vinny_the_hack Posted August 26, 2018 Share Posted August 26, 2018 Example: I want to change the face tone to white, as a clown or mime, but when I dump white on the face, it completely obliterates the face contrours, lines, etc. Is there a simple way to add/change colour while maintaining fine lines and "texture"? Thanks for any help you can offer. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 26, 2018 Share Posted August 26, 2018 1. Set the Primary color to White 2. use the Color Picker tool to set the Secondary color to a shade used in the face. (tip: right click with the CP tool). 3. Select the Recolor tool 4. Set the Sample Secondary option in the tool bar 5. Set the Brush width to something large & paint over the face 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
vinny_the_hack Posted August 26, 2018 Author Share Posted August 26, 2018 Thank-you so much! Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 26, 2018 Share Posted August 26, 2018 Good luck Vinny. I recently saw this technique posted by @dipstick, it might be worth a trial too. On 8/20/2018 at 11:40 AM, dipstick said: There is an alternative way to dodge/burn in order to darken or lighten parts of an image. 1) Add a blank layer above background layer and set Blending Mode to "Overlay". 2) Use the brush to paint on the overlay layer. Black to darken and White to lighten. 3) Adjust opacity to suit... Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
vinny_the_hack Posted September 25, 2018 Author Share Posted September 25, 2018 Ego, I had used such a technique with limited success. Your first suggestion works for me. Thanks, again. Quote Link to comment Share on other sites More sharing options...
