null54
G'MIC (9-07-2019)
@ScrapbookWithPDN
Thank you for your words. I am really happy that thanks to Pixey's video I understood how it works.
The Spanish Water Dog (Perro ) exists since around 80-90 years, and is cultured in Spain. Then the other is the Portuguese Water Dog (Obama had one of those).
The dog named by you (Golden-Doodle ) is, as far as I know, bred in Europe in the east and is a quite young breed.  If you place a Perro next to one ( Golden-Doodle) then you can easily see the difference between the two breeds.
I chose the Perro because of his great, lovable qualities. He is not a hunter but a keeper, he is not a biter but he is self-confident enough to guard a herd. He bows a bell about barkers, they are not interesting for him.
For me it was the absolute stroke of luck, because I am not very consistent in the education. This little guy has achieved everything with me through patience and charm. We are together now for 14 years and 5 months and I have not regretted one day to have decided for him.
Have a nice day/evening and greetings from Hamburg
Share this post
Link to post
Version 1.3.0.0 doesn't seem to work with my paint.net v 4.0.19 for some reason.
EDIT: I just found that I can use v1.2.0 G'mic dll along with the newer v1.3.0 folder with the support files. Now I'm running G'mic v2.4.4 while using the compatible v1.2.0 G'mic dll for my PDN version. The best of both worlds now...
Edited by dipstick
update
Share this post
Link to post
3 minutes ago, dipstick said:
Exception has been thrown by the target of an invocation. ---> System.TypeLoadException: Could not load type 'PaintDotNet.Effects.EffectOptions' from assembly 'PaintDotNet.Effects, Version=4.19.6484.39094, Culture=neutral, PublicKeyToken=null'.
EffectOptions is a newer paint.net feature that plugin authors can use. It was added in paint.net v4.1.2.
Why have you not upgrade to the most recent paint.net?
Share this post
Link to post
I'm running Win7x64 in a VM that's locked down with no internet. I don't want to install the needed resources for the latest PDN version. Paint.net v4.0.19 works well enough with G'mic plugin v1.2.0, so I'll stick with that one.
Share this post
Link to post
Hi, sorry if I'm being really stupid, but do I need any other software to run this plugin? Because I tried both versions, putting them (both the dll and  the folder) to the effect folder, but literally nothing happens, Paint.net does not react nor shows anything at all. I had no problems with adding plugins before.
Thanks
Edited by jacrow
Share this post
Link to post
Hi @jacrow
Welcome to the forum.
No other software is needed for this new plugin.
When you say "nothing happens"  what do you expect?
Is GMic showing up in the advanced folder?
What version of Windows and Paint.Net are you running?
This is a start.
Share this post
Link to post
@AndrewDavid Thanks
Well I expect it to appear in the effect menu in Paint.net, just like other plugins I installed did. But it just doesn't happen, there is no advanced folder for that matter.
Paint.net 4.0.13 and Windows 8.1
Share this post
Link to post
Hi Again @jacrow
From some of the previous posts , I understand that the newest release of Paint.Net has some new features. These features are what allow GMic to run. The current version is 4.1.5  Upgrading may resolve the issue. https://www.getpaint.net/download.html
For clarification the plugin is found in Effects/Advanced/GMic
Let us know what happens. :)
Share this post
Link to post
@AndrewDavid Well Andrew, you have my thanks. And I feel rather stupid.
I saw the update notification in Paint.net from time to time, even recently I think... but it seems that it did not update, in fact... so yeah, the out-of-date version was the problem.
Once again, thanks :)
Share this post
Link to post
@jacrow
The great thing about the help here in Paint.net is that you can be unknowing without being considered stupid -
and that makes it a lot easier to ask for help😅
Share this post
Link to post
Added support for the G'MIC-Qt "Apply" button.
Allow the clipboard layer to have a different size than the Paint.NET document.
File version updated to 1.5.0.0.
  • Like 2
Share this post
Link to post
Released a new build of version 1.5.0.0 to fix a potential data-loss issue with the communication between G'MIC-Qt and Paint.NET.
Share this post
Link to post
@G'MIC
I miss Stylize in the latest revised version of G'mic
Hello David Tschumperlé
Since I haven't found another way to ask where Stylize stayed in the last version of G'mic, I try to get an answer in paint.net. Neither in Gimp or in Krita and also not on Paint.net is to be found under Artistic Stylize. It's just gone, this great plugin with which you can conjure up such wonderful pictures. The thought that this part is no longer there frustrates me without end.
I would be happy if Stylize would be made available again.
Greetings from Hamburg
Share this post
Link to post
I've just updated using null54's latest release and Stylize is still under Artistic
Share this post
Link to post
@null54  I just updated to the latest version, now I can't use the plugin at all. All other plugins work.
I'm getting an "Access Denied" message and when I click "OK", PDN crashes.  Here is the crash log:
Spoiler
This text file was created because paint.net crashed. Please e-mail this to crashlog4@getpaint.net so we can diagnose and fix the problem.
Application version: paint.net 4.1.5 (Final 4.105.6913.325)
Time of crash: 2/17/2019 10:56:06 AM
Application uptime: 00:00:32.1526904
Application state: Running
Working set: 233,556 KiB
Handles and threads: 2406 handles, 62 threads, 187 gdi, 250 user
Install type: Classic
Application directory: C:\Program Files\Paint.NET
Install directory: C:\Program Files\paint.net
OS Version: Windows 10 Pro 10.0.17763.0 x64 (0x30)
.NET version: CLR 4.0.30319.42000 x64
Processor: "Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz" @ ~3300MHz (6C/12T, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2)
Physical memory: 16296 MB
Video card: NVIDIA GeForce GTX 970 (v:10DE, d:13C2, r:161), Microsoft Basic Render Driver (v:1414, d:8C, r:0)
Hardware acceleration: True (default: True)
UI animations: True
UI DPI: 120.00 dpi (1.25x scale)
UI theme: VisualStyleClass=Aero, EffectiveTheme=Aero, DWM=yes, AeroColorScheme=Blue, ThemeFileName=Aero.msstyles
Updates: True, 2/17/2019
Flags:
Exception details:
System.NullReferenceException: Object reference not set to an instance of an object.
   at GmicEffectPlugin.GmicConfigDialog.ShowErrorMessage(String message)
   at GmicEffectPlugin.GmicConfigDialog.GmicThread()
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ThreadHelper.ThreadStart()
Managed assemblies:
    mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorlib.dll
    PaintDotNet, Version=4.105.6913.325, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe
    PaintDotNet.Base, Version=4.105.6913.325, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Base.dll
    PaintDotNet.Core, Version=4.105.6913.325, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Core.dll
    PaintDotNet.SystemLayer, Version=4.105.6913.325, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.SystemLayer.dll
    PaintDotNet.Framework, Version=4.105.6913.325, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Framework.dll
    PaintDotNet.Resources, Version=4.105.6913.325, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Resources.dll
    PaintDotNet.Data, Version=4.105.6913.325, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Data.dll
    PaintDotNet.Effects, Version=4.105.6913.325, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Effects.dll
    PaintDotNet.SystemLayer.Native.x64, Version=4.105.6913.325, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll
    System.Runtime.CompilerServices.Unsafe, Version=4.0.4.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Program Files\paint.net\System.Runtime.CompilerServices.Unsafe.dll
    "AA's_Assistant", Version=1.1.4329.33034, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AA's_Assistant.dll
    Aardvark, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Aardvark.dll
    ABC Perlin Noise, Version=1.0.6819.23096, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ABC Perlin Noise.dll
    Add Depth, Version=1.0.4247.30168, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Add Depth.dll
    AdvancedRotate, Version=1.0.3663.28009, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AdvancedRotate.dll
    advcolorrep, Version=1.3.3303.27314, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\advcolorrep.dll
    AForge, Version=2.2.5.0, Culture=neutral, PublicKeyToken=c1db6ff4eaa06aeb @ C:\Program Files\Paint.NET\Effects\AForge.dll
    AForge.Imaging, Version=2.2.5.0, Culture=neutral, PublicKeyToken=ba8ddea9676ca48b @ C:\Program Files\Paint.NET\Effects\AForge.Imaging.dll
    Alias, Version=2.0.3167.14578, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alias.dll
    Align, Version=1.0.1.7, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Align.dll
    AlignPlugin, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlignPlugin.dll
    Alpha-Displacement Mask, Version=1.4.1.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha-Displacement Mask.dll
    Alpha2Gray, Version=4.5.6832.21862, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha2Gray.dll
    AlphaBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaBlur.dll
    AlphaContrast, Version=1.0.3813.18307, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaContrast.dll
    alphalevels, Version=1.4.6830.2789, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\alphalevels.dll
    AlphaMask, Version=2.0.3574.41943, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMask.dll
    AlphaSpace, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaSpace.dll
    AlphaThreshold, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaThreshold.dll
    Alpha_to_0, Version=1.0.4452.22746, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha_to_0.dll
    Alpha_to_255, Version=1.0.4452.22782, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha_to_255.dll
    Angled Gradient, Version=1.0.6166.41233, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Angled Gradient.dll
    animal, Version=2.1.6443.30021, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\animal.dll
    Apply Color, Version=1.0.4406.25220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Apply Color.dll
    ArgusPaintNet.Convolution, Version=1.1.5746.27780, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPaintNet.Convolution.dll
    ArgusPaintNet.Shared, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPaintNet.Shared.dll
    ArgusPDN.Barcode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPDN.Barcode.dll
    ArgusPDN.EdgeDetect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPDN.EdgeDetect.dll
    ArgusPDN.FFTEffects, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPDN.FFTEffects.dll
    ArgusPDN.Unblend, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArgusPDN.Unblend.dll
    ArtyThing, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ArtyThing.dll
    AutoChrome, Version=1.1.8.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AutoChrome.dll
    AutoChromeNoise, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AutoChromeNoise.dll
    Average Object Color, Version=1.0.6225.37409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Average Object Color.dll
    AveragedColorBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AveragedColorBlur.dll
    BandWPlus, Version=1.1.6909.27136, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BandWPlus.dll
    Barcode, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Barcode.dll
    Basic Edge Detector, Version=1.0.5347.22706, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Basic Edge Detector.dll
    BasicAntialias11, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BasicAntialias11.dll
    BasicPhotoAdjustments, Version=2.1.4020.485, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BasicPhotoAdjustments.dll
    Bevel, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bevel_v1.4.0.0.dll
    Bezncurve, Version=4.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bezncurve.dll
    Bidirectional Blur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bidirectional Blur.dll
    BlackAndWhiteConverter, Version=1.1.3472.36275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Black and White Converter.dll
    BlackandAlpha+, Version=1.2.4329.272, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlackandAlpha+.dll
    BlackAndWhite+, Version=1.1.6744.2631, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlackAndWhite+.dll
    BlendModesPlus, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlendModesPlus.dll
    BlendSeams, Version=1.1.6021.34867, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlendSeams.dll
    BlurBlend, Version=1.1.6601.26020, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlurBlend.dll
    BlurFill, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlurFill.dll
    Border, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Border.dll
    "Borders N' Shapes", Version=4.0.4642.26476, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll
    Boutons, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Boutons.dll
    boxfitting, Version=1.1.6164.32856, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\boxfitting.dll
    BrushFactory, Version=1.8.0.12212, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BrushFactory.dll
    BrushFilter, Version=1.0.0.21152, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BrushFilter.dll
    BulletinBoardTrim, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BulletinBoardTrim.dll
    Burninate, Version=4.5.6827.39185, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Burninate.dll
    Calendar, Version=4.6.6909.25747, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Calendar.dll
    CalliColour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CalliColour.dll
    CameraLens, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CameraLens.dll
    CameraTrouserFlareV3, Version=1.1.4600.41268, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CameraTrouserFlareV3.dll
    Caption, Version=0.1.6194.31663, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Caption.dll
    Cartoonize, Version=1.0.4629.37393, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Cartoonize.dll
    CellMaker, Version=1.1.6139.29120, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CellMaker.dll
    CellMakerRev, Version=1.0.3626.24472, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CellMakerRev.dll
    CellTexture, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CellTexture.dll
    centerlines, Version=1.0.6976.652, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\centerlines.dll
    ChangeExtremeColors, Version=1.2.6.30674, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ChangeExtremeColors.dll
    Channel Ops, Version=1.1.5347.28486, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Channel Ops.dll
    circleFractal2, Version=1.1.5613.38521, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\circleFractal2.dll
    CircleText1-2, Version=1.2.6850.27870, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CircleText1-2.dll
    CircularShapes, Version=1.0.6755.22817, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CircularShapes.dll
    CircularText, Version=2.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CircularText.dll
    ClampedGaussianBlur, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClampedGaussianBlur.dll
    Clarifaction+, Version=1.0.4406.25898, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Clarifaction+.dll
    OptionBasedLibrary v0.7.9, Version=0.7.9.1561, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OptionBasedLibrary v0.7.9.dll
    Clarify, Version=1.0.4349.19613, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Clarify.dll
    ClipDisplace, Version=1.0.5763.42010, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClipDisplace.dll
    ClipDisplaceAA, Version=1.2.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClipDisplaceAA.dll
    ClipWarp, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClipWarp.dll
    ClipWarpNew, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClipWarpNew.dll
    Clock, Version=1.1.6230.35204, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Clock.dll
    CloudEffect, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CloudEffect.dll
    CMY Ghost, Version=1.0.4909.35063, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CMY Ghost.dll
    Cobweb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Cobweb.dll
    CodeArtEng.DspToolbox, Version=2.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CodeArtEng.DspToolbox.dll
    CodeLab, Version=4.1.6869.41369, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CodeLab.dll
    Color Dimmer, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Dimmer.dll
    Color Match, Version=4.0.4642.26532, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Match.dll
    coloraberation, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\coloraberation.dll
    ColorBalance, Version=4.5.6832.41698, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorBalance.dll
    ColorBalanceLesson, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorBalanceLesson.dll
    ColorClearer, Version=1.1.6009.41762, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorClearer.dll
    ColorCut, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorCut.dll
    ColorMixer, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorMixer.dll
    ColorModulo, Version=1.1.2.40250, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorModulo.dll
    ColorRange_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorRange_en.dll
    ColorSketch_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorSketch_en.dll
    ColorToAlpha, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorToAlpha.dll
    ColorZoomBlur, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorZoomBlur.dll
    Colour Distort2, Version=1.0.3564.18753, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Colour Distort.dll
    CompoGrids, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CompoGrids.dll
    Compotool, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Compotool.dll
    ContentAwareFill, Version=1.3.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ContentAwareFill.dll
    Contour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Contour.dll
    CoordinatePlanePoints, Version=1.1.6846.29158, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CoordinatePlanePoints.dll
    CopyAlpha, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CopyAlpha.dll
    Cuboids, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Cuboids.dll
    LightningCurve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurlyLines.dll
    Curves+, Version=4.0.6119.31044, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Curves+.dll
    CustomBrushesMini, Version=2.2.5286.39584, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll
    CycleHSV, Version=1.0.4909.35068, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CycleHSV.dll
    DeFisheye, Version=1.0.6819.19098, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DeFisheye.dll
    DHShapeMaker, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DHShapeMaker.dll
    Diagonal Lines, Version=1.0.4800.36619, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Diagonal Lines.dll
    Diffuse, Version=1.0.3254.27766, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Diffuse.dll
    Dimensions, Version=1.3.6826.38472, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dimensions.dll
    DisconnectedObjectShadow, Version=0.1.6546.25799, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DisconnectedObjectShadow.dll
    Displacement, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Displacement.dll
    DisplayColorChangeDirection, Version=2.0.5621.37825, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DisplayColorChangeDirection.dll
    DispMap, Version=2.0.4919.36181, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DispMap.dll
    Dissolve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dissolve.dll
    DistortingMirror, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DistortingMirror.dll
    DistortThis, Version=2.9.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DistortThis.dll
    Donut, Version=1.1.2.39581, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Donut.dll
    DotMatrix, Version=1.0.6178.27733, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DotMatrix.dll
    DPL KAL, Version=1.0.3937.11496, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DPL KAL.dll
    DPLNightVision, Version=1.0.4004.18455, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DPLNightVision.dll
    dpyColorBalance, Version=1.1.4330.37850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\dpyColorBalance.dll
    DraganEffect_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DraganEffect_en.dll
    DragFrom, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DragFrom.dll
    Dream, Version=4.5.6832.41729, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dream.dll
    Dreamy, Version=1.0.6818.30743, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dreamy.dll
    DropShadowDemo, Version=1.0.6825.32531, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DropShadowDemo.dll
    Droste, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Droste.dll
    Dryad, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dryad.dll
    EarthsAndGreys, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EarthsAndGreys.dll
    EdgeBlur, Version=1.1.6579.1729, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdgeBlur.dll
    EdgeExpander, Version=1.0.5863.38192, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdgeExpander.dll
    EdgeFader, Version=5.3.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdgeFader.dll
    edgemaster, Version=1.0.3880.5859, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\edgemaster.dll
    EdgeShaderMJW, Version=1.1.5849.39125, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdgeShaderMJW.dll
    EdHarvey.Edfects.Common, Version=3.36.3160.38013, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Edfects.Common.dll
    EdHarvey.Effects.Archive.PolarInversionPlus, Version=3.22.3024.37811, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.Archive.PolarInversionPlus.dll
    EdHarvey.Effects.Archives.DentsClassic, Version=3.5.3777.2631, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.Archives.DentsClassic.dll
    EdHarvey.Effects, Version=4.0.5120.42730, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll
    EditableText, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EditableText.dll
    EliminateDarkLight, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EliminateDarkLight.dll
    EngraveEmboss, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EngraveEmboss.dll
    EnhanceDetails, Version=1.0.3581.22689, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EnhanceDetails.dll
    EOEffects, Version=1.10.16.12, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EOEffects.dll
    SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SBCommon.dll
    Equirectangular Viewer, Version=1.0.0.42271, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Equirectangular Viewer.dll
    ErodeDilate, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ErodeDilate_v0.2.dll
    System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Design\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Design.dll
    ErrorDiffusionDithering, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ErrorDiffusionDithering.dll
    ExtendBorder, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ExtendBorder.dll
    IniFile, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IniFile.dll
    ExtractColor, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ExtractColor.dll
    Eyeshine, Version=1.0.3700.25905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Eyeshine.dll
    Facet, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Facet.dll
    FibonacciFill, Version=1.1.6139.28851, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FibonacciFill.dll
    FillFromClipboard, Version=4.6.6909.25430, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FillFromClipboard.dll
    FillFromFile, Version=4.6.6909.24920, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FillFromFile.dll
    FillPalette, Version=1.2.5.25424, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FillPalette.dll
    Film, Version=4.0.4642.26607, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Film.dll
    FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FindEdges.dll
    Fisheye, Version=2.2.5533.12794, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Fisheye.dll
    Flip, Version=4.5.6832.41809, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flip.dll
    Flourish, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flourish.dll
    FloydSteinbergDithering, Version=4.6.6944.26049, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FloydSteinbergDithering.dll
    FractalAttractor, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FractalAttractor.dll
    FractalFern, Version=1.2.0.28378, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FractalFern.dll
    FractalTree, Version=1.2.0.38806, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FractalTree.dll
    Frames, Version=1.2.5.27903, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Frames.dll
    FSPost, Version=1.0.4913.8979, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FSPost.dll
    FurBlur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FurBlur.dll
    Fuzzy Edge Detect, Version=1.0.6513.29729, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FuzzyEdgeDetect.dll
    GaussianBlurPlus, Version=4.2.5691.27401, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll
    Gears, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gears.dll
    Gen96Colors, Version=1.0.0.32381, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gen96Colors.dll
    GenTree, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GenTree.dll
    Gingham, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gingham.dll
    Gmic, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gmic.dll
    Gossamer, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gossamer.dll
    Gradient Bars, Version=4.0.5152.23084, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Bars.dll
    Gradient Blocks, Version=4.0.4642.26658, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blocks.dll
    GradientBlur, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blur.dll
    Gradient Grid, Version=4.0.6436.36068, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Grid.dll
    Gradient Mapping, Version=4.0.6547.33963, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll
    GradientsGalore, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GradientsGalore.dll
    GradientShapes-1, Version=1.0.6811.27461, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GradientShapes-1.dll
    GradientShapes-20, Version=1.0.6811.32260, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GradientShapes-20.dll
    Gradual Stripes, Version=2.0.6609.35577, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradual Stripes.dll
    Gradual_Stripes_a, Version=1.0.6595.41826, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradual_Stripes.dll
    Grain, Version=1.0.3854.25523, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Grain.dll
    GraphPaper, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GraphPaper.dll
    Gravity, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gravity.dll
    Gray2Alpha, Version=4.5.6826.36897, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gray2Alpha.dll
    GreenTintReduction, Version=1.0.6484.29238, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GreenTintReduction.dll
    Grid Warp, Version=4.0.6544.34496, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Grid Warp.dll
    GridCheckerboard, Version=4.5.6828.36789, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridCheckerboard.dll
    GridMaker, Version=5.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridMaker.dll
    GrimColorReaper, Version=1.2.4299.5808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GrimColorReaper.dll
    GuideLines, Version=1.0.6239.35558, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GuideLines.dll
    Helix, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Helix.dll
    HexaGrid, Version=4.1.0.40699, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HexaGrid.dll
    Highlight, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Highlight.dll
    HilbertCurve, Version=1.0.6636.29792, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HilbertCurve.dll
    Histogram, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Histogram.dll
    HotMetalGlow, Version=1.0.5984.26576, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HotMetalGlow.dll
    HsvEraser, Version=1.1.5625.39352, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HsvEraser.dll
    HSVGradients, Version=4.5.6832.41864, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HSVGradients.dll
    HsvScrambler, Version=1.1.5675.38718, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HsvScrambler.dll
    HueSatPlus, Version=4.5.6832.41926, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HueSatPlus.dll
    ImageDifference, Version=1.0.0.21216, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ImageDifference.dll
    ImageInText, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ImageInText.dll
    InputToOutput, Version=1.0.3167.14695, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InputToOutput.dll
    InsetBoxShadow, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InsetBoxShadow.dll
    Intensity, Version=1.0.6791.15591, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Intensity.dll
    InterlockingTiles, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InterlockingTiles.dll
    invert channels, Version=1.0.3509.14656, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\invert channels.dll
    InvertAlpha, Version=1.0.3040.33378, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InvertAlpha.dll
    isolate, Version=1.0.3303.3202, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\isolate.dll
    IsometricCuboid, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IsometricCuboid.dll
    IsometricTiled, Version=1.0.6827.41632, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IsometricTiled.dll
    JigsawPuzzle, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\JigsawPuzzle.dll
    Jitter, Version=4.0.4642.26986, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Jitter.dll
    JuliaPlus, Version=1.0.5.18510, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\JuliaPlus.dll
    JustifyText, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\JustifyText.dll
    Kaleidoscope, Version=1.6.0.33956, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll
    kb_lens, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\kb_lens.dll
    Kill Color Keeper, Version=1.0.6641.13453, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kill Color Keeper.dll
    KlumpNoiz, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KlumpNoiz.dll
    Landscape, Version=4.5.6826.38591, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Landscape.dll
    LaplacianPyramidFilter, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LaplacianPyramidFilter.dll
    LavEnt.Effects.Mosaic, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LavEnt.Effects.Mosaic.dll
    Layer Cake, Version=1.0.4911.8147, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Layer Cake.dll
    LensFlare, Version=2.2.12.38674, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LensFlare.dll
    LevelHorizon, Version=4.5.6826.37471, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LevelHorizon.dll
    Lightning, Version=1.1.3896.32593, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lightning.dll
    LightRays, Version=2.1.0.37796, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LightRays.dll
    Line Tracer, Version=1.0.4911.29141, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Line Tracer.dll
    LinesGrid, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LinesGrid_en.dll
    Linocut_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Linocut_en.dll
    Liquify, Version=4.0.5873.25113, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Liquify.dll
    ListOfPalettes, Version=1.0.0.30736, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ListOfPalettes.dll
    LocalContrast, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LocalContrast.dll
    LongiStripes, Version=1.0.6337.34025, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LongiStripes.dll
    LookAtIt.Effect, Version=0.6.0.779, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LookAtIt.Effect.dll
    LynxsterWhiteNoise_v1, Version=1.0.6854.22878, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LynxsterWhiteNoise_v1.dll
    Magnifier, Version=1.3.5.14308, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Magnifier.dll
    Majority, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Majority.dll
    MakeTransparent, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MakeTransparent.dll
    mandala, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\mandala.dll
    MandalaCreator, Version=1.2.6946.21792, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MandalaCreator.dll
    MathNet.Iridium, Version=2007.3.8.35795, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MathNet.Iridium.dll
    Matrice, Version=1.0.3810.11744, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Matrice.dll
    Melting, Version=1.3.6550.31783, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Melting.dll
    MemeMaker, Version=4.5.6828.38061, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MemeMaker.dll
    Metallize, Version=1.2.4415.32969, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Metallize.dll
    MirrorRotate, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MirrorRotate.dll
    MirrorRotateMenu, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MirrorRotateMenu.dll
    MismatchEraser, Version=1.0.6920.41978, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MismatchEraser.dll
    ModifyChannels, Version=1.0.6201.10839, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ModifyChannels.dll
    Moire, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Moire.dll
    MosaicManiac, Version=1.0.906.8, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MosaicManiac.dll
    MotionSharpen, Version=1.2.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MotionSharpen.dll
    MultiColorGradient, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MultiColorGradient.dll
    MultiSpline, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MultiSpline.dll
    MultiThreshold, Version=1.1.4330.38982, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MultiThreshold.dll
    Nebulous, Version=1.2.4.16193, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Nebulous.dll
    NeonEdges_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NeonEdges_en.dll
    NeutralWire, Version=1.0.6333.34789, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NeutralWire.dll
    NewtonFractal, Version=2.2.1.40537, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NewtonFractal.dll
    NoiseBleach, Version=1.0.4909.35542, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NoiseBleach.dll
    NoiseChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NoiseChoice.dll
    NormalMapPlus, Version=1.4.6422.43071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NormalMapPlus.dll
    Object2Colour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Object2Colour.dll
    ObjectBevel, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ObjectBevel.dll
    ObjectEdge, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Objectedge.dll
    ObjectTools, Version=4.5.6832.42044, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ObjectTools.dll
    Oblique, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Oblique.dll
    Offset Shadow, Version=1.0.4247.30184, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Offset Shadow.dll
    Offset, Version=1.0.4914.19410, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Offset.dll
    OffsetAlternatingStripes, Version=1.0.6025.41452, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OffsetAlternatingStripes.dll
    OilPaintingPlus, Version=4.5.6832.21777, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OilPaintingPlus.dll
    Olden, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Olden.dll
    Feather, Version=2.3.4315.37038, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OldFeather.dll
    OptionBasedLibrary v0.6, Version=0.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OptionBasedLibrary v0.6.dll
    Organigram, Version=1.3.6565.29874, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Organigram.dll
    Outline Object, Version=4.0.4642.26954, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline Object.dll
    Outlined text, Version=1.0.6620.40680, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outlined text.dll
    OutlineGradientText, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OutlineGradientText.dll
    OutlineSelection, Version=1.0.3055.21360, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OutlineSelection.dll
    OutlineSelectionSquare, Version=3.5.4756.19375, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OutlineSelectionSquare.dll
    Overblur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Overblur.dll
    overliner, Version=1.2.6408.35899, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Overliner.dll
    PageCurl, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PageCurl.dll
    Paneling, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Paneling.dll
    ParallelLines.Effect, Version=1.6.0.575, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ParallelLines.Effect.dll
    Paste Warp Plus, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Paste Warp Plus.dll
    PasteAlpha, Version=4.5.6826.36532, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PasteAlpha.dll
    PasteFill, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PasteFill.dll
    PasteFromClipboard, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PasteFromClipboard.dll
    Pastel, Version=4.5.6832.42132, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pastel.dll
    PdnFF, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PdnFF.dll
    PegBoardLights, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PegBoardLights.dll
    PerlinTexture, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerlinTexture.dll
    Perspective, Version=2.1.4415.36116, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Perspective.dll
    PerspectiveLines1_2, Version=1.2.3679.1005, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerspectiveLines1_2.dll
    PerspectiveTransformation, Version=1.2.5795.41799, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerspectiveTransformation.dll
    phips_kill_color, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\phips_kill_color.dll
    phips_selective_enhancer, Version=1.1.3302.33189, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\phips_selective_enhancer.dll
    phips_selective_toning, Version=1.0.3304.32827, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\phips_selective_toning.dll
    PhotoAdjustments, Version=4.5.6826.37237, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PhotoAdjustments.dll
    PieChart, Version=2.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PieChart.dll
    Pixelate+, Version=4.0.4642.26940, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pixelate+.dll
    PixSetRepl, Version=1.0.0.20200, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PixSetRepl.dll
    Planetoid, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Planetoid.dll
    PlugInData, Version=1.3.0.2, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PlugInData.dll
    pointwarp, Version=1.2.5709.42172, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PointWarpEffect.dll
    Polar, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polar.dll
    PolaroidFrame, Version=1.2.6565.30489, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PolaroidFrame.dll
    PolyGlitch.Effects, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PolyGlitch.Effects.dll
    Polygon Tool, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygon Tool.dll
    Polygon, Version=4.5.6828.38648, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygon.dll
    Polygones, Version=1.1.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygones.dll
    PostageStamp, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PostageStamp.dll
    Poster, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Poster.dll
    posterize+, Version=1.0.4629.2600, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\posterize+.dll
    PowerStretch20Beta, Version=1.9.3045.14671, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PowerStretch.dll
    PremultiplyAlpha, Version=1.0.6868.37601, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PremultiplyAlpha.dll
    PSEmboss, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PSEmboss.dll
    PSFilterPdn, Version=1.0.7.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PSFilterPdn.dll
    Psychocolour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Psychocolour.dll
    QuadrilateralCorrection, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\QuadrilateralCorrection.dll
    Quick Gravity, Version=1.0.4408.25818, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Quick Gravity.dll
    Radialcolors, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Radialcolors.dll
    RadialFade, Version=1.3.5401.38798, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RadialFade.dll
    RadiusFillCorners, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RadiusFillCorners.dll
    rainball, Version=1.0.4907.41850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\rainball.dll
    rainbow3, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\rainbow3.dll
    RainbowTwist, Version=1.2.6412.12609, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RainbowTwist.dll
    Random Effect, Version=4.0.4642.26928, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Effect.dll
    Random lines, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random lines.dll
    Random Shape Fill, Version=4.0.4642.26910, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll
    RandomMaze1, Version=1.2.5.26409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RandomMaze1.dll
    RandomMaze2, Version=1.2.5.26820, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RandomMaze2.dll
    Recolor Using Palette, Version=1.0.6382.573, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Recolor Using Palette.dll
    RecolorGray, Version=1.0.6438.38281, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RecolorGray.dll
    RecolourChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RecolourChoice.dll
    RedEyeQuickFix, Version=1.1.3161.39688, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RedEyeQuickFix.dll
    RefocusingSDe, Version=1.0.3760.21016, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RefocusingSDe.dll
    RegularNoise, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RegularNoise.dll
    RemoveBrightDark, Version=1.1.3063.36415, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RemoveBrightDark.dll
    RemoveDust, Version=4.5.6826.37862, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RemoveDust.dll
    RenderSphereHeightMap, Version=1.0.6145.37460, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RenderSphereHeightMap.dll
    Replace Colors, Version=1.1.5767.26297, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ReplaceColors.dll
    Reticulation, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Reticulation.dll
    ReverseColors, Version=1.2.6414.34455, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ReverseColors.dll
    ReverseFisheye, Version=1.0.5146.26176, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ReverseFisheye.dll
    RGBCompositor, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RGBCompositor.dll
    RGB_Remap4, Version=1.0.3538.24311, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RGB_Remap4.dll
    Rosaces, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rosaces.dll
    RotateColor, Version=0.5.0.32475, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotateColor.dll
    RotateText, Version=1.1.4415.32628, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotateText.dll
    RoundedRectangle, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RoundedRectangle.dll
    RubberStamp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RubberStamp.dll
    Ruler, Version=1.0.6846.37263, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Ruler.dll
    Saturation to Alpha, Version=1.0.5346.26026, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Saturation to Alpha.dll
    SaturationRGB, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SaturationRGB.dll
    Scintillate, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Scintillate.dll
    ScratchArt_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScratchArt_en.dll
    ScreenPixel, Version=1.1.6846.39497, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScreenPixel.dll
    Scribble, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Scribble.dll
    ScriptLab, Version=4.0.6107.18914, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScriptLab.dll
    SeamCarving, Version=4.5.6838.35770, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamCarving.dll
    SeamlessHelper, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessHelper.dll
    SeamlessTextureMaker, Version=1.2.5.29984, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll
    Selection2Clear, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Selection2Clear.dll
    SelectionObscure, Version=1.1.4602.34476, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionObscure.dll
    SelectionText, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionText.dll
    SelectionTools, Version=4.5.6832.22117, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionTools.dll
    ShadowEffect, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ShadowEffect.dll
    ShadowHighlight, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ShadowHighlight.dll
    Shape3D, Version=1.2.6.2, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shape3D.dll
    shapegradient, Version=1.5.3886.6574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\shapegradient.dll
    Shapes, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shapes.dll
    Sharpen+, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sharpen+.dll
    Sierpinski, Version=2.2.6438.28160, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sierpinski.dll
    silhouetteplus, Version=1.1.3131.17586, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\silhouetteplus.dll
    SinWaves, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SinWaves.dll
    Slinky, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Slinky.dll
    Smooth, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smooth.dll
    SmoothNoise, Version=1.0.0.28227, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SmoothNoise.dll
    Smudge, Version=4.0.5873.25097, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smudge.dll
    Sound wave, Version=2.1.3542.36435, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sound wave.dll
    SpacedOutlinedText, Version=1.0.6811.25344, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpacedOutlinedText.dll
    SpacedTextPlugin, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpacedTextPlugin.dll
    Specular, Version=1.0.3254.27778, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Specular.dll
    SpeechBubble, Version=2.1.4445.42029, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpeechBubble.dll
    SpiralText, Version=1.4.4415.32775, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiralText.dll
    SpiroGraph, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroGraph.dll
    SpiroShapes, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroShapes.dll
    Splashes, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splashes.dll
    Splatter, Version=4.0.5873.25083, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splatter.dll
    SplitHueAndBrightness, Version=1.0.5800.37276, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SplitHueAndBrightness.dll
    SpokedWheel, Version=1.1.6846.37336, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpokedWheel.dll
    SpongeLesson, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpongeLesson.dll
    Sponge_3, Version=1.0.6817.19644, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sponge_3.dll
    Sponge_4, Version=1.0.6818.36403, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sponge_4.dll
    Sponge_en, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sponge_en.dll
    Sponge_v1, Version=1.2.6818.17854, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sponge_v1_1.dll
    Sponge_v1_2, Version=1.0.6820.12553, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sponge_v1_2.dll
    SpotCenter, Version=1.2.0.17265, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpotCenter.dll
    SprinklerHead, Version=0.9.6303.26648, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SprinklerHead.dll
    Squirkle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Squirkle.dll
    SquirkleWarp, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SquirkleWarp.dll
    StarGlow, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StarGlow.dll
    Stars, Version=1.3.5.21601, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stars.dll
    StewienFilters, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StewienFilters.dll
    Stickman, Version=1.2.2.30005, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stickman.dll
    Stitch, Version=4.0.4642.26808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stitch.dll
    StrayPixelRemover, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StrayPixelRemover.dll
    StringAndPin, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StringAndPin.dll
    SubLCD, Version=1.2.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SubLCD.dll
    Table, Version=1.1.5847.38905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Table.dll
    Tartan, Version=1.5.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tartan.dll
    Tattersall, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tattersall.dll
    Temperature, Version=4.5.6832.41128, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Temperature.dll
    Tesserae, Version=1.0.6200.27517, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tesserae.dll
    EnvelopeDistorsion, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextDistorsion.dll
    TextMask, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextMask.dll
    TextPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Textplus.dll
    Texture Object Rounder, Version=1.0.6464.41586, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Texture Object Rounder.dll
    Texture Scaler, Version=1.1.6217.32880, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Texture Scaler.dll
    TextureMerger, Version=1.1.6159.40169, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextureMerger.dll
    Microsoft.GeneratedCode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ <Location?>
    TextureShader, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextureShader.dll
    TextureSmoother, Version=1.0.6096.31689, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextureSmoother.dll
    TextureViewSkewer, Version=1.0.5713.42082, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextureViewSkewer.dll
    Texturize, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Texturize.dll
    TextWindow, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextWindow.dll
    TGAngle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TGAngle.dll
    TGMagnitude, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TGMagnitude.dll
    ThermalHeatMapEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThermalHeatMapEffect.dll
    Tiles, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tiles.dll
    TileWorld, Version=1.0.2.30273, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TileWorld.dll
    Tournesol, Version=1.0.0.29873, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tournesol.dll
    "TR's Pixel Push", Version=1.0.4954.37564, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TR's Pixel Push.dll
    "TR'sColorizerHMS", Version=1.0.4937.30626, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TR'sColorizerHMS.dll
    Trail, Version=4.0.4642.26791, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Trail.dll
    trail3d, Version=1.0.3902.32071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\trail3d.dll
    Trail Blur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TrailBlur.dll
    Transparency, Version=4.5.6832.41213, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transparency.dll
    TransparentToTransparentWhite, Version=1.0.6963.30396, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TransparentToTransparentWhite.dll
    TreeGen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TreeGen.dll
    TrippyRainbow, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TrippyRainbow.dll
    TRs Scatter, Version=1.3.4949.23250, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRs Scatter.dll
    TRsAlphaCutter, Version=3.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsAlphaCutter.dll
    TRsAlphaMapper, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsAlphaMapper.dll
    TRsBokeh, Version=2.0.5457.42261, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsBokeh.dll
    TRsBrushStrokes, Version=1.0.6.11937, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsBrushStrokes.dll
    TRsBWPhoto, Version=1.0.4949.38907, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsBWPhoto.dll
    TRsCloudControl, Version=2.0.4968.34489, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCloudControl.dll
    TRsColorReducer, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsColorReducer.dll
    TRsContourFiller, Version=1.5.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsContourFiller.dll
    TRsCoquin, Version=1.0.4960.31131, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCoquin.dll
    TRsCroquis, Version=1.4.5634.10354, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCroquis.dll
    TRsCustomPaletteMatch, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCustomPaletteMatch.dll
    TRsCustomRandomFill, Version=1.5.1.31287, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCustomRandomFill.dll
    TRsDodgeBurn, Version=1.4.0.33503, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsDodgeBurn.dll
    TRsDoodleMatic, Version=1.4.5045.31846, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsDoodleMatic.dll
    TRsDrumSkin, Version=1.4.5199.15427, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsDrumSkin.dll
    TRsExportSelection, Version=1.0.5668.9645, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsExportSelection.dll
    TRsFilaments, Version=1.0.15.11399, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFilaments.dll
    TRsFilmStock, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFilmStock.dll
    TRsFilmStripPlgIn, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFilmStripPlgIn.dll
    TRsFireWorks, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFireWorks.dll
    TRsFreeWarp, Version=1.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFreeWarp.dll
    TRsFuego, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFuego.dll
    TRsGlassVignette, Version=1.1.5239.30797, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsGlassVignette.dll
    TRsHalfTone, Version=1.0.4937.7773, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsHalfTone.dll
    TRsIntenseFilteration, Version=1.3.5390.22367, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsIntenseFilteration.dll
    TRsIntensityWarp, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsIntensityWarp.dll
    TRsiPollock, Version=1.0.3.11944, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsIPollock.dll
    TRsIsopleth, Version=1.0.3.10995, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsIsopleth.dll
    TRsKaboom, Version=1.0.5118.21464, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsKaboom.dll
    TRsKeyFrame, Version=1.2.5693.38036, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsKeyFrame.dll
    TRsMonolithic, Version=1.0.5.26132, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsMonolithic.dll
    TRsMorpher, Version=1.1.10.8959, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsMorpher.dll
    TRsPanoPDN, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPanoPDN.dll
    TRsPasteFrame, Version=1.3.20.9613, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPasteFrame.dll
    TRsPasteWarp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPasteWarp.dll
    TRsPixelPuller, Version=1.1.4994.29625, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPixelPuller.dll
    TRsPixelSharp, Version=2.0.5467.31590, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPixelSharp.dll
    TRsPlasmatix, Version=1.0.5220.31660, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPlasmatix.dll
    TRsPSnap, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPSnap.dll
    TRsQuickOutline, Version=1.5.5713.19293, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsQuickOutline.dll
    TRsRadialExtruder, Version=1.2.5609.8244, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsRadialExtruder.dll
    TRsRetouch, Version=1.0.5684.16160, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsRetouch.dll
    TRsSelfeez, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSelfeez.dll
    TRsSmudger, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSmudger.dll
    TRsSnowFlakeMaker, Version=1.0.1.1701, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSnowFlakeMaker.dll
    TRsSphereCuber, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSphereCuber.dll
    TRsSplineMaster, Version=1.4.2.18310, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSplineMaster.dll
    TRsStarFilter, Version=1.0.4930.9612, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStarFilter.dll
    TRsStr8Edge, Version=1.1.5045.31905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStr8Edge.dll
    TRsStrangeAttractor, Version=1.1.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStrangeAttractor.dll
    TRsStrobeMotion, Version=1.2.4962.30523, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStrobeMotion.dll
    TRsTeslaCoil, Version=1.0.4935.18219, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTeslaCoil.dll
    TRsThirdDimension, Version=1.7.13.38717, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsThirdDimension.dll
    TRsTiledPixels, Version=1.2.4942.13226, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTiledPixels.dll
    TRsTiltShift, Version=1.0.4957.12341, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTiltShift.dll
    TRsTreeMaker, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTreeMaker.dll
    TRsZigZag, Version=1.1.4929.6773, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsZigZag.dll
    Truncate resolution, Version=1.0.5346.33759, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Truncate resolution.dll
    TubeOblique, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TubeOblique.dll
    TurbulentCircles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TurbulentCircles.dll
    TurbulentLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TurbulentLines.dll
    Tweaktrans2, Version=2.0.4252.27152, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tweaktrans2.dll
    Twist, Version=4.0.5873.25056, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Twist.dll
    TwistedTorus, Version=1.0.6742.39190, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwistedTorus.dll
    TwistZ, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwistZ.dll
    TwoPointPerspective, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwoPointPerspective.dll
    TwoToneThreshold, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwoToneThreshold.dll
    UnselectedRectangleKeeper, Version=1.0.5669.37022, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\UnselectedRectangleKeeper.dll
    Vandermotten.PaintDotNetEffects.Blurs, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll
    Vandermotten.PaintDotNetEffects.ColorAccent, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll
    Vandermotten.PaintDotNetEffects, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.dll
    Vandermotten.PaintDotNetEffects.DropShadow, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll
    Vandermotten.PaintDotNetEffects.Duotones, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll
    Vandermotten.PaintDotNetEffects.FadeEdge, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll
    Vandermotten.PaintDotNetEffects.Gradient, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll
    Vandermotten.PaintDotNetEffects.Grid, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Grid.dll
    Vandermotten.PaintDotNetEffects.Monochromes, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll
    VanishPoint, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\VanishPoint.dll
    Varicose2, Version=2.1.1.42085, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Varicose2.dll
    Vibration, Version=1.0.4407.34043, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vibration.dll
    Vibrato, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vibrato.dll
    ViewFramer, Version=1.0.6074.42436, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ViewFramer.dll
    Vignette1, Version=1.0.3538.14367, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vignette1.dll
    VignettePlus, Version=4.5.6826.39332, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\VignettePlus.dll
    Volutes, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Volutes.dll
    WaterReflection, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaterReflection.dll
    Waves, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Waves.dll
    WaveText, Version=1.2.4415.32811, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaveText.dll
    WetFloor, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WetFloor.dll
    WhichSymbolRedux, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WhichSymbolRedux.dll
    WovenPhoto94, Version=1.94.6505.33087, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WovenPhoto94.dll
    WovenPhoto95, Version=1.94.6529.30892, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WovenPhoto95.dll
    X Rainbow bars, Version=1.0.3536.37632, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\X Rainbow bars.dll
    XYCoords, Version=1.2.6.20096, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\XYCoords.dll
    Zoom Blur Deluxe CL, Version=1.0.6896.32632, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Zoom Blur Deluxe CL.dll
    ABRFileType, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ABRFileType.dll
    CSVFiletype, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\CSVFiletype.dll
    IcoCur, Version=4.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\IcoCur.dll
    ImAGIF.FileType, Version=0.12.0.1084, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImAGIF.FileType.dll
    ImAPNG.FileType, Version=0.3.0.19, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImAPNG.FileType.dll
    ImEmf\,Wmf.FileType, Version=1.1.0.158, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImEmf,Wmf.FileType.dll
    ImPDF.Open.FileType, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImPDF.Open.FileType.dll
    ImPDF.Save.FileType, Version=1.4.5187.23557, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImPDF.Save.FileType.dll
    ImPS\,EPS\,AI.Open.FileType, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImPS,EPS,AI.Open.FileType.dll
    ImSVG.Open.FileType, Version=0.18.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImSVG.Open.FileType.dll
    ImXcf.FileType, Version=1.4.0.95, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImXCF.FileType.dll
    OptiPngFileType, Version=10.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\OptiPngFileType.dll
    PatternFileType, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PatternFileType.dll
    PcxFileType, Version=0.9.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PcxFileType.dll
    PhotoShop, Version=2.5.0.40665, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PhotoShop.dll
    SpriteSheet, Version=1.2.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\SpriteSheet.dll
    WebPFileType, Version=1.0.9.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\WebPFiletype.dll
    Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\Accessibility\v4.0_4.0.0.0__b03f5f7f11d50a3a\Accessibility.dll
Native modules:
    C:\Program Files\Paint.NET\PaintDotNet.exe, version=4.105.6913.325
    C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\MSCOREE.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\KERNEL32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Program Files (x86)\PCPitstop\Super Shield\SuperShieldHookCpy64.dll, version=3.0.11.0
    C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\msvcrt.dll, version=7.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\sechost.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\RPCRT4.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\SHELL32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\ucrtbase.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\shcore.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\combase.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\windows.storage.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\msvcp_win.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\profapi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\powrprof.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\shlwapi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\GDI32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\gdi32full.dll, version=10.0.17763.316 (WinBuild.160101.0800)
    C:\WINDOWS\System32\USER32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\win32u.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\kernel.appcore.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\cryptsp.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\IMM32.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.7.3190.0 built by: NET472REL1LAST_C
    C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\SYSTEM32\MSVCR120_CLR0400.dll, version=12.00.52519.0 built by: VSWINSERVICING
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\mscorlib\a4c029035a52b21a293c249a889b6925\mscorlib.ni.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\System32\ole32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\uxtheme.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Program Files (x86)\Stardock\Start10\Start10_64.dll, version=1.6.1.0
    C:\Program Files (x86)\Stardock\Fences\FencesMenu64.dll, version=3.0.9.11
    C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.17763.292 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WTSAPI32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.17763.316_none_36a02ec761b1c084\gdiplus.dll, version=10.0.17763.316 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System\e65b7fc2cdb258e12f5157d45e98ae31\System.ni.dll, version=4.7.3353.0 built by: NET472REL1LAST_B
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Core\c1385e46d5b4e393009027215a0c9063\System.Core.ni.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\WindowsBase\4e0cf5c025f73c5f2d1a235077889ac9\WindowsBase.ni.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\system32\rsaenh.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\bcrypt.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Drawing\cf57e007dbdfaacf2d77d89618661a02\System.Drawing.ni.dll, version=4.7.3190.0 built by: NET472REL1LAST_C
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PresentationCore\d25356ce85053f2a55cef8fafc0c247b\PresentationCore.ni.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\1747a42639d0ab5cc579cc2583f711a5\PresentationFramework.ni.dll, version=4.7.3324.0
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\46c8a903cf269b47842cec62d1f5f800\PaintDotNet.Base.ni.dll, version=4.105.6913.325
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\6ba4fb641ef0e48e731192c27cf61703\System.Windows.Forms.ni.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\393645bde9685ffe645cd6d1d5a2c249\PaintDotNet.SystemLayer.ni.dll, version=4.105.6913.325
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\3e554948a732991510a2184e5963fcbe\PaintDotNet.Core.ni.dll, version=4.105.6913.325
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\6fe0f7af0cb7b4f613922092138468d8\PaintDotNet.Resources.ni.dll, version=4.105.6913.325
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\645c8df42a63c0aeefedea9877d5ae81\PaintDotNet.Framework.ni.dll, version=4.105.6913.325
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\f296a0edef100dcda1a859f962347ce7\PaintDotNet.Data.ni.dll, version=4.105.6913.325
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\d16b12b3f0b026747c396cfda53f5fb9\PaintDotNet.Effects.ni.dll, version=4.105.6913.325
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet\b9e65511a2589123bbda5c204c60aaa4\PaintDotNet.ni.exe, version=4.105.6913.325
    C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\SYSTEM32\MSVCP120_CLR0400.dll, version=12.00.52519.0 built by: VSWINSERVICING
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\Program Files\Paint.NET\SxS\X64\vcruntime140.dll, version=14.14.26405.0 built by: VCTOOLSREL
    C:\Program Files\Paint.NET\SxS\X64\msvcp140.dll, version=14.14.26405.0 built by: VCTOOLSREL
    C:\Program Files\Paint.NET\SxS\X64\msvcp140_1.dll, version=14.14.26405.0 built by: VCTOOLSREL
    C:\Program Files\Paint.NET\SxS\X64\msvcp140_2.dll, version=14.14.26405.0 built by: VCTOOLSREL
    C:\Program Files\Paint.NET\SxS\X64\vcomp140.dll, version=14.14.26405.0 built by: VCTOOLSREL
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Configuration\ddb7bbe8064cd36b6769e89084872a2a\System.Configuration.ni.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml\e33fe851cd3e0d8899daf6b1b5bc961a\System.Xml.ni.dll, version=4.7.3190.0 built by: NET472REL1LAST_C
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\System32\MSCTF.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\9d6886fcb6abb873096b6484324bd4c0\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.105.6913.325
    C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll, version=4.105.6913.325
    C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\dwmapi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\CRYPT32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\MSASN1.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    C:\WINDOWS\System32\UIAnimation.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.17763.316_none_05b53be2071f46b6\comctl32.dll, version=6.10 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.17763.55 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xaml\8923af04d1cebb19f15670aacb61fc81\System.Xaml.ni.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Runtea61dfd5#\d0008ae073b96ea758ae877ac1edfd67\System.Runtime.CompilerServices.Unsafe.ni.dll, version=
    C:\WINDOWS\system32\dataexchange.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\dcomp.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\RMCLIENT.dll, version=10.0.17763.194 (WinBuild.160101.0800)
    C:\WINDOWS\System32\TextInputFramework.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.17763.194
    C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.17763.1
    C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\wintypes.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Program Files (x86)\DisplayFusion\Hooks\AppHook64_69313BB1-7E89-4CCF-805A-47E5E331B095.dll, version=9.4.0.4
    C:\WINDOWS\SYSTEM32\WINMM.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.17763.316_none_10dfcac86432709b\COMCTL32.dll, version=5.82 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\winmmbase.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_9db4450b8107f59a\nvldumdx.dll, version=25.21.14.1722
    C:\WINDOWS\System32\WINTRUST.DLL, version=10.0.17763.292 (WinBuild.160101.0800)
    C:\WINDOWS\System32\imagehlp.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_9db4450b8107f59a\nvwgf2umx.dll, version=25.21.14.1722
    C:\WINDOWS\system32\nvspcap64.dll, version=3.16.0.140
    C:\WINDOWS\system32\explorerframe.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Design\a81206f07ee5a807beddd5e0df07a866\System.Design.ni.dll, version=4.7.3190.0 built by: NET472REL1LAST_C
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=14.7.3190.0 built by: NET472REL1LAST_C
    C:\WINDOWS\SYSTEM32\policymanager.dll, version=10.0.17763.168 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\msvcp110_win.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\winhttp.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\NSI.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\WS2_32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\psapi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\rasapi32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\rasman.dll, version=10.0.17763.292 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\rtutils.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\mswsock.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\DNSAPI.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WINNSI.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\rasadhlp.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\fwpuclnt.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\secur32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\SSPICLI.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\schannel.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\mskeyprotect.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\ncrypt.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\NTASN1.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\ncryptsslp.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\gpapi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Accessibility\b8265f8bc5ff5e57a7dd5030ce79559b\Accessibility.ni.dll, version=4.7.3190.0 built by: NET472REL1LAST_C
    C:\WINDOWS\SYSTEM32\edputil.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\urlmon.dll, version=11.00.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\iertutil.dll, version=11.00.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\CLDAPI.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\FLTLIB.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\appresolver.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\Bcp47Langs.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\SLC.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\sppc.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\SetupApi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.17763.1 (WinBuild.160101.0800)
Working fine in previous version.  No files are 'blocked'.  I can't figure it out.
EDIT:  I went in and changed the permissions on the folder and the Gmic dll file.  Now it works.  I've never had to do that before.
           Oh well, there's always some kind of 'glitch' sooner or later.  :)
Share this post
Link to post
@lynxster4
I have the latest version of G´mic on all programs. I press the refresh button at regular intervals. Also yesterday I clicked on this small button. Stylize was and remained disappeared, also "Test". I shut down my PC without success. When I returned to the PC after hours, stylize and "Test" were there again as if by magic. 😃I am very happy about it!
Thanks for the answers.
Greetings from Hamburg
Share this post
Link to post
Improved performance when transferring the output image from G'MIC-Qt.
Prevent the 32-bit version of  G'MIC-Qt from attempting to load images larger than 4GB.
File version updated to 1.5.1.0.
The 4GB limit on 32-bit is a sanity check to prevent issues when calculating the total image size, in case someone is using it with the 64-bit version of Paint.NET.
Even the 64-bit version of G'MIC-Qt fails to load images that size.
14 hours ago, lynxster4 said:
I'm getting an "Access Denied" message and when I click "OK", PDN crashes.  Here is the crash log:
I am not able to reproduce that crash, but I did get a few memory access errors when trying to load images > 3GB in size.
Share this post
Link to post
