Meenie50 Posted September 23, 2018 Share Posted September 23, 2018 I'm fairly new to Paint.net, so that may be part of the problem, lol. But here's what's happening: I'm trying to create an ebook cover. I have several layers. I want to put a glow around my text. And this is where I''m running into trouble. I unselected all the layers except two with text. I'm trying to re-color using the recolor tool. But everytime I drag the circle over the text, it affects the background layer by drawing a path of that color on it. The background layer is NOT CHECKED. i.e. not selected. But it's drawing on it as if it is. How can I make it stop? I'm assuming there's some function I'm missing but I sure can't find it. Thanks for helping, If you can. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted September 23, 2018 Share Posted September 23, 2018 Operations affect the selected Layer. Whether it's checked or not is irrelevant. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
SodiumEnglish Posted September 23, 2018 Share Posted September 23, 2018 You may be confused as to the active layer and what the checkbox means. The checkboxes will turn rendered layers on and off and does not affect whether you can draw in them or not. The currently selected layer (highlighted in blue) is the layer that you are currently interacting with, draw on, etc. regardless of whether the check is selected or not. 2 Quote Link to comment Share on other sites More sharing options...
Pixey Posted September 24, 2018 Share Posted September 24, 2018 Hello @Meenie50 I'm not sure if you mean the Background of the text layer, or the Background of the layers windows. In case it's the former, it may be you are not 'selecting' the text correctly. Also, you don't really need the Re-color Tool for the Glow. Here is a quick video of how you can do it another way. 1 Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Meenie50 Posted September 24, 2018 Author Share Posted September 24, 2018 22 hours ago, SodiumEnglish said: BINGO!! I didn't know to look for a highlight! I thought the checkmark was what designated the layer that was being worked on. THANK you!!! You may be confused as to the active layer and what the checkbox means. The checkboxes will turn rendered layers on and off and does not affect whether you can draw in them or not. The currently selected layer (highlighted in blue) is the layer that you are currently interacting with, draw on, etc. regardless of whether the check is selected or not. Quote Link to comment Share on other sites More sharing options...
Meenie50 Posted September 24, 2018 Author Share Posted September 24, 2018 (edited) 17 hours ago, Pixey said: Thanks, @Pixey! By background, I'm referring to the layer that my background color is on. And what they said above was correct, I didn't realize I had to look for a highlighted layer, lol. Just thought when you unchecked a layer, it was out of the equation for the time being. Does this video have sound? I can't hear anything. Maybe I can slow it down so I can follow the bouncing cursor, lol. Hello @Meenie50 I'm not sure if you mean the Background of the text layer, or the Background of the layers windows. In case it's the former, it may be you are not 'selecting' the text correctly. Also, you don't really need the Re-color Tool for the Glow. Here is a quick video of how you can do it another way. Edited September 25, 2018 by Meenie50 left out the @ sign :) Quote Link to comment Share on other sites More sharing options...
Pixey Posted September 25, 2018 Share Posted September 25, 2018 @Meenie50 - sorry, no I didn't speak in the video. Hope you can follow via the mouse Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
