Rick Brewster 1,766 Posted December 20, 2017 Author Share Posted December 20, 2017 I'm seeing another handful of bugs in Win7 w/ Dark that I"ll be fixing. There's a seam underneath the menus that goes away when you resize the window (or maximize it) -- I've fixed that. There's also some problems with text headers in the Levels dialog getting clipped, and possibly elsewhere. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
Woodsy 857 Posted December 20, 2017 Share Posted December 20, 2017 I don't know if it pertains but the size in MJW's Paste from Clipboard and the coordinates in Red's Vanishing Point are very temperamental. They weren't like that before. My PDN Gallery Link to post Share on other sites
lynxster4 3,215 Posted December 22, 2017 Share Posted December 22, 2017 This is more of a minor annoyance than a major issue, but some plugin UI's aren't displaying correctly in terms of color. Examples: Color Tint button text is white instead of black, making it difficult to see. Color Flip/Rotate doesn't inherit your chosen Windows color; it is white, along with the button text. There may be more, but I haven't opened every single plugin...that would take some time... 1 My Art Gallery | My Shape Packs | ShapeMaker Mini Tut | Air Bubble Stained Glass Chrome Text with Reflections | Porcelain Text w/ Variegated Coloring | Realistic Knit PatternOpalescent Stained Glass | Frosted Snowman Cookie | Leather Texture | Plastic Text | Silk Embroidery Visit my Personal Website "Never, ever lose your sense of humor - you'll live longer" Link to post Share on other sites
BoltBait 3,276 Posted December 22, 2017 Share Posted December 22, 2017 11 minutes ago, lynxster4 said: This is more of a minor annoyance than a major issue, but some plugin UI's aren't displaying correctly in terms of color. Are those plugins based on IndirectUI or are they custom? Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
toe_head2001 1,834 Posted December 22, 2017 Share Posted December 22, 2017 Yeah, those have custom User Interfaces, which won't work 100% correctly without some tweaks by their authors. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
lynxster4 3,215 Posted December 22, 2017 Share Posted December 22, 2017 31 minutes ago, BoltBait said: Are those plugins based on IndirectUI or are they custom? 27 minutes ago, toe_head2001 said: Yeah, those have custom User Interfaces, which won't work 100% correctly without some tweaks by their authors Well, those are things we will just have to live with when using 'dark theme'. Some of these plugins are old, old...but I still use them. Thank you for the quick reply... My Art Gallery | My Shape Packs | ShapeMaker Mini Tut | Air Bubble Stained Glass Chrome Text with Reflections | Porcelain Text w/ Variegated Coloring | Realistic Knit PatternOpalescent Stained Glass | Frosted Snowman Cookie | Leather Texture | Plastic Text | Silk Embroidery Visit my Personal Website "Never, ever lose your sense of humor - you'll live longer" Link to post Share on other sites
COLOVE Products 0 Posted December 22, 2017 Share Posted December 22, 2017 Hey! Look it, our someedit) If this helps you Issues - Original https://imgur.com/a/0c5vJ Some Edit.. for DarkTheme is better for the eyes... https://imgur.com/a/kzXar Link to post Share on other sites
TrevorOutlaw 300 Posted December 23, 2017 Share Posted December 23, 2017 On the dark theme, some of the plug in icons in the menu are hard to see. Pyrochild's Grid Warp, for example almost disappears into the menu background. I wonder if it's possible for plugin authors to code icons to switch between dark and light themes. Paint.NET Gallery | Remove Foreground Object Tutorial | Dispersion Effect Tutorial Link to post Share on other sites
toe_head2001 1,834 Posted December 23, 2017 Share Posted December 23, 2017 2 hours ago, TrevorOutlaw said: I wonder if it's possible for plugin authors to code icons to switch between dark and light themes. There currently no official way for a plugin to detect which theme is active. I think Rick will eventual add this ability for plugins. The CodeLab editor has a Dark theme also, and it would be cool if it automatically switch to that Dark theme when paint.net's Dark theme is active. That is to say, CodeLab themes could be [Automatic, Light, Dark], once plugin can detect paint.net's theme. The best option right now is to use an icon that works on both Light and Dark themes. (plugins should already be doing this for High Contrast accessibility...) My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
AndrewDavid 732 Posted December 23, 2017 Share Posted December 23, 2017 (edited) Probably no big deal but I thought I would mention it. After upgrading to Fall creators edition - I had to install a new version of Acrobat reader to read PDF files. What I just noticed is the icon in the task bar shows as Paint.Net. I looked at the .exe for Adobe but it does not display a change icon choice. In Explorer the proper Adobe icon is displayed for PDF images as well. Perplexed Edit Figured it out by deleting existing shortcuts - creating new ones - rebooting. Not 100% fixed. Still shows Paint.net icon in start menu and it won't let me unpin. Treated as a WIN10 issue Edited December 23, 2017 by AndrewDavid added solution Link to post Share on other sites
toe_head2001 1,834 Posted December 23, 2017 Share Posted December 23, 2017 1 hour ago, AndrewDavid said: I had to install a new version of Acrobat reader to read PDF files. Had to, eh? There are better choices than Abode Reader when it comes to PDF viewers. Can't Windows 10 already read PDF files without any additional software anyways? My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
AndrewDavid 732 Posted December 23, 2017 Share Posted December 23, 2017 That's true. Edge, IE and Chrome are some examples. Reader as well, but it will be retired in the New Year. I am so used to Adobe I had to install the new version because the old version disappeared. And the new version does work better than the old one. Just call me an old dog. ' Link to post Share on other sites
AndrewDavid 732 Posted December 24, 2017 Share Posted December 24, 2017 @Ego Eram Reputo Thought I would post the issue here instead of the plugin thread for planetoid. It is now failing to retain settings (Alpha=0) in saved files. Nor will it save the 2D format as described in @welshblue's latest tutorial. Win 10 Fall Creators update. 1 Link to post Share on other sites
Eli 1,130 Posted December 24, 2017 Share Posted December 24, 2017 (edited) Thanks for these new version but I can not get used to the new dark theme. I can not find the icons even though they are there. Perhaps Dark Theme is not good for old eyes. I must have a BUG in my eyes. Edited December 24, 2017 by Eli Link to post Share on other sites
Pixey 4,926 Posted December 24, 2017 Share Posted December 24, 2017 4 hours ago, Eli said: Thanks for these new version but I can not get used to the new dark theme. I can not find the icons even though they are there. Perhaps Dark Theme is not good for old eyes. I must have a BUG in my eyes. like @Eli I too can't get used to the Dark Theme - but never mind - we have choices, which is nice I am also having trouble pasting numbers into settings in @MJW's Height Map Texture Shader How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to post Share on other sites
Ego Eram Reputo 2,795 Posted December 24, 2017 Share Posted December 24, 2017 13 hours ago, AndrewDavid said: @Ego Eram Reputo Thought I would post the issue here instead of the plugin thread for planetoid. It is now failing to retain settings (Alpha=0) in saved files. Nor will it save the 2D format as described in @welshblue's latest tutorial. Win 10 Fall Creators update. Thanks for the report AndrewDavid. I'll round up the usual suspects and see if I can extract a confession ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
Rick Brewster 1,766 Posted December 25, 2017 Author Share Posted December 25, 2017 Locking this thread. New beta build incoming ... The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
