Timbo128 Posted April 11, 2018 Share Posted April 11, 2018 Hi- Hoping I can get some help/ direction with prepping Paint.net generated vinyl graphics for cutting. We had some simple graphics made and should have specified they be printed to transparent matte vinyl laminating stock. Instead, the print source put them on white and they are too small and detailed to cut out with an Xacto knife. I need some guidance on setting up a cut line path, on a separate layer, for these graphics we're playing with. If more details required, please inform. Appreciate any input- Thanks! Tim Quote Link to comment Share on other sites More sharing options...
Eli Posted April 11, 2018 Share Posted April 11, 2018 Making an outline as aguide can help when cutting those words. 1 1 Quote Link to comment Share on other sites More sharing options...
Timbo128 Posted April 11, 2018 Author Share Posted April 11, 2018 Hmmm... will the final black guide outline show up on the graphic, and what to do about back/ drop shadowing?... do I just put the cutting guide outline on another layer and not flatten?... is there a tutorial here for vinyl cutting setup?... I'm thinking I could use the white illustrated above as a temp layer and throw it out after establishing cut line. Thanks for your patience and help. Quote Link to comment Share on other sites More sharing options...
