Rick Brewster 1,453 Report post Posted August 28, 2018 "old" in this case was mostly about the drivers Glad it's working! Share this post Link to post Share on other sites
mottoman 279 Report post Posted August 28, 2018 26 minutes ago, Rick Brewster said: "old" in this case was mostly about the drivers Glad it's working! Once again, thanks for diagnosing the diagnostics, I should remind myself to check for updates driver wise every now and then. I always assume windows update handles everything and of course that's not the case. Share this post Link to post Share on other sites
skyoxZ 0 Report post Posted August 29, 2018 (edited) On 8/24/2018 at 8:24 AM, Rick Brewster said: Please note that some of the updates to the translations were done via machine translation, and are not very good. If you'd like to help improve them, head over to https://forums.getpaint.net/topic/27847-official-translations-for-40-via-crowdinnet/ and make a post with your crowdin.net user name and which language you'd like to contribute to. It would be great if there's a filter for me to find all approved 0-vote translations not translated by me. Any suggestion? ps: Sorry for downvoting your translations. I was trying using "Need to be voted" filter, but it seems not practical. Edited August 29, 2018 by skyoxZ Share this post Link to post Share on other sites
Rick Brewster 1,453 Report post Posted August 29, 2018 @skyoxZ, I don't think there's a way to filter or sort in that way. I have mostly been just sorting descending by changed date, which gives me all strings that have changed most recently. Share this post Link to post Share on other sites
skyoxZ 0 Report post Posted August 29, 2018 @Rick Brewster Thank you. I made some mistakes. Please recheck all strings in top 2 pages of Chinese Simplified Translations with that Date Changed filter. Share this post Link to post Share on other sites
AndrewDavid 625 Report post Posted August 31, 2018 @Rick Brewster Thank you for the new and improved version @toe_head2001 Thank you for the wheel scroll ability through the large menus. (I consider it an early birthday present) With over 600 plugins installed this is the only one that is showing an error in your tools menu. Pretty sure it was not there prior to the Beta so I will post here instead of the plugin thread. With only 8 MB of memory in my machine I am amazed at how stable the new version is responding to my crazy drawing techniques. Share this post Link to post Share on other sites
alexo 1 Report post Posted September 3, 2018 Immediate crash when clicking on the "Image" dropdown menu. Crash log attached. Reverted to 4.0.21 pdncrash.4.log Share this post Link to post Share on other sites
toe_head2001 1,458 Report post Posted September 3, 2018 6 minutes ago, alexo said: CAR.Paint.NET, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\Effects\CAR.Paint.NET.dll You need to remove that plugin. @Rick Brewster, it should be blacklisted in paint.net. https://forums.getpaint.net/topic/29492-content-aware-resize-aka-seam-carving/ 1 Share this post Link to post Share on other sites
alexo 1 Report post Posted September 3, 2018 11 minutes ago, toe_head2001 said: You need to remove that plugin. @Rick Brewster, it should be blacklisted in paint.net. https://forums.getpaint.net/topic/29492-content-aware-resize-aka-seam-carving/ Thanks, that fixed it. Share this post Link to post Share on other sites
TrevorOutlaw 254 Report post Posted September 3, 2018 Kudos, Rick. I was just reading through the Roadmap, and it is amazing how far PDN came from being an undergraduate senior design project into what it is today. Share this post Link to post Share on other sites
Rick Brewster 1,453 Report post Posted September 4, 2018 On 9/2/2018 at 10:50 PM, toe_head2001 said: You need to remove that plugin. @Rick Brewster, it should be blacklisted in paint.net. https://forums.getpaint.net/topic/29492-content-aware-resize-aka-seam-carving/ Thanks for pointing this out -- yup, I'll have to blacklist it. Would be nice to have an improved plugin model for it to use. Share this post Link to post Share on other sites
Rick Brewster 1,453 Report post Posted September 4, 2018 On 8/30/2018 at 6:17 PM, AndrewDavid said: @Rick Brewster Thank you for the new and improved version @toe_head2001 Thank you for the wheel scroll ability through the large menus. (I consider it an early birthday present) With over 600 plugins installed this is the only one that is showing an error in your tools menu. Pretty sure it was not there prior to the Beta so I will post here instead of the plugin thread. With only 8 MB of memory in my machine I am amazed at how stable the new version is responding to my crazy drawing techniques. The Argus FFT plugin is going to need to be updated. It's using the PointInt32 struct which I've renamed to Point2Int32. I'll be moving it around some more in a post-4.1 update as well. Share this post Link to post Share on other sites
Rick Brewster 1,453 Report post Posted September 5, 2018 Locking this -- I'm publishing the final release soon Share this post Link to post Share on other sites
