Carrito Posted May 11, 2018 Share Posted May 11, 2018 I would a template divided in four parts . Din A4 divided in four parts. 1 | 2 | ------------- 3 | 4 | And when printed margin obtain margin zero. Print all the size of the din a4. that's my idea how can I obtain the adequate canvas for this target ? Best Regards Quote Ingenieros TenerifePeritos Tenerife Link to comment Share on other sites More sharing options...
Eli Posted May 11, 2018 Share Posted May 11, 2018 (edited) Do you have a printer that prints all the way to the bords (margin zero)? You may want to try Xod's Guidelines... Edited May 11, 2018 by Eli Quote Link to comment Share on other sites More sharing options...
Carrito Posted May 13, 2018 Author Share Posted May 13, 2018 I go to the copy shop. Probably not to the margin. Do you have a template ? Quote Ingenieros TenerifePeritos Tenerife Link to comment Share on other sites More sharing options...
Eli Posted May 13, 2018 Share Posted May 13, 2018 It is best to ask the copy shop for their specifications. You can then make a template with the information provided by the copy shop. Quote Link to comment Share on other sites More sharing options...
