Force saving in the same bit depth and compression as source
I'm having a problem with paint.net and I'm not seeing any way to solve it. I am outputting TIF images (single page) in 1-bit using CCITT T.6 compression from another program. Occasionally, I will need to bring them into paint.net for some hand clean-up work. When I edit them and then save the image, it is not maintaining 1-bit mode and using LZW compression. This becomes a problem when I compile these images into a PDF because Chrome and other browser render these saved images poorly.
Here's a comparison of two files--the first has been edited and saved by paint.net while the second has not.
image.png.2746ca208a8fe3234e5ff82daa4c4a62.pngimage.png.6f65ebb67c141ff6d258d8394199dee7.png
How can I make the program save the resulting image in the same bit depth (and, optionally, compression) as the source image? The only editing I'm doing is filling a selection with white (to remove inking artifacts). Any help is greatly appreciated here.
EDIT: I have found and applied the LowColor plug-in from here (https://forums.getpaint.net/topic/15317-low-color-filetype-bmp-gif-png-tiff-20091204/) but this seems to require a manual process to "save as" a new type. All I'm looking to do is make edits to the file in situ with the source colorspace and compression. Since I have hundreds to process at a given time, I simply want to select an area, fill with white, press save and move on.
Edited by ChipZ
Added acknowledgement of LowColor plug-in.
Unfortunately Paint.NET only has bare minimal TIFF support. There is no way to choose a bit-depth when saving, and it hasn't been a priority to add that because TIFF just isn't used very much. For now I'd recommend finding a separate utility that can re-compress the image with the parameters you need.
Thanks for the response, @Rick Brewster. I realize you may not know (or care to know), but any chance you can recommend an image editor other than a high priced one that can do what I'm after? Again, my needs are very very simple: Edit 1-bit images to remove inking artifacts and stamps, save the file in 1-bit mode.
Irfanview
1708244082_Image085.png.4dd24bcfd5059fdb2b76bdd5149401da.png144082232_Image084.png.c7e5ac555dbfe8f270c6e4284b0eea74.png
It has a basic paint functions and that CCITT Fax 4 comes up as CCITT T.6 in file properties.
It even has a batch processor that is extremely comprehensive.
Thank you for the reminder. Irfanview is a great program, but it doesn't give you the ability to do (some) simple editing tasks like what I'm after (select area, remove black/fill with white). The save and convert portion works fine, and I suppose I could use two apps instead of one, it just slows the process down.
