appearance and Pesonalization > Fonts (or whatever path your Windows OS uses to display the stored fonts). Find the Oswald font set click on it and delete "Oswald-Light". After that if you use PDN you should find it uses Oswald-Regular. Although Oswald-Bold precedes it alphabetically I'm guessing it is the convention not to display a bold font when a regular one is available as emboldening and/or italicizing a regular font are usually options provided by the text writing tool being used. ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- https://forums.getpaint.net/topic/113810-text-and-text-window-installed-fonts-missing-from-menu/?do=findComment&comment=554878 I open that thread about a similar sort of matter a few weeks ago. The bottom line apparently is that if PDN or a plugin does 'like', for whatever technical reason, a particular font/font set there is nothing you can do about it. The problem may even be with the original font naming; many 'free' alternative font family sets name the font ie. its actual embedded name the same. It is surprisingly difficult to rename a font, especially if it is not a .ttf, and even if that has been done there is no guarantee that PDN or a particular PDN text plugin would list separately every font in that family no matter however they were renamed. Edited March 2, 2019 by IHaveNoName Quote Link to comment Share on other sites More sharing options...
