how do I make a Water or paint dripping effect?
Hi for a current project I want to make an image of something similar to water (Maple syrup to be precise) dripping on like a vertical pane of glass, as if the viewer's monitor was coated in it. I've been looking around (albeit I'm bad at this) and haven't found anything that covers the whole image with it or has visible drops and streaks or anything the like.
Does anyone know how to do it or a tutorial that shows how to do it? (ideally a text tutorial, I don't like video tutorials)
Thanks to anyone willing to help :)
Similar to this ( https://www.fbcoverlover.com/cover/3295 ) but for full screen along with some streaking and rivulets and the like.  The intended use is for it to serve as a background/frame for videos
Hello @nawavids.  Here is a tutorial that will give you an idea of how to go about doing this:
There are also brushes you can bring into PDN and you can find them here.
