null54
G'MIC (8-14-2019)
(Yes I did make an account just to ask this) Is this still supported with newer versions of Paint.Net? I tried to install it the way the ReadMe says to, but the thing is that the next time I start up the program, when I go into the effects>advanced menu (or any other effects menu for that matter) nothing about G'MIC is there. I am using the 64-bit version of Windows 10 and I installed the 64-bit version of the plugin, so that shouldn't be a problem.
Edited by Psherman01
Add extra sentence at the beginning
Share this post
Link to post
The plugin uses features that require Paint.NET 4.1.6, it will not work with older versions.
Does it appear in Settings > Plugin Errors.
Share this post
Link to post
Yeah, for some reason I was still on 4.1.5. I upgraded and now it's fine. I'm not gonna make excuses, that was just stupid of me to not try that.
Share this post
Link to post
Updated to G'MIC version 2.5.7
Add support for reading Bitmaps with alpha from the clipboard.
  • Like 2
Share this post
Link to post
1 hour ago, sashwilko said:
? mine is 2.5.7 and no fragment blur ?
The reason it doesn't show up is because 2.5.7 is no longer being updated. 2.6 is the current G'MIC version. All I could do for other PDN users to use my filter in those stage is copy and paste the code. People can still go to reptorian.gmic at gmic-community, and copy and paste current code into updatexxxx.gmic at %appdata%/gmic.
Share this post
Link to post
Where do I get the latest version from? I visited the G'mic website but the download link just brings me back to this forum.
Share this post
Link to post
This text file was created because paint.net crashed. Please e-mail this to crashlog4@getpaint.net so we can diagnose and fix the problem.
Application version: paint.net 4.1.6 (Final 4.106.7016.38074)
Time of crash: 5/10/2019 10:54:50 AM
Application uptime: 00:00:16.4858554
Application state: Running
Working set: 188,536 KiB
Handles and threads: 1605 handles, 40 threads, 153 gdi, 213 user
Install type: Classic
Application directory: C:\Program Files\paint.net
Current directory: C:\Program Files\paint.net
Install directory: C:\Program Files\paint.net
OS Version: Windows 10 Pro 10.0.17763.0 x64 (0x30)
.NET version: CLR 4.0.30319.42000 x64
Processor: "Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz" @ ~3492MHz (4C/4T, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2)
Physical memory: 16324 MB
Video card: NVIDIA GeForce GTX 1050 Ti (v:10DE, d:1C82, r:161), Microsoft Basic Render Driver (v:1414, d:8C, r:0)
Hardware acceleration: True (default: True)
UI animations: True
UI DPI: 96 dpi (1.00x scale)
UI theme: VisualStyleClass=Aero, EffectiveTheme=Aero, DWM=yes, AeroColorScheme=Dark, ThemeFileName=Aero.msstyles
Updates: False, 1/1/0001
Flags:
Exception details:
System.IO.EndOfStreamException: Attempted to read past the end of the stream.
   at PaintDotNet.IO.StreamExtensions.ProperRead(Stream input, Byte[] buffer, Int32 offset, Int32 count) in D:\src\pdn\src\Base\IO\StreamExtensions.cs:line 131
   at GmicEffectPlugin.GmicPipeServer.WaitForConnectionCallback(IAsyncResult result)
   at System.IO.Pipes.NamedPipeServerStream.AsyncWaitForConnectionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOverlapped)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Managed assemblies:
    mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorlib.dll
    PaintDotNet, Version=4.106.7016.38074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.exe
    PaintDotNet.Base, Version=4.106.7016.38074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Base.dll
    PaintDotNet.Core, Version=4.106.7016.38074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Core.dll
    PaintDotNet.SystemLayer, Version=4.106.7016.38074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.SystemLayer.dll
    PaintDotNet.Framework, Version=4.106.7016.38074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Framework.dll
    PaintDotNet.Resources, Version=4.106.7016.38074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Resources.dll
    PaintDotNet.Data, Version=4.106.7016.38074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Data.dll
    PaintDotNet.Effects, Version=4.106.7016.38074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Effects.dll
    PaintDotNet.SystemLayer.Native.x64, Version=4.106.7016.38074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll
    System.Runtime.CompilerServices.Unsafe, Version=4.0.4.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Program Files\paint.net\System.Runtime.CompilerServices.Unsafe.dll
    System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Runtime.dll
    Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\Accessibility\v4.0_4.0.0.0__b03f5f7f11d50a3a\Accessibility.dll
    "AA's_Assistant", Version=1.1.4329.33034, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AA's_Assistant.dll
    Aardvark, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Aardvark.dll
    Add Depth, Version=1.0.4247.30168, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Add Depth.dll
    advcolorrep, Version=1.3.3303.27314, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\advcolorrep.dll
    AdvGrey, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AdvGrey.dll
    AForge, Version=2.2.5.0, Culture=neutral, PublicKeyToken=c1db6ff4eaa06aeb @ C:\Program Files\paint.net\Effects\AForge.dll
    AForge.Imaging, Version=2.2.5.0, Culture=neutral, PublicKeyToken=ba8ddea9676ca48b @ C:\Program Files\paint.net\Effects\AForge.Imaging.dll
    AlignPlugin, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AlignPlugin.dll
    Alpha-Displacement Mask, Version=1.4.1.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Alpha-Displacement Mask.dll
    Alpha2Gray, Version=4.5.6832.21862, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Alpha2Gray.dll
    AlphaMask, Version=2.0.3574.41943, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AlphaMask.dll
    AlphaThreshold, Version=1.0.4677.33078, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\AlphaThreshold.dll
    Alpha_to_0, Version=1.0.4452.22746, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Alpha_to_0.dll
    Alpha_to_255, Version=1.0.4452.22782, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Alpha_to_255.dll
    Apply Texture, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Apply Texture.dll
    ArtyThing, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ArtyThing.dll
    BasicAntialias11, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BasicAntialias11.dll
    BasicPhotoAdjustments, Version=2.1.4020.485, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BasicPhotoAdjustments.dll
    OutlinedGradientText, Version=1.1.6826.41783, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BBOutlinedGradientText.dll
    BevelObject, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BevelObject.dll
    Bidirectional Blur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Bidirectional Blur.dll
    BlackAndWhiteConverter, Version=1.1.3472.36275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Black and White Converter.dll
    BlackandAlpha+, Version=1.2.4329.272, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BlackandAlpha+.dll
    BlendModesPlus, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BlendModesPlus.dll
    BlurBlend, Version=1.1.6601.26020, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BlurBlend.dll
    "Borders N' Shapes", Version=4.0.4642.26476, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Borders N' Shapes.dll
    boxfitting, Version=1.0.6162.25420, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\boxfitting.dll
    BrushFactory, Version=1.0.0.25814, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\BrushFactory.dll
    Bullet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Bullet.dll
    Burninate, Version=4.5.6827.39185, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Burninate.dll
    Calendar, Version=4.5.6832.41660, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Calendar.dll
    CameraTrouserFlareV3, Version=1.1.4600.41268, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CameraTrouserFlareV3.dll
    Cartoonize, Version=1.0.4629.37393, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Cartoonize.dll
    centerlines, Version=1.0.6976.652, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\centerlines.dll
    CircleText, Version=1.4.4415.32488, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CircleText.dll
    ClampedGaussianBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ClampedGaussianBlur.dll
    ClipWarp, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ClipWarp.dll
    ClipWarpNew, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ClipWarpNew.dll
    CloudEffect, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CloudEffect.dll
    CMY Ghost, Version=1.0.4909.35063, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CMY Ghost.dll
    Cobweb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Cobweb.dll
    Color Match, Version=4.0.4642.26532, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Color Match.dll
    ColorBalance, Version=4.5.6832.41698, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorBalance.dll
    ColorClearer, Version=1.1.6009.41762, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorClearer.dll
    ColorCut, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorCut.dll
    ColorMixer, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorMixer.dll
    ColorRange_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorRange_en.dll
    ColorSketch_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorSketch_en.dll
    ColorToAlpha, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ColorToAlpha.dll
    Compotool, Version=1.0.4368.42355, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Compotool.dll
    ContentAwareFill, Version=1.3.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ContentAwareFill.dll
    contourJune2011v2, Version=1.0.4182.2900, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\contour.dll
    Cuboids, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Cuboids.dll
    LightningCurve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CurlyLines.dll
    Curves+, Version=4.0.6119.31044, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Curves+.dll
    CustomBrushesMini, Version=2.2.5286.39584, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CustomBrushesMini.dll
    DHShapeMaker, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DHShapeMaker.dll
    Diffuse, Version=1.0.3254.27766, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Diffuse.dll
    Dimensions, Version=1.3.6826.38472, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Dimensions.dll
    DispMap, Version=2.0.4919.36181, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DispMap.dll
    DistortThis, Version=2.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DistortThis.dll
    DotMatrix, Version=1.0.6178.27733, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DotMatrix.dll
    dpyColorBalance, Version=1.1.4330.37850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\dpyColorBalance.dll
    DraganEffect_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DraganEffect_en.dll
    DragFrom, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\DragFrom.dll
    Dream, Version=4.5.6832.41729, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Dream.dll
    Droste, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Droste.dll
    Dryad, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Dryad.dll
    Earths&Greys2a, Version=1.0.4041.40688, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Earths&Greys.dll
    EdgeExpander, Version=1.0.5863.38192, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EdgeExpander.dll
    EdgeFader, Version=5.3.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EdgeFader.dll
    EdgeShaderMJW, Version=1.1.5849.39125, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EdgeShaderMJW.dll
    EdHarvey.Effects.Archives.DentsClassic, Version=3.5.3777.2631, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EdHarvey.Effects.Archives.DentsClassic.dll
    EdHarvey.Effects, Version=4.0.5120.42730, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EdHarvey.Effects.dll
    EdHarvey.FastFx, Version=0.1.3426.11348, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EdHarvey.FastFx.dll
    EditableText, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EditableText.dll
    EliminateDarkLight, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EliminateDarkLight.dll
    EOEffects, Version=1.10.16.12, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\EOEffects (2).dll
    ErodeDilate, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ErodeDilate_v0.2.dll
    ExtendBorder, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ExtendBorder.dll
    SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SBCommon.dll
    Eyeshine, Version=1.0.3700.25905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Eyeshine.dll
    Facet, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Facet.dll
    FibonacciFill, Version=1.1.6139.28851, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FibonacciFill.dll
    FillFromClipboard, Version=4.5.6826.30801, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FillFromClipboard.dll
    FillFromFile, Version=4.5.6826.31854, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FillFromFile.dll
    Film, Version=4.0.4642.26607, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Film.dll
    FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FindEdges.dll
    Fisheye, Version=2.2.5533.12794, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Fisheye.dll
    Flip, Version=4.5.6832.41809, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Flip.dll
    System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Design\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Design.dll
    FloydSteinbergDithering, Version=4.5.6828.38953, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FloydSteinbergDithering.dll
    FurBlur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\FurBlur.dll
    GaussianBlurPlus, Version=4.2.5691.27401, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GaussianBlurPlus.dll
    Gears, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gears.dll
    GenTree, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GenTree.dll
    Gmic, Version=2.6.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gmic.dll
    Gossamer, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gossamer.dll
    Gradient Bars, Version=4.0.5152.23084, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gradient Bars.dll
    Gradient Blocks, Version=4.0.4642.26658, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gradient Blocks.dll
    Gradient Mapping, Version=4.0.6107.40059, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gradient Mapping.dll
    GradientsGalore, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GradientsGalore.dll
    Grain, Version=1.0.3854.25523, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Grain.dll
    Gray2Alpha, Version=4.5.6826.36897, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Gray2Alpha.dll
    Grid Warp, Version=4.0.5873.25124, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Grid Warp.dll
    GridCheckerboard, Version=4.5.6828.36789, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GridCheckerboard.dll
    GrimColorReaper, Version=1.2.4299.5808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\GrimColorReaper.dll
    Heightmap plugin v1, Version=1.3.4261.22267, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Heightmap v1.3.dll
    HeightToNormal, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HeightToNormal.dll
    HexaGrid, Version=4.1.0.40699, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HexaGrid.dll
    highlightv2, Version=1.0.4253.28274, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\highlightv2.dll
    HighPass, Version=1.2.3903.27501, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HighPass.dll
    HighPass_rec, Version=1.3.6135.23156, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HighPass_rec.dll
    HotMetalGlow, Version=1.0.5984.26576, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HotMetalGlow.dll
    HSVGradients, Version=4.5.6832.41864, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HSVGradients.dll
    HueSatPlus, Version=4.5.6832.41926, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\HueSatPlus.dll
    IcoCur, Version=3.7.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\IcoCur.dll
    ImgurUploader, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ImgurUploader.dll
    InnerShadow, Version=3.0.5509.3391, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\InnerShadow.dll
    InsetBoxShadow, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\InsetBoxShadow.dll
    InterlockingTiles, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\InterlockingTiles.dll
    PDNPI_IndirectUI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\jchunn.dll
    JigsawPuzzle, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\JigsawPuzzle.dll
    Jitter, Version=4.0.4642.26986, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Jitter.dll
    Lameography, Version=4.0.5285.19635, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Lameography.dll
    Landscape, Version=4.5.6826.38591, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Landscape.dll
    LaplacianPyramidFilter, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LaplacianPyramidFilter.dll
    Layer Cake, Version=1.0.4911.8147, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Layer Cake.dll
    LensFlare, Version=2.2.12.35124, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LensFlare.dll
    LevelHorizon, Version=4.5.6826.37471, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LevelHorizon.dll
    Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\Microsoft.VisualBasic\v4.0_10.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll
    Lightning, Version=1.1.3896.32593, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Lightning.dll
    LightRays, Version=2.1.5.14276, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LightRays.dll
    Line Tracer, Version=1.0.4911.29141, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Line Tracer.dll
    Lines, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Lines.dll
    LinesGrid, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LinesGrid_en.dll
    Liquify, Version=4.0.5873.25113, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Liquify.dll
    LocalContrast, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LocalContrast.dll
    LookAtIt.Effect, Version=0.6.0.779, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\LookAtIt.Effect.dll
    MakeTransparent, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MakeTransparent.dll
    MandalaCreator, Version=1.2.6946.21792, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MandalaCreator.dll
    MathNet.Iridium, Version=2007.3.8.35795, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MathNet.Iridium.dll
    MemeMaker, Version=4.5.6828.38061, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MemeMaker.dll
    Metallize, Version=1.2.4415.32969, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Metallize.dll
    MosaicManiac, Version=1.0.906.8, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MosaicManiac.dll
    MultiColorGradient, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MultiColorGradient.dll
    MultiThreshold, Version=1.1.4330.38982, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\MultiThreshold.dll
    NeonEdges_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\NeonEdges_en.dll
    noisechoice, Version=1.0.4460.1271, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\noisechoice.dll
    NormalMapPlus, Version=1.4.6422.43071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\NormalMapPlus.dll
    Object Pruner, Version=1.0.7020.41772, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Object Pruner.dll
    Object2colour, Version=1.0.4661.28375, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Object2colour.dll
    ObjectBevel, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ObjectBevel.dll
    Objectedge, Version=1.0.4674.982, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Objectedge.dll
    ObjectFeather, Version=3.5.4315.35085, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ObjectFeather.dll
    ObjectTools, Version=4.5.6832.42044, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ObjectTools.dll
    Oblique, Version=1.2.5.15730, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Oblique.dll
    Offset Shadow, Version=1.0.4247.30184, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Offset Shadow.dll
    OffsetAlternatingStripes, Version=1.0.6025.41452, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\OffsetAlternatingStripes.dll
    OilPaintingPlus, Version=4.5.6832.21777, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\OilPaintingPlus.dll
    Feather, Version=2.3.4315.37038, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\OldFeather.dll
    Organigram, Version=1.1.6176.35283, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Organigram.dll
    Outline Object, Version=4.0.4642.26954, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Outline Object.dll
    OutlineObject, Version=1.1.3160.31739, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Outline.dll
    overblur, Version=1.0.4483.1623, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\overblur.dll
    PageCurl, Version=1.5.5.23162, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PageCurl.dll
    Paneling, Version=1.2.5.23448, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Paneling.dll
    ParallelLines.Effect, Version=1.6.0.575, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ParallelLines.Effect.dll
    Paste Warp Plus, Version=1.0.6244.33283, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Paste Warp Plus.dll
    PasteAlpha, Version=4.5.6826.36532, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PasteAlpha.dll
    PasteFromClipboard, Version=1.1.6346.2917, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PasteFromClipboard.dll
    Pastel, Version=4.5.6832.42132, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Pastel.dll
    Perspective, Version=2.1.4415.36116, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Perspective.dll
    PerspectiveTransformation, Version=1.2.5795.41799, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PerspectiveTransformation.dll
    phips_fill_gaps, Version=1.0.3307.18956, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\phips_fill_gaps.dll
    PhotoAdjustments, Version=4.5.6826.37237, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PhotoAdjustments.dll
    Pixelate+, Version=4.0.4642.26940, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Pixelate+.dll
    OptionBasedLibrary v0.7.9, Version=0.7.9.1561, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\OptionBasedLibrary v0.7.9.dll
    Planetoid, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Planetoid.dll
    PlugInData, Version=1.2.1.2, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PlugInData.dll
    PointBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PointBlur.dll
    pointwarp, Version=1.2.5709.42172, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PointWarpEffect.dll
    Polar, Version=1.2.5.24467, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Polar.dll
    Polygon, Version=4.5.6828.38648, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Polygon.dll
    PostageStamp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PostageStamp.dll
    Poster, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Poster.dll
    posterize+, Version=1.0.4629.2600, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\posterize+.dll
    PrintIt.Effect, Version=0.9.0.1162, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PrintIt.Effect.dll
    PSFilterPdn, Version=1.0.7.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\PSFilterPdn.dll
    pxEexpansion, Version=1.0.4437.36287, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\pxEexpansion.dll
    QuadrilateralCorrection, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\QuadrilateralCorrection.dll
    RadiusFillCorners, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RadiusFillCorners.dll
    rainball, Version=1.0.4907.41850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\rainball.dll
    Random Effect, Version=4.0.4642.26928, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Random Effect.dll
    Random Shape Fill, Version=4.0.4642.26910, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Random Shape Fill.dll
    recolourchoice, Version=1.0.4483.35063, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\recolourchoice.dll
    RedEyeQuickFix, Version=1.1.3161.39688, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RedEyeQuickFix.dll
    OptionBasedLibrary v0.7, Version=0.7.0.602, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\OptionBasedLibrary v0.7.dll
    RemoveDust, Version=4.5.6826.37862, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RemoveDust.dll
    RenderSphereHeightMap, Version=1.0.6145.37460, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RenderSphereHeightMap.dll
    ReverseFisheye, Version=1.0.5146.25956, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ReverseFisheye35.dll
    Rogers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Rogers.dll
    RotateText, Version=1.1.4415.32628, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RotateText.dll
    RotateTextSUI, Version=1.1.4415.32713, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RotateTextSUI.dll
    Rotate_Zoom+, Version=1.0.4438.19459, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Rotate_Zoom+.dll
    RoundedRect, Version=0.9.5994.26696, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RoundedRect.dll
    RubberStamp, Version=0.1.6301.38527, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\RubberStamp.dll
    Scintillate, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Scintillate.dll
    Scribble, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Scribble.dll
    ScriptLab, Version=4.0.6107.18914, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ScriptLab.dll
    SeamCarving, Version=4.5.6838.35770, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SeamCarving.dll
    SeamlessHelper, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SeamlessHelper.dll
    selection2clear, Version=1.0.4544.36371, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\selection2clear.dll
    SelectionTools, Version=4.5.6832.22117, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SelectionTools.dll
    ShadowEffect, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ShadowEffect.dll
    ShadowHighlight, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ShadowHighlight.dll
    Shape3D, Version=1.2.6.2, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Shape3D.dll
    shapegradient, Version=1.5.3886.6574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\shapegradient.dll
    Sharpen+, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Sharpen+.dll
    Signature, Version=1.5.6617.21474, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Signature.dll
    SinWaves, Version=1.2.5.30582, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SinWaves.dll
    SmartSharpen, Version=1.5.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SmartSharpen.dll
    Smudge, Version=4.0.5873.25097, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Smudge.dll
    Sparkle_Stars, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Sparkle_Stars.dll
    SpeechBubble, Version=2.1.4445.42029, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SpeechBubble.dll
    SpiralText, Version=1.4.4415.32775, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SpiralText.dll
    Splatter, Version=4.0.5873.25083, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Splatter.dll
    SplitHueAndBrightness, Version=1.0.5800.37276, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SplitHueAndBrightness.dll
    SpotCenter, Version=1.2.0.17265, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SpotCenter.dll
    squirkle, Version=1.0.4677.25184, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\squirkle.dll
    squirklewarp, Version=1.0.4677.26893, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\squirklewarp.dll
    StarGlow, Version=1.3.5.17930, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\StarGlow.dll
    SteganographyDecodeBW, Version=2.0.5303.25592, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SteganographyDecodeBW.dll
    SteganographyDecodeColor, Version=2.0.5303.25093, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SteganographyDecodeColor.dll
    SteganographyEncode, Version=3.0.5306.34590, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\SteganographyEncode.dll
    Stickman, Version=1.2.2.7733, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Stickman.dll
    Stitch, Version=4.0.4642.26808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Stitch.dll
    Temperature, Version=4.5.6832.41128, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Temperature.dll
    Tesserae, Version=1.0.6200.27517, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Tesserae.dll
    TextDistortion, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TextDistortion.dll
    Textplus, Version=1.0.4618.37123, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Textplus.dll
    TextPro, Version=1.0.3614.36023, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TextPro.dll
    Texture Object Rounder, Version=1.0.6464.41586, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Texture Object Rounder.dll
    TextureMerger, Version=1.0.6144.2153, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TextureMerger.dll
    TextureShader, Version=2.1.6276.42488, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TextureShader.dll
    TextureSmoother, Version=1.0.6096.31689, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TextureSmoother.dll
    Texturize, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Texturize.dll
    TGAngle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TGAngle.dll
    TGMagnitude, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TGMagnitude.dll
    ThermalHeatMapEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ThermalHeatMapEffect.dll
    Tiles, Version=1.2.5.13094, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Tiles.dll
    TileWorld, Version=1.0.0.25400, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TileWorld.dll
    TJacksonEffects, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TJacksonEffects.dll
    Toon Shader, Version=1.0.3470.28696, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Toon Shader.dll
    MyScript, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TOON.dll
    "TR's Pixel Push", Version=1.0.4954.37564, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TR's Pixel Push.dll
    Trail, Version=4.0.4642.26791, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Trail.dll
    trail3d, Version=1.0.3902.32071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\trail3d.dll
    Transparency, Version=4.5.6832.41213, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Transparency.dll
    trix400, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\trix400.dll
    TRs Scatter, Version=1.3.4949.23250, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRs Scatter.dll
    TRsAlphaCutter, Version=3.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsAlphaCutter.dll
    TRsCloudControl, Version=2.0.4968.34489, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsCloudControl.dll
    TRsColorReducer, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsColorReducer.dll
    TRsContourFiller, Version=1.5.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsContourFiller.dll
    TRsCustomRandomFill, Version=1.5.1.31287, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsCustomRandomFill.dll
    TRsDodgeBurn, Version=1.3.28.34621, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsDodgeBurn.dll
    TRsDodgeBurn.resources, Version=1.3.26.12436, Culture=zh-CN, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsDodgeBurn.resources.dll
    TRsDrumSkin, Version=1.4.5199.15427, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsDrumSkin.dll
    TRsFireWorks, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsFireWorks.dll
    TRsFreeWarp, Version=1.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsFreeWarp.dll
    TRsFuego, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsFuego.dll
    TRsGlassVignette, Version=1.1.5239.30797, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsGlassVignette.dll
    TRsIntensityWarp, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsIntensityWarp.dll
    TRsKeyFrame, Version=1.2.5693.38036, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsKeyFrame.dll
    TRsMonolithic, Version=1.0.5.26132, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsMonolithic.dll
    TRsPanoPDN, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsPanoPDN.dll
    TRsPasteFrame, Version=1.3.20.9613, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsPasteFrame.dll
    TRsPasteWarp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsPasteWarp.dll
    TRsPixelPuller, Version=1.1.4994.29625, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsPixelPuller.dll
    TRsPixelSharp, Version=2.0.5467.31590, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsPixelSharp.dll
    TRsPSnap, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsPSnap.dll
    TRsQuickOutline, Version=1.5.5713.19293, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsQuickOutline.dll
    TRsRadialExtruder, Version=1.2.5609.8244, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsRadialExtruder.dll
    TRsRetouch, Version=1.0.5684.16160, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsRetouch.dll
    TRsSmudger, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsSmudger.dll
    TRsSplineMaster, Version=1.4.2.18310, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsSplineMaster.dll
    TRsStarFilter, Version=1.0.4930.9612, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsStarFilter.dll
    TRsStr8Edge, Version=1.1.5045.31905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsStr8Edge.dll
    TRsStrobeMotion, Version=1.2.4962.30523, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsStrobeMotion.dll
    TRsThirdDimension, Version=1.7.13.38717, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsThirdDimension.dll
    TRsTiltShift, Version=1.0.4957.12341, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsTiltShift.dll
    TRsTreeMaker, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsTreeMaker.dll
    TRsZigZag, Version=1.1.4929.6773, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TRsZigZag.dll
    Tweakedges, Version=1.0.4252.39711, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Tweakedges.dll
    Tweaktrans2, Version=2.0.4252.27152, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Tweaktrans2.dll
    Twist, Version=4.0.5873.25056, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Twist.dll
    TwoPointPerspective, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\TwoPointPerspective.dll
    Vandermotten.PaintDotNetEffects.Blurs, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll
    Vandermotten.PaintDotNetEffects, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.dll
    Vandermotten.PaintDotNetEffects.DropShadow, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll
    Vandermotten.PaintDotNetEffects.FadeEdge, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll
    Vandermotten.PaintDotNetEffects.Gradient, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll
    Vandermotten.PaintDotNetEffects.Grid, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Grid.dll
    Vandermotten.PaintDotNetEffects.ObjectAlign, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll
    VanishPoint, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\VanishPoint.dll
    ViewFramer, Version=1.1.5711.29834, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ViewFramer.dll
    VignettePlus, Version=4.5.6826.39332, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\VignettePlus.dll
    WaterReflection, Version=1.2.5.15754, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WaterReflection.dll
    WaveText, Version=1.2.4415.32811, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WaveText.dll
    WaveTextSUI, Version=1.2.4415.33440, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WaveTextSUI.dll
    WhichSymbolRedux, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WhichSymbolRedux.dll
    WoodsyVP1, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WoodsyVP1.dll
    WoodsyVP2, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WoodsyVP2.dll
    WoodsyVP3, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\WoodsyVP3.dll
    Zoom Blur Deluxe, Version=1.1.5709.42909, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\ZoomBlurDeluxe.dll
Native modules:
    C:\Program Files\paint.net\PaintDotNet.exe, version=4.106.7016.38074
    C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\MSCOREE.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\KERNEL32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\msvcrt.dll, version=7.0.17763.475 (WinBuild.160101.0800)
    C:\WINDOWS\System32\sechost.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\RPCRT4.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.7.3190.0 built by: NET472REL1LAST_C
    C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\combase.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\ucrtbase.dll, version=10.0.17763.404 (WinBuild.160101.0800)
    C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\GDI32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\gdi32full.dll, version=10.0.17763.475 (WinBuild.160101.0800)
    C:\WINDOWS\System32\msvcp_win.dll, version=10.0.17763.348 (WinBuild.160101.0800)
    C:\WINDOWS\System32\USER32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\win32u.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\IMM32.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\kernel.appcore.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.7.3362.0 built by: NET472REL1LAST_C
    C:\WINDOWS\SYSTEM32\MSVCR120_CLR0400.dll, version=12.00.52519.0 built by: VSWINSERVICING
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\mscorlib\e2c5db271896923f5450a77229fb2077\mscorlib.ni.dll, version=4.7.3362.0 built by: NET472REL1LAST_C
    C:\WINDOWS\System32\ole32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\uxtheme.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System\1eca7c432f5a4a5565d7baf771596696\System.ni.dll, version=4.7.3362.0 built by: NET472REL1LAST_C
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Core\7f6e28abc06e0862235287813c887df1\System.Core.ni.dll, version=4.7.3362.0 built by: NET472REL1LAST_C
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\WindowsBase\b2697d31e18ca5e2b664e7413dd7f134\WindowsBase.ni.dll, version=4.7.3362.0 built by: NET472REL1LAST_C
    C:\WINDOWS\System32\CRYPTSP.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\rsaenh.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\bcrypt.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Drawing\83b20ab828331685d1c2e7444bdc3e82\System.Drawing.ni.dll, version=4.7.3190.0 built by: NET472REL1LAST_C
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PresentationCore\3388f19e4865fa72b3e4fd23bbcdd194\PresentationCore.ni.dll, version=4.7.3362.0 built by: NET472REL1LAST_C
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\82b21b8e0f6279daa67f1245814e253a\PresentationFramework.ni.dll, version=4.7.3362.0
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\9f8a6a46daeaebc067b7d87922f2b95c\PaintDotNet.Base.ni.dll, version=4.106.7016.38074
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\ac650f25c169d12a3b25602013e92861\System.Windows.Forms.ni.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\5ca7e45431c8148161a851ed88b5642c\PaintDotNet.SystemLayer.ni.dll, version=4.106.7016.38074
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\8cc810235f842020e97b4b7d213bd345\PaintDotNet.Core.ni.dll, version=4.106.7016.38074
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\cfdc1915b6bca9f432a220482b34fc32\PaintDotNet.Resources.ni.dll, version=4.106.7016.38074
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\e689a220714243a6f180d3ba2e66e717\PaintDotNet.Framework.ni.dll, version=4.106.7016.38074
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\24a88d845b090418965100a576485653\PaintDotNet.Data.ni.dll, version=4.106.7016.38074
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\6d70452657c136fcd505e6e455a931c4\PaintDotNet.Effects.ni.dll, version=4.106.7016.38074
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet\c19f0164b701deea90220b9df765d049\PaintDotNet.ni.exe, version=4.106.7016.38074
    C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.7.3362.0 built by: NET472REL1LAST_C
    C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.17763.437 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\MSVCP120_CLR0400.dll, version=12.00.52519.0 built by: VSWINSERVICING
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.7.3362.0 built by: NET472REL1LAST_C
    C:\WINDOWS\System32\shell32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\shcore.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\windows.storage.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\profapi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\powrprof.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Program Files\paint.net\SxS\X64\vcruntime140.dll, version=14.16.27012.6 built by: vcwrkspc
    C:\Program Files\paint.net\SxS\X64\msvcp140.dll, version=14.16.27012.6 built by: vcwrkspc
    C:\Program Files\paint.net\SxS\X64\msvcp140_1.dll, version=14.16.27012.6 built by: vcwrkspc
    C:\Program Files\paint.net\SxS\X64\msvcp140_2.dll, version=14.16.27012.6 built by: vcwrkspc
    C:\Program Files\paint.net\SxS\X64\vcomp140.dll, version=14.16.27012.6 built by: vcwrkspc
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Configuration\6019398a305b7ef3cd3b612919794068\System.Configuration.ni.dll, version=4.7.3324.0 built by: NET472REL1LAST_C
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml\d46ad585cca07bf7e962625b048f54c0\System.Xml.ni.dll, version=4.7.3190.0 built by: NET472REL1LAST_C
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.7.3362.0 built by: NET472REL1LAST_C
    C:\WINDOWS\System32\MSCTF.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\OskSupport.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\96dd848e2ea5e2abe1d86a14012906e6\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.106.7016.38074
    C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll, version=4.106.7016.38074
    C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.17763.475_none_369f2f8b61b2a63a\gdiplus.dll, version=10.0.17763.475 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\dwmapi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\CRYPT32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\MSASN1.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    C:\WINDOWS\System32\UIAnimation.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.17763.475_none_05b43ca607202c6c\comctl32.dll, version=6.10 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.17763.55 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Runtea61dfd5#\92783308a5314dbd083fdfd3afc23f3b\System.Runtime.CompilerServices.Unsafe.ni.dll, version=
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xaml\8aeda6440f378ea86bc49360ea59468f\System.Xaml.ni.dll, version=4.7.3362.0 built by: NET472REL1LAST_C
    C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Runtime\3c2e51bd92d96b055e6b8f21a9ea7bf1\System.Runtime.ni.dll, version=4.7.3190.0
    C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.17763.348 (WinBuild.160101.0800)
    C:\WINDOWS\system32\dataexchange.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\dcomp.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\system32\RMCLIENT.dll, version=10.0.17763.194 (WinBuild.160101.0800)
    C:\WINDOWS\System32\TextInputFramework.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.17763.1
    C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.17763.194
    C:\WINDOWS\SYSTEM32\wintypes.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Accessibility\7ab91f7040565ea35e3bf50aff09175e\Accessibility.ni.dll, version=4.7.3190.0 built by: NET472REL1LAST_C
    C:\WINDOWS\SYSTEM32\oleacc.dll, version=7.2.17763.1 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=14.7.3190.0 built by: NET472REL1LAST_C
    C:\WINDOWS\SYSTEM32\winmm.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\winmmbase.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_bfe69934a6b764ef\nvldumdx.dll, version=26.21.14.3064
    C:\WINDOWS\System32\WINTRUST.DLL, version=10.0.17763.348 (WinBuild.160101.0800)
    C:\WINDOWS\System32\imagehlp.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_bfe69934a6b764ef\nvwgf2umx.dll, version=26.21.14.3064
    C:\WINDOWS\system32\nvspcap64.dll, version=3.18.0.102
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Design\9fd40b4f37d0a12e1f8f0965446d3cff\System.Design.ni.dll, version=4.7.3190.0 built by: NET472REL1LAST_C
    C:\WINDOWS\system32\explorerframe.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\OneCoreCommonProxyStub.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\uiautomationcore.dll, version=7.2.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\Bcp47Langs.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Microsoft.V9921e851#\4d63e7cb20b86d9b143f87431781674e\Microsoft.VisualBasic.ni.dll, version=14.7.3190.0 built by: NET472REL1LAST_C
    C:\WINDOWS\SYSTEM32\edputil.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.17763.439 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\urlmon.dll, version=11.00.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\iertutil.dll, version=11.00.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\SspiCli.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\smartscreenps.dll, version=10.0.17763.348 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\policymanager.dll, version=10.0.17763.475 (WinBuild.160101.0800)
    C:\Windows\System32\msvcp110_win.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\shdocvw.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\comsvcs.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    C:\Windows\System32\ieproxy.dll, version=11.00.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\CLDAPI.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\FLTLIB.DLL, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\appresolver.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\USERENV.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\SLC.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\Windows\System32\sppc.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\SetupApi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.17763.1 (WinBuild.160101.0800)
    C:\WINDOWS\System32\psapi.dll, version=10.0.17763.1 (WinBuild.160101.0800)
Share this post
Link to post
None! I just opened the plugin. It crashed PDN but opened the plugin. Although I couldn't do anything with the plugin. Weird!
Share this post
Link to post
I was trying to install the plugin and PDN didn't like it. It crashed out PDN and left the plugin open but I couldn't do anything with it.
Share this post
Link to post
@Woodsy
The crash indicates that Paint.NET is not receiving the data the G'MIC plugin is sending, but I am not able to reproduce it.
The only suggestion I have is to try reinstalling the plugin.
Share this post
Link to post
I have Gmic loaded to paint.net, except it is the previous version 2.6.1.
2.6.2 is not loading for some reason and paint.net just updated to version 4.1.7. I have placed the gmic.dll and the gmic folder in the Effects PDN folder. I am using Windows 10 64Bit.
Share this post
Link to post
