MrGreggles Posted April 4, 2018 Share Posted April 4, 2018 I love Paint.NET but frequently need to draw point to point lines. I'm currently needing to go into Gimp to do that (only), which suckus big time. Any chance of this being incorporated into Paint.NET? https://www.useloom.com/share/8dc318e7e6e148398de12fd18f8b84a8 Cheers. ~ Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted April 4, 2018 Share Posted April 4, 2018 As a work-around, you could use TR's SplineMaster. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
MrGreggles Posted April 5, 2018 Author Share Posted April 5, 2018 I'll give this a try. Thank you. Quote Link to comment Share on other sites More sharing options...
MrGreggles Posted April 8, 2018 Author Share Posted April 8, 2018 Unfortunately like Paint.NET, it doesn't save its settings between uses (my only other peeve with Paint.NET) so is impractical since it's used multiple times each session. I didn't look to see if 2+ lines lines are possible due to that. I dearly lament that PAINT.NET doesn't have this simple functionality. I've been putting up with it for years because I like the program but having to use the unfriendly Gimp just for drawing paths is too inconvenient, so the search continues. Anyway, thank for your help. Quote Link to comment Share on other sites More sharing options...
MJW Posted April 8, 2018 Share Posted April 8, 2018 I very recently mentioned the desired functionality on another thread: Quote I'll add that I wish the line/curve tool had a mode allowing lines and curves to be chained end-to-end, so that the last point in one line/curve becomes the first point in the next. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted April 8, 2018 Share Posted April 8, 2018 ShapeMaker will allow you to do point-to-point lines. 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
