Metallic Presets for Gradient Mapping
Hi All,
Here is some preset for Gradient Mapping plugin from Pyrochild. These preset can be used to give grayscale images a colored metallic tint with use of luminosity.
Following images are example to what the they map to. The name like Copper, Nichrome, Stannous, Electroplated, chromium, Steel etc are more or less arbitrary or for name only.
dAzEeXr.pngCP8tcfZ.png4TZ4Oan.png63Lmf0c.pngACphTBM.png2ukl3cw.pngS7JlFOS.pngw2a74ab.png
Download
  • Like 4
  • Upvote 2
Thank you @Pratyush for these.  I'm a big fan of Gradients and the electroplated is really cool and not one I've tried before.  Just love the sexy Download button as well :D
1 minute ago, cruthis87 said:
Where do these files go?  Do they appear under the gradient as selectable options?
These are specifically for the Gradient Mapping plugin. You can put the files anywhere you want.
My Gallery  |  My Plugin Pack
Layman's Guide to CodeLab
