Suggestion: Right click > Secondary Color or Eraser
Basically if you have the paintbrush or the pencil on, then there should be a setting where you can set right click to either Draw the secondary color or Erase.
It'd be like on the Recolor tool how it shows a Target Color or Secondary Color icon on the ribbon(i think that's what it's called?), except it shows Secondary Color and an Eraser icon
Just a quality of life tweak, because it's annoying to switch between eraser and paintbrush repeatedly if I make a mistake :D Hope it gets added!
