Reptillian 306 Posted September 26, 2019 Author Report Share Posted September 26, 2019 I'm working on improving Fragment Blur for G'MIC. Here's some improvements. Speed is over 500 times faster though not as fast as PDN version, but it's usable in many more cases. From a test I did with 50 iteration with a image that has 4000x3000. It goes from 30-90 minutes to 6 seconds. That's how fast it is now. Better handling of picture info. If some info are not needed to be processed, they will not be processed. In some cases, some options are taken out because it doesn't match expectations. Added bug handling option, in case of image going over-range or under-range as a result of the filter. You probably are not going to noticed, but just in case, you have this option. It behaves almost 100% proper to 100% proper in all cases. The current one has issues with certain images. The new one will fix it to the point where it's usable in every cases. So, with color space option and speed and bug handling options, it's now getting to be a go-to option if you want a little extra. Note - Bug handling option has another side which is that it can improve the result. So, you could try that when it gets here. But for now, I'm working on it. Quote Link to post Share on other sites
Reptillian 306 Posted September 27, 2019 Author Report Share Posted September 27, 2019 (edited) After a huge amount of effort, I have solved the fragment blur. Now I know how it works. Details here - https://github.com/dtschump/gmic-community/pull/207 Image that was created with G'MIC Fragment Blur - Please ignore the border, I'm not sure how to fix that pasting bug. Edited September 27, 2019 by Reptillian 1 Quote Link to post Share on other sites
Reptillian 306 Posted September 27, 2019 Author Report Share Posted September 27, 2019 (edited) @lynxster4 There's two filters that I don't see useful enough to be worth fixing, but I really like to know if you think Vibrato and Channel Overblur... filters are useful enough for me to extend them. I could add anti-aliasing, and blending mode options to vibrato as well as make the gradient continuous. Next filters I'll be fixing Color Modulo Texture (Tricky) Restore color manipulation toolbox for Transfer Colors [Reduced] filter Edited September 27, 2019 by Reptillian Quote Link to post Share on other sites
lynxster4 3,157 Posted September 29, 2019 Report Share Posted September 29, 2019 @Reptillian, please don't let me influence what you do to your g'mic filters. But, here's my opinion. I probably won't ever use Vibrato. It's just not my thing and I don't ever see me using it in my artwork. Not to say you shouldn't do this: add anti-aliasing, and blending mode options to vibrato as well as make the gradient continuous. Channel Overblur...I got some interesting results, but sometimes I get a 'Preview Timeout' and I have to close it. Lots of sliders and I fully don't know how to use all of them, but I can see me using this plugin. Thanks for the Fragment Blur! It seems to be identical to the PDN plugin and the addition of 'Color Space' drop-down menu just adds to it! I've gotten some images that I'm thinking 'how can I use this in my artwork?', I like it so much. Keep on doing what what you're doing @Reptillian I appreciate it! 🍩☕ Quote My Art Gallery | My Shape Packs | ShapeMaker Mini Tut | Air Bubble Stained Glass Chrome Text with Reflections | Porcelain Text w/ Variegated Coloring | Realistic Knit PatternOpalescent Stained Glass | Frosted Snowman Cookie | Leather Texture | Plastic Text | Silk Embroidery Visit my Personal Website "Never, ever lose your sense of humor - you'll live longer" Link to post Share on other sites
Reptillian 306 Posted October 2, 2019 Author Report Share Posted October 2, 2019 @lynxster4 No worry about the influence, all I wanted was a bit of feedback. What I do is up to no one. I fixed Alpha Normalization bug on G'MIC Fragment Blur and made a pull request. Also new filter which is on the same pull request. @Eli @Iota16 Thank you so much for encouragement for this filter. 2 Quote Link to post Share on other sites
Reptillian 306 Posted October 2, 2019 Author Report Share Posted October 2, 2019 (edited) Delete this please. Edited October 3, 2019 by Reptillian Quote Link to post Share on other sites
Reptillian 306 Posted October 3, 2019 Author Report Share Posted October 3, 2019 (edited) Deleted because it's not necessary anymore. Edited October 6, 2019 by Reptillian Quote Link to post Share on other sites
Reptillian 306 Posted October 4, 2019 Author Report Share Posted October 4, 2019 (edited) Deleted because it's not necessary anymore. Edited October 6, 2019 by Reptillian Quote Link to post Share on other sites
Reptillian 306 Posted October 6, 2019 Author Report Share Posted October 6, 2019 (edited) Thorn Fractal - Secant Sea Filter is coming soon - Pull Request : https://github.com/dtschump/gmic-community/pull/210 Some images of the filters - It's basically a different version of Strange Attractor made by @MadJik Edited December 10, 2020 by Reptillian 2 Quote Link to post Share on other sites
Reptillian 306 Posted October 7, 2019 Author Report Share Posted October 7, 2019 (edited) Thorny Fractal - Secant Sea filter is on G'MIC. Also, I wanted to share this. That was made with the Thorny Fractal - Secant Sea filter. Here's the setting Escape - 1000000 Loop - 353 Subsampling Level - 8.929 Distortion X Formula - Petallian Distortion X - 7 Distortion Y - -8.3 Random Color Map - Colours - 6 Seed - 2116 After that, it's just modifying the color. I did applied it to a much bigger picture though. Edited December 10, 2020 by Reptillian 1 Quote Link to post Share on other sites
Eli 1,129 Posted October 12, 2019 Report Share Posted October 12, 2019 @Reptillian The autofill coloring book effect really works. Would it be possible to add an option to use colors from a colors palette? 2 Quote Link to post Share on other sites
Reptillian 306 Posted October 12, 2019 Author Report Share Posted October 12, 2019 (edited) 2 hours ago, Eli said: @Reptillian The autofill coloring book effect really works. Would it be possible to add an option to use colors from a colors palette? I can do that, but I'm thinking this would imply that either I should fill with nearest nonexisting colors if number of areas exceed a palette, or refill it with the current palette, or to do with random colors. It would take some time for me to implement, but right now I'm having bad case of insomnia, so it might not be possible any time soon on my end. That, and I do have some plans to fix my filter or implement a new filter. Edited October 12, 2019 by Reptillian Quote Link to post Share on other sites
Eli 1,129 Posted October 12, 2019 Report Share Posted October 12, 2019 1 hour ago, Reptillian said: I can do that, but I'm thinking this would imply that either I should fill with nearest nonexisting colors if number of areas exceed a palette, or refill it with the current palette, or to do with random colors. That would be a great enhancement. Thanks. Quote Link to post Share on other sites
Reptillian 306 Posted October 13, 2019 Author Report Share Posted October 13, 2019 I'm not so sure if I can manage to make this new filter works with Paint.NET, but it needs to be asked though. Is there any way one can create pictures side by side from videos and import into paint.net? This new filter is basically z-depth render where you use a clipboard image to determine which frame to render. The above shows the effect of the filter with conical gradient. As you can see, there are 3 images, and the conical gradient determines the time. Quote Link to post Share on other sites
Reptillian 306 Posted October 14, 2019 Author Report Share Posted October 14, 2019 (edited) I guess there isn't a good workaround to the issue of multiple images i.e more than 2 images. That being said, @Eli wanted a better brick solution. I made this. It doesn't have the disable top or left or right or bottom outline, but that can be done later (I'll have to update some filters later on with more features, but adding features is time-consuming as it is). EDIT: Removed code as it isn't needed here. Also, GUI is finished. Edited October 15, 2019 by Reptillian Quote Link to post Share on other sites
Reptillian 306 Posted October 15, 2019 Author Report Share Posted October 15, 2019 Brick filter has arrived though there's bugs in it. The bug fix will arrive in a few days or so. You can however test it and give me some feedbacks except for bugs. Quote Link to post Share on other sites
Eli 1,129 Posted October 15, 2019 Report Share Posted October 15, 2019 Thanks for this effect @Reptillian It is what I requested and more The offset works pretty well. The rounded corners are great but a bit jagged. Quote Link to post Share on other sites
Reptillian 306 Posted October 16, 2019 Author Report Share Posted October 16, 2019 I just got a idea to try to make realistic brick though this wasn't made with Paint.NET. I made it using Krita 4.3 Beta with the latest G'MIC. 1 Quote Link to post Share on other sites
Reptillian 306 Posted October 17, 2019 Author Report Share Posted October 17, 2019 Bricks bug fix has arrived. Only the offset bug remains, but I don't feel like fixing it any time soon. Quote Link to post Share on other sites
Reptillian 306 Posted October 22, 2019 Author Report Share Posted October 22, 2019 (edited) Haven't posted a update here in a while, but now I'm definitely finishing up the GUI for updated Color Modulo Texture and adding error messages to it. Pull Request will start today tonight, or tomorrow! EDIT: Pull Request - https://github.com/dtschump/gmic-community/pull/215/commits/2df65c65fe32ee4800b91fae021bdd879eb8872d Edited October 22, 2019 by Reptillian Quote Link to post Share on other sites
Reptillian 306 Posted October 23, 2019 Author Report Share Posted October 23, 2019 (edited) Ok, news, Color Modulo Texture upgrade has arrived! Edited October 23, 2019 by Reptillian Quote Link to post Share on other sites
Reptillian 306 Posted October 25, 2019 Author Report Share Posted October 25, 2019 I have news, I think I'm going to be back on Construction Material Texture. But, however, is there any buggy filter I should know about? I know I should fix some of the palettes in my reduced transfer filter. The OOBS filter is not something I care too much about for now, that’s very low on my priority. And yes, modulo filter needs a upgrade too. Quote Link to post Share on other sites
Reptillian 306 Posted October 27, 2019 Author Report Share Posted October 27, 2019 (edited) Added Chaos Series from @MadJik Fractal Attractor to Thorn Fractal. It is on Pull Request. Edited October 27, 2019 by Reptillian Quote Link to post Share on other sites
Reptillian 306 Posted October 28, 2019 Author Report Share Posted October 28, 2019 (edited) Another update, I have added begin statements, still on the same pull request - Found out how MadJik Chaos Alternating Formula works ; Begin Statements Added Begin statements make sure that variables are only evaluated once in context of fill or f blocks or formula blocks. Think of it as variable = 5 for(x,x<w,x++){ for(y,y<h,y++) }; }; Variable = 5 equivalent to begin(variable=5;); This mean some filters will be faster. There might be bugs though I doubt I made a mistake. Edited October 28, 2019 by Reptillian Quote Link to post Share on other sites
Reptillian 306 Posted November 1, 2019 Author Report Share Posted November 1, 2019 (edited) Since new changes are not coming till 2.8, here's what will be available - - Faster distortion filters with the usage of begin. Nebulous and Modulo Texture filter also have begin statements. - Implemented Chaos from PDN Fractal Attractor to G'MIC Thorn Fractal - Fixed Form Pixels Honourable mention - Converted TR's Intense Filtration and placed it in G'MIC. It's more precise, but that's about it. Hue are in 0-360 range instead of 0-5999, this is more logical as well. Upcoming - Upgraded TR's Glass Vignette with more than 10 options. Edited November 2, 2019 by Reptillian 2 Quote Link to post Share on other sites
