TheModder32412 Posted October 6, 2018 Share Posted October 6, 2018 While installing paint.net which I haven't had a problem with ever sense I got it but lately there was a problem where when I went to add text to any picture I had opened in the software it would crash. I tried re-installing paint.net but every time after a few seconds of loading it pop ups with a prompt saying "There was an error while installing paint.net. (1603)" with a box that said "Fatal error during installation." I've re-installing the program several times but with the same outcome every time Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 6, 2018 Share Posted October 6, 2018 Your paint.net installation has became broken. You can use this utility to remove the broken installation: https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed Afterwards, you can install paint.net anew. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
TheModder32412 Posted October 7, 2018 Author Share Posted October 7, 2018 Thank you so so so much bro Quote Link to comment Share on other sites More sharing options...
