unspell Posted June 24, 2018 Share Posted June 24, 2018 I can't use paint.net, whenever i try to repair it, it says its unavailable. When i try to uninstall it, it also doesn't let me. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted June 24, 2018 Share Posted June 24, 2018 Somehow your paint.net installation became broken. You can use this utility to remove the broken installation: https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed Afterwards, you can install paint.net anew. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
unspell Posted June 24, 2018 Author Share Posted June 24, 2018 I got it to uninstall but when i try to reinstall it, it doesn't appear in control panel or anywhere else Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 24, 2018 Share Posted June 24, 2018 Classic or Windows Store version? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
toe_head2001 Posted June 25, 2018 Share Posted June 25, 2018 9 hours ago, unspell said: but when i try to reinstall it, it doesn't appear in control panel or anywhere else Ok, so are you're saying the installation process didn't complete, or what? Please provide us with some details. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
unspell Posted August 12, 2018 Author Share Posted August 12, 2018 It doesn't let me complete the installation process Quote Link to comment Share on other sites More sharing options...
Pixey Posted August 12, 2018 Share Posted August 12, 2018 On 6/24/2018 at 6:08 PM, Ego Eram Reputo said: Classic or Windows Store version? Please answer the above question. Do you have the Store bought version, or ... the Classic? (Classic means the non-store bought) Have you tried this - downloading Framework 7.2 ? https://www.microsoft.com/net/download/thank-you/net472 Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
unspell Posted August 13, 2018 Author Share Posted August 13, 2018 6 hours ago, Pixey said: Please answer the above question. Do you have the Store bought version, or ... the Classic? (Classic means the non-store bought) Have you tried this - downloading Framework 7.2 ? https://www.microsoft.com/net/download/thank-you/net472 classic version, it doesn't let me download the framework. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted August 13, 2018 Share Posted August 13, 2018 7 hours ago, unspell said: It doesn't let me complete the installation process What stops it? What does it say? 13 minutes ago, unspell said: it doesn't let me download the framework. Again, what stops it? Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
unspell Posted August 13, 2018 Author Share Posted August 13, 2018 "The .NET framework 4.7.2 is not supported on this operating system" Quote Link to comment Share on other sites More sharing options...
Pixey Posted August 13, 2018 Share Posted August 13, 2018 Which operating system are you using? Also, please check that all of your Windows updates are up-to-date. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
