Iink Posted December 25, 2018 Share Posted December 25, 2018 Here are some examples I made: This first example could be where every new image is set to that zoom set if locked. The second example is where every new opened file is locked to that zoom if the lock is clicked on. This would be useful if you maybe had a lot of 20x20px size images and you wanted to edit every single one for some reason but you had to keep zooming in on every single file. Maybe you could do this in Settings > Tools. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted December 25, 2018 Share Posted December 25, 2018 I don't see the point when CTRL + mouse wheel is so easy to get used to. The other way I regularly zoom in is CTRL + B (zoom to window) and CTRL + 0 to return to the actual size. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Andrewnui Posted December 26, 2018 Share Posted December 26, 2018 I made an account just to reply to this. I use Paint.net to do pixel art pretty much exclusively. I actually do find myself opening a lot of little files and was wondering if there was a way to set my default zoom to something like 1000%. I hate that zooming in with the mouse wheel uncenters the image, because often times I have multiple images I'm comparing to others, and so they need to be in the same spot as each other-- so I have to click and drag the zoom slider on the bottom every time. It gets annoying after a while. I would love if the second example plugin/feature was a real thing. 1 Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted December 26, 2018 Share Posted December 26, 2018 1 hour ago, Andrewnui said: I hate that zooming in with the mouse wheel uncenters the image, Zoom in then hit Ctrl + B twice to recenter the image. 2 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Iink Posted December 26, 2018 Author Share Posted December 26, 2018 On 12/25/2018 at 6:30 PM, Ego Eram Reputo said: I don't see the point when CTRL + mouse wheel is so easy to get used to. The other way I regularly zoom in is CTRL + B (zoom to window) and CTRL + 0 to return to the actual size. It would just make things easier. Quote Link to comment Share on other sites More sharing options...
NinthDesertDude Posted December 26, 2018 Share Posted December 26, 2018 (edited) 4 hours ago, Andrewnui said: so I have to click and drag the zoom slider on the bottom every time. Alternatively, hold Ctrl and press + a few times. A default setting to open images to fill the visible window space would be a solid option to implement, but it would be up to Rick. Edited December 26, 2018 by Joshua Lamusga Quote Link to comment Share on other sites More sharing options...
