toe_head2001 Posted January 23, 2018 Share Posted January 23, 2018 4 minutes ago, Pratyush said: what's return type of this function? If only we had something in CodeLab to inform us... oh, wait, we do! At least 3! - AutoComplete tooltips - Editor tooltips - F12 to lookup on docs.microsoft.com Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 23, 2018 Share Posted January 23, 2018 55 minutes ago, toe_head2001 said: @Pratyush, the Math.Sin() and Math.Cos() trigonometric functions use radians rather than degrees, so don't forget to do conversions if needs be. A little help on this..... Write yourself a couple of helper functions to do the conversions public double DegreeToRadians(double angle) { return (Math.PI / 180) * angle; } private double RadianToDegrees(double angle) { return angle * (180.0 / Math.PI); } You can call these from your code like this... double angle = Math.Cos(DegreeToRadians(45)); Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
BoltBait Posted January 23, 2018 Share Posted January 23, 2018 @Pratyush you've written your plugin in a very strange way. I'm not sure about your looping structure... and basing your calculations on the size of the rectangle sent into the Render function... Anyway, I've written a well behaved version of your plugin. Use it if you like. <snip> It will render your gradient to any angle and it respects the current selection. Plus, it is super fast (that is, the UI is very responsive). It will also repeat the pattern if you pull the nubs [+] in from the edges. Enjoy. 2 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
null54 Posted January 24, 2018 Share Posted January 24, 2018 (edited) 6 hours ago, Pratyush said: what's return type of this function? Both Math.Sin and Math.Cos return a double. Edit: I did not see that @toe_head2001 answered the question on the second page. Edited January 24, 2018 by null54 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Pratyush Posted January 24, 2018 Author Share Posted January 24, 2018 (edited) On 1/24/2018 at 4:32 AM, BoltBait said: Use it if you like. Posterize is not giving desired result. Thanks everyone for suggestion. I will use x^2(3-2x) which gives very good approximation of sin(pi x\2)^2 for the range [0,1] Edited February 4, 2018 by Pratyush Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 24, 2018 Share Posted January 24, 2018 22 hours ago, Pratyush said: Posterize is not giving desired result. I agree, so I rewrote the posterize portion: <snip> I think you're going to like this version. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
BoltBait Posted January 25, 2018 Share Posted January 25, 2018 22 hours ago, Pratyush said: Posterize is not giving desired result. I agree... which is why I just rewrote the Posterize part. Now the colors are correct: // Name: Gradual Stripes // Submenu: Render // Author: BoltBait & Pratyush // Title: Gradual Stripes // Version: 2.0 // Desc: Draws stripes with gradual change in shades // Keywords: Stripes|Grayscale|Lines #region UICode PanSliderControl Amount1 = Pair.Create(-1.0,0.0); // Starting Point ColorWheelControl Amount2 = ColorBgra.FromBgr(0,0,0); // [Black] PanSliderControl Amount3 = Pair.Create(1.0,0.0); // Ending Point ColorWheelControl Amount4 = ColorBgra.FromBgr(255,255,255); // [White] IntSliderControl Amount5=16; // [2,64] Bands #endregion Surface wrk = null; Color[] palette = new Color[64]; protected override void OnDispose(bool disposing) { if (wrk != null) wrk.Dispose(); wrk = null; base.OnDispose(disposing); } Color FindNearestColor(Color color, Color[] palette, int palSize) { int minDistanceSquared = 255 * 255 + 255 * 255 + 255 * 255 + 1; byte bestIndex = 0; for (byte i = 0; i < palSize; i++) { int Rdiff = color.R - palette[i].R; int Gdiff = color.G - palette[i].G; int Bdiff = color.B - palette[i].B; int distanceSquared = Rdiff * Rdiff + Gdiff * Gdiff + Bdiff * Bdiff; if (distanceSquared < minDistanceSquared) { minDistanceSquared = distanceSquared; bestIndex = i; if (minDistanceSquared < 1) break; } } if (bestIndex == 0) return Amount2; if (bestIndex == palSize-1) return Amount4; return palette[bestIndex]; } void PreRender(Surface dst, Surface src) { if (wrk == null) wrk = new Surface(src.Size); int sw = (Amount5 + 1) * 2; Bitmap swatch = new Bitmap(sw,1); using (LinearGradientBrush Brush1 = new LinearGradientBrush(new Point(0,0),new Point(sw-2,0), Amount2, Amount4)) { using (Graphics g = Graphics.FromImage(swatch)) { g.FillRectangle(Brush1,0,0,sw,1); } } for (int i = 0; i < Amount5; i++) { palette[i] = swatch.GetPixel(i*2+1,0); } Rectangle selection = EnvironmentParameters.GetSelection(wrk.Bounds).GetBoundsInt(); int width = selection.Right - selection.Left; int height = selection.Bottom - selection.Top; int x1 = (int)Math.Round(((Amount1.First + 1) / 2) * width) + selection.Left; int y1 = (int)Math.Round(((Amount1.Second + 1) / 2) * height) + selection.Top; int x2 = (int)Math.Round(((Amount3.First + 1) / 2) * width) + selection.Left; int y2 = (int)Math.Round(((Amount3.Second + 1) / 2) * height) + selection.Top; Point p1 = new Point(x1,y1); Point p2 = new Point(x2,y2); if (!p1.Equals(p2)) { using (LinearGradientBrush Brush1 = new LinearGradientBrush(p1,p2, Amount2, Amount4)) { using (Graphics g = new RenderArgs(wrk).Graphics) { g.FillRectangle(Brush1,selection.Left,selection.Top,width,height); } } } } void Render(Surface dst, Surface src, Rectangle rect) { for (int y = rect.Top; y < rect.Bottom; y++) { for (int x = rect.Left; x < rect.Right; x++) { if (IsCancelRequested) return; ColorBgra CurrentPixel = wrk[x,y]; CurrentPixel = FindNearestColor(CurrentPixel, palette, Amount5); dst[x,y] = CurrentPixel; } } } EDIT: I just rewrote it again. Now the stripes are the correct number and size. 1 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
MadJik Posted January 25, 2018 Share Posted January 25, 2018 1 hour ago, BoltBait said: int minDistanceSquared = 255 * 255 + 255 * 255 + 255 * 255 + 1; This makes sense to understand the code, but these calculations are done for each pixels... Can I suggest this change to save some cpu? int minDistanceSquared = 999999; // high value greater than 255 * 255 + 255 * 255 + 255 * 255 + 1; Quote My DeviantArt | My Pictorium | My Plugins | Donate via Paypal Link to comment Share on other sites More sharing options...
MJW Posted January 25, 2018 Share Posted January 25, 2018 Though it's better not to count on it, I suspect the compiler would compute the constant expression. That's a pretty simple optimization. 1 Quote Link to comment Share on other sites More sharing options...
MadJik Posted January 25, 2018 Share Posted January 25, 2018 1 hour ago, MJW said: Though it's better not to count on it, I suspect the compiler would compute the constant expression,. That's a pretty simple optimization. I'm old school dev... Quote My DeviantArt | My Pictorium | My Plugins | Donate via Paypal Link to comment Share on other sites More sharing options...
BoltBait Posted January 25, 2018 Share Posted January 25, 2018 8 hours ago, MJW said: the compiler would compute the constant expression Yes, the compiler is smart enough to precompute the results of the constant expression. Writing it out that way is just easier for us humans to understand what I'm doing. It is easy to verify by using ILSpy to decompile the resulting DLL: Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Pratyush Posted January 25, 2018 Author Share Posted January 25, 2018 How to typecast double to int? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 25, 2018 Share Posted January 25, 2018 10 minutes ago, Pratyush said: How to typecast double to int? Like this: int MyInt = (int)MyDouble; You can see examples of this in the code I posted above. Look at the PreRender function where I'm calling some Math functions. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 25, 2018 Share Posted January 25, 2018 4 hours ago, BoltBait said: Writing it out that way is just easier for us humans to understand what I'm doing. That's what comments are for. int minDistanceSquared = 195076; // i.e. the result of (255 * 255) * 3 + 1; Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
MJW Posted January 26, 2018 Share Posted January 26, 2018 One way to do that sort of thing is to use a constant variable: const int MaxDistSqPlusOne = 3 * 255 * 255 + 1; That way, it will be clearer what's being done when it's assigned: minDistanceSquared = MaxDistSqPlusOne; Since it must evaluate to a single value, if the compiler accepts it, it's guaranteed to be computed in the compilation phase. 1 Quote Link to comment Share on other sites More sharing options...
Pratyush Posted January 26, 2018 Author Share Posted January 26, 2018 I don't understand this error. what is missing? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 26, 2018 Share Posted January 26, 2018 try this: k = (int)(k * n); Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
BoltBait Posted January 26, 2018 Share Posted January 26, 2018 The reason for this is simple. You are trying to store something into a variable defined as an integer. So, you rightfully tried to cast your calculation to integer using "(int)" in front of it. The problem is that when casting, you're casting only the next item to int. So, you're casting k to an integer then multiplying it by n which is a double... the result of this multiplication is a double. And, you can't store a double into an integer variable. The solution, as pointed out by toe_head2001, is to put parens around k * n so that the multiplication happens first resulting in a double and then cast that double to an integer for storing into the variable. You actually did it correctly on line 66. Clear? 2 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Pratyush Posted January 30, 2018 Author Share Posted January 30, 2018 Is there a way I can call blur effect after doing all that render? so that I can soften rough edges. . Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 30, 2018 Share Posted January 30, 2018 8 minutes ago, Pratyush said: Is there a way I can call blur effect after doing all that render? so that I can soften rough edges. . It depends on how your script works. Generally, you can't. Show us your current script, and we'll let you know. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Pratyush Posted January 31, 2018 Author Share Posted January 31, 2018 Hi everyone, Can we do from codelab, that checking one of checkbox will uncheck or disable other UI element? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 31, 2018 Share Posted January 31, 2018 Yes, a checkbox can disable another UI element. Use the UI Designer in CodeLab. On 1/11/2018 at 1:18 AM, BoltBait said: Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
BoltBait Posted January 31, 2018 Share Posted January 31, 2018 4 minutes ago, Pratyush said: Hi everyone, Can we do from codelab, that checking one of checkbox will uncheck or disable other UI element? As long as you are using CodeLab v3.0 (or higher), you can. Read this post for more info on how to do it: https://forums.getpaint.net/topic/880-codelab-v32-for-advanced-users-released-january-17-2018/?do=findComment&comment=541005 EDIT: ...which toe_head2001 has just quoted above this post. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Pratyush Posted January 31, 2018 Author Share Posted January 31, 2018 On 1/25/2018 at 12:03 AM, BoltBait said: I think you're going to like this version. Hi, I just remembered that I didn't thanked you for all that work. In next version I will use that code. Thank you very much. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 31, 2018 Share Posted January 31, 2018 1 minute ago, Pratyush said: Thank you very much. You're welcome. I found it to be an interesting challenge. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
