FreshYTX Posted September 2, 2018 Share Posted September 2, 2018 Yup, same as the title goes... example of something is like this But I also want to control the angle. Quote Link to comment Share on other sites More sharing options...
TrevorOutlaw Posted September 2, 2018 Share Posted September 2, 2018 Be warned, though, it is a very slow plugin. 1 Quote Paint.NET Gallery | Remove Foreground Object Tutorial | Dispersion Effect Tutorial Link to comment Share on other sites More sharing options...
TrevorOutlaw Posted September 3, 2018 Share Posted September 3, 2018 (edited) 17 hours ago, FreshYTX said: Yup, same as the title goes... example of something is like this But I also want to control the angle. You can also achieve this effect WITHOUT the use of plugin. Below are the steps: Duplicate the original photograph. On the duplicated layer, run Gaussian Blur, keep the blur radius at a very minimum, less than 10. While still on the duplicated layer, use the gradient tool set to linear (reflected), and set to transparency mode. Below is an example of what you can achieve following the steps above (clickable to see it bigger). Original image. Edit: Here is another photograph, manipulated with tilt shift technique, utilizing the steps above, and using reflected linear transparent gradient from the bottom right to middle of the photograph. The only limitation is your imagination. Edited September 3, 2018 by TrevorOutlaw 1 Quote Paint.NET Gallery | Remove Foreground Object Tutorial | Dispersion Effect Tutorial Link to comment Share on other sites More sharing options...
lynxster4 Posted September 3, 2018 Share Posted September 3, 2018 Excellent outcomes @TrevorOutlaw without using the plugin! ? We had a Tilt Shift comp not too long ago...you should have entered! Quote My Art Gallery | My Shape Packs | ShapeMaker Mini Tut | Air Bubble Stained Glass Chrome Text with Reflections | Porcelain Text w/ Variegated Coloring | Realistic Knit PatternOpalescent Stained Glass | Frosted Snowman Cookie | Leather Texture | Plastic Text | Silk Embroidery Visit my Personal Website "Never, ever lose your sense of humor - you'll live longer" Link to comment Share on other sites More sharing options...
FreshYTX Posted September 3, 2018 Author Share Posted September 3, 2018 12 hours ago, welshblue said: I use pyrochilds Film. With some playing you get good results and it's quicker than the above under what like topic is it in? (Render, Object, etc) Quote Link to comment Share on other sites More sharing options...
FreshYTX Posted September 3, 2018 Author Share Posted September 3, 2018 Im looking for a plugin guys Quote Link to comment Share on other sites More sharing options...
