null54
Content Aware Fill (2018-10-4)
A problem that iy have with this plugin is that it immediately starts working when I change the settings, even if I am not done changing them, and then I have to wait a long time for it to finish only to update the settings again.
It would be better to have an "apply" button.
Share this post
Link to post
Perhaps the algorithm affords a "draft quality" setting? (I'm not familiar with the algorithm though...)
Similar to how some of the other effects have a Quality slider.
Share this post
Link to post
The effect renders automatically because that is the expected behavior for all Paint.NET effects that do not show their own drawing surface.
If I were to add an apply button it would be controlled by a checkbox that disables the automatic rendering.
I could try to adjust the number of refinement passes and random points the algorithm will try when searching for matches.
Currently the algorithm uses 6 refinement passes and will try up to 500 random points if it does not find a match in the 16 neighboring points.
Unfortunately this algorithm only supports sequential processing of the image data, so it cannot use Paint.NET's multi-threaded rendering.
Share this post
Link to post
Sprinkle these throughout the algorithm?
Share this post
Link to post
That is what the plugin does when it is run as a repeat effect (in OnSetRenderInfo).
Because Paint.NET does not allow Effect plugins to report their own progress, the effect dialog uses a BackgroundWorker for rendering to allow its progress bar to be updated.
Currently the effect dialog does not tell the BackgroundWorker to abort and restart when the settings change, it only aborts the BackgroundWorker when the user cancels the dialog.
Share this post
Link to post
The problem is that if I want to move the slider from the default 50 to say 12, the process starts as soon as I start moving the slider, before it reaches the mark.  Then I have to wait for it to finish (can take 20 second's or so),  then try to trigger it again, which is problem when the slider is already in the correct position, so I end up running it twice more.  It is an unnecessary inconvenience.
Share this post
Link to post
Try this instead...
https://forums.getpaint.net/topic/112378-plugin-development-nuggets-of-wisdom-i-learned/?do=findComment&comment=542006
Share this post
Link to post
2 hours ago, BoltBait said:
Try this instead...
Rendering in OnSetRenderInfo would break the progress reporting for the plugin.
Share this post
Link to post
Well, I'm out of ideas on how to make your UI more responsive. :(
Share this post
Link to post
You should be able to give the BackgroundWorker access to your Effect.IsCancelRequested. And then just stop what you're doing -- either return or `throw OperationCanceledException` (and catch it in an appropriate place).
Share this post
Link to post
The IsCancelRequested property would not help as I render to a temporary surface, and only call FinishTokenUpdate when the BackgroundWorker completes.
Share this post
Link to post
That sounds like the wrong way to architect this then. Rendering should happen in response to OnRender(). Even rendering in OnSetRenderInfo() isn't the right way to do things anymore now that IsCancelRequested exists.
Share this post
Link to post
Unfortunately not all algorithms are compatible with the chunked rendering used by OnRender.
The algorithm used by this plugin performs multi-pass rendering on the selected area.
After some experimentation I determined that rendering in OnSetRenderInfo and adding an event to the effect class that allows the config dialog to receive the rendering progress appears to be the best approach to fixing the UI responsiveness.
This allows Paint.NET to handle the restarting the effect when the token changes while still allowing the dialog to display the rendering progress.
Share this post
Link to post
IsCancelRequested currently works in OnSetRnderInfo, and at least originally was intended to be pollable from within OnSetRenderInfo:
On 12/28/2009 at 11:54 PM, Rick Brewster said:
.NET threads will correspond to Win32 threads. The abstraction between "managed thread ID" and "native thread ID" mapping does exist, but it only matters if you are doing custom .NET hosting, e.g. SQL Server. Also, .NET is not a virtual machine or environment, so you are doing yourself a disservice by thinking that way.
As a corollary, in Paint.NET you can be sure that a managed thread will not be "migrated" among native threads, or processes. Fibers are never used anywhere.
And you're right that Paint.NET has a lot of "ambitious ambiguity" in the contract. However, at this point (5 years later) it's safe to say:
1) OnSetRenderInfo() will always be called first, and always by itself.
2) OnRender() will be called next. The first ROI is always executed by itself. After that, parallelism ensues.
Also, the token that is given to the effect is a Clone() of the one from the effect config dialog. From there, each thread used for OnRender() has its own Clone() of the token.
So, there is some "bracketing" that takes place. You can be assured that calls to OnSetRenderInfo() and OnRender() will never overlap when drawn on a timeline.
Also, in v3.5.2 I am adding an IsCancelRequested property that you can poll from within OnSetRenderInfo() or OnRender(). The guarantee at that point is that when IsCancelRequested flips to true that any "in-flight" OnRender() calls will be discarded.
In a future version, I plan to redo the effect system to provide more control over execution and progress reporting type stuff. Basically you'll be given an object to report progress through, and a simple ReadPixels() / WritePixels() interface. From there, additional classes will be provided which will take care of chunking of ROIs, parallelism, etc. But at that point those things will be optional -- great for multipass effects, and also great for effects where a different ROI "chunking" strategy is preferred.
I certainly hope it will always work in OnSetRenderInfo.  As null54 points out, there are many very useful algorithms that require the entire canvas be processed at once, not in randomly-ordered pieces.
Share this post
Link to post
I don't remember if IsCancelRequested works during OnSetRenderInfo. If it does, then everything's fine. Otherwise you won't be able to cancel out of your rendering until the first OnRender() call, which will be too late to maintain a good user experience.
Share this post
Link to post
IsCancelRequested works in OnSetRenderInfo. I tested it to make sure processing in OnSetRenderInfo is aborted when a control is changed. Perhaps I should say it worked as of Nov. 2016, since that's when I ran the test.
Share this post
Link to post
Getting errors when using lasso selected regions:
File: C:\Program Files\paint.net\Effects\ContentAwareFill.dll
      Version: 1.3.0.0
      Author: null54
      Copyright: Copyright © 2018 Nicholas Hayes (aka null54)
      Website: https://forums.getpaint.net/index.php?showtopic=112730
      Full error message: PaintDotNet.WorkerThreadException: Worker thread threw an exception ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at ContentAwareFill.ContentAwareFillEffect.OnConfigDialogProgress(Int32 value)
   at ContentAwareFill.Resynthesizer.Synthesize(Int32 pass, Func`1 abortCallback)
   at ContentAwareFill.Resynthesizer.ContentAwareFill(Func`1 abortCallback)
   at ContentAwareFill.ContentAwareFillEffect.OnSetRenderInfo(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs)
   at PaintDotNet.Effects.BackgroundEffectRenderer.ThreadFunction() in D:\src\pdn\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 225
   at PaintDotNet.Effects.BackgroundEffectRenderer.DrainExceptions() in D:\src\pdn\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 418
   at PaintDotNet.Effects.BackgroundEffectRenderer.Abort() in D:\src\pdn\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 374
   at PaintDotNet.Effects.BackgroundEffectRenderer.Start() in D:\src\pdn\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:line 320
   at PaintDotNet.Menus.EffectMenuBase.<>c__DisplayClass42_5.<RunEffectImpl>b__5() in D:\src\pdn\src\PaintDotNet\Menus\EffectMenuBase.cs:line 1032
Share this post
Link to post
I noticed some bug. Click on the image or on the effect UI when you have this message and then click Cancel button.
As a result, we have endless canceling.
Share this post
Link to post
Fixed in 1.3.2.
21 hours ago, xod said:
How could I miss such a good plugin?
With the large number of plugins available on this forum it does not surprise me that some may be overlooked, and this is more of a niche plugin than something like Feather or Clipwarp.
I do not envy @Ego Eram Reputo's job keeping the plugin index up to date. ?
  • Upvote 2
Share this post
Link to post
This is a fantastic plugin. Quick question, is there a way to add a shortcut in the GUI for this plugin so you do not need to go to Effects > Selection each time? Thank you.
Share this post
Link to post
