vvx Posted August 31, 2018 Share Posted August 31, 2018 (edited) Please make improvement to brush and pen! When using a brush/pen i want press ALT to switch to colorpicker! when alt released - return to brush or pen with picked color I often adjust images with brush and there are many regions to adjust with nearer pixel's color switching by clicking on a toolbox is terrible Edited August 31, 2018 by vvx Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 31, 2018 Share Posted August 31, 2018 Color pickers shortcut is K. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
MJW Posted August 31, 2018 Share Posted August 31, 2018 Also, in the tool settings for the Color Picker you can specify that it will switch back to the previous tool after you pick a color. So with that option selected, you can be using the brush, hit "K" to pick a color, and it will automatically switch back to the brush after the pick. The setting can be specified in the Options window, so it's the default. 1 Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted August 31, 2018 Share Posted August 31, 2018 Take a look at the other Keyboard Shortcuts too: https://www.getpaint.net/doc/latest/KeyboardMouseCommands.html 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
vvx Posted September 30, 2018 Author Share Posted September 30, 2018 (edited) Quote Also, in the tool settings for the Color Picker you can specify that it will switch back to the previous tool after you pick a color. So with that option selected, you can be using the brush, hit "K" to pick a color, and it will automatically switch back to the brush after the pick. The setting can be specified in the Options window, so it's the default. it's not really easy and handy to press more than 1 keys, one of which (K) placed on the other side (right side) of keyboard i mean it Edited October 1, 2018 by vvx Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 30, 2018 Share Posted September 30, 2018 Example? On a standard PC keyboards there are Shift, Ctrl + Alt keys on both sides of the keyboard. If you haven't got one you should consider it. They are cheap. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
vvx Posted October 1, 2018 Author Share Posted October 1, 2018 (edited) On 8/31/2018 at 10:44 PM, MJW said: 15 hours ago, Ego Eram Reputo said: Example? On a standard PC keyboards there are Shift, Ctrl + Alt keys on both sides of the keyboard. If you haven't got one you should consider it. They are cheap. you didn't get my prev message Edited October 1, 2018 by vvx Quote Link to comment Share on other sites More sharing options...
