dwight Posted January 29, 2019 Share Posted January 29, 2019 how do I extract an image's color palette (extract it as .png etc. not .txt/.csv etc.) in version 4.1.5? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 29, 2019 Share Posted January 29, 2019 Hey Dwight - welcome. Try this plugin: The image colors will appear in the right hand pane. Beware: even an apparently simple image can have thousands of shades. Once loaded take a screenshot of the plugin UI and crop to the color table. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
dwight Posted January 29, 2019 Author Share Posted January 29, 2019 I tried the plugin linked and it didn't show the image's color palette. nothing. I need to extract the image's color palette for mutli-layered .tm2 images. Quote Link to comment Share on other sites More sharing options...
AndrewDavid Posted January 29, 2019 Share Posted January 29, 2019 Hi @dwight You are on the right track. You can see that your image is over 67K Colors Below the pic you will see a divide by slider bar. As you move the slider it will reduce the number of colors to a point where it will begin to show you the colors in the window on the right hand side. I think the break point is 1024 colors. At this point you would start doing screen captures of the colors shown to paste into a new image to get your graphic pallette. Sounds like a lot of work - be careful what you wish for. As you increase the multiplier it will reduce the number of colors shown. I think the window will show about 96 colors at a time. Once the number of colors shown is below 96 it allows you to save as a pallette.txt file (I know you don't want it) but there are plugins that allow you to create a layer based on the palette. A 2 step process to get want you want. Hope this helps Quote Link to comment Share on other sites More sharing options...
Reptillian Posted January 29, 2019 Share Posted January 29, 2019 (edited) There's CLUT transferring tool on G'MIC, and the command autoindex which will reduce the numbers of colors -autoindex count > 0 0<= dithering <= 1, method={ O=median-cut | 1=k-means } -autoindex 2048,1,1 and then use the G'MIC CLUT tools if you want to use those colors for changing pictures. If you're interested in just the colors, G'MIC has an colormap command. The picture above demonstrate that the image has been turned into a palette. 1024x1 indicates that there are only 1024 colors. In Paint.NET, you would need to resize the image width to 1024 manually if and only if the size of the palette is greater than the width of your image, and then apply this. Here's the output in PDN close-up Edited January 29, 2019 by Reptillian Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 29, 2019 Share Posted January 29, 2019 9 hours ago, dwight said: I tried the plugin linked and it didn't show the image's color palette. That's because there are 67114 colors. I did warn you 😉 The plugin is limited to showing around 1000 colors. If there is more, nothing shows up. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
dwight Posted January 30, 2019 Author Share Posted January 30, 2019 13 hours ago, welshblue said: Have you tried breaking it down into 2 smaller images - eg. the disk on it's own and then the thumbnails? There's also some pretty good online palette generators. Might be a bit more work but if something is worth having ... 10 hours ago, Reptillian said: There's CLUT transferring tool on G'MIC, and the command autoindex which will reduce the numbers of colors -autoindex count > 0 0<= dithering <= 1, method={ O=median-cut | 1=k-means } -autoindex 2048,1,1 and then use the G'MIC CLUT tools if you want to use those colors for changing pictures. If you're interested in just the colors, G'MIC has an colormap command. The picture above demonstrate that the image has been turned into a palette. 1024x1 indicates that there are only 1024 colors. In Paint.NET, you would need to resize the image width to 1024 manually if and only if the size of the palette is greater than the width of your image, and then apply this. Here's the output in PDN close-up sorry for being a little slow but, I'm trying ton use that to extract my image's color palette like this example that includes alpha. https://i.postimg.cc/XvMcZc6B/dataface-c-layer0-0.png Quote Link to comment Share on other sites More sharing options...
Reptillian Posted January 30, 2019 Share Posted January 30, 2019 (edited) 4 hours ago, dwight said: sorry for being a little slow but, I'm trying ton use that to extract my image's color palette like this example that includes alpha. https://i.postimg.cc/XvMcZc6B/dataface-c-layer0-0.png I tested colormap command with alpha, and it does indeed work. Do you want the alpha values and the color values to be separated. Duplicate layer If so, in code[local] split_opacity colormap [desired palette size],1,1 rv Remove rv for one of those layers and you'll get both of them separated. Mind you, there are 255 colors possible in alpha in PDN. Edited January 30, 2019 by Reptillian Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
