Illnab1024 11 Posted May 17, 2006 Report Share Posted May 17, 2006 Just a quirk that I noticed: Here i give the same two files, one in bitmap and one in PNG format. Now i noticed this in IE6's internal PNG viewer, but if one were to take a snapshot of the IE page, one would notice a slight discoloration between the two "same" colors in the two images. e.g., #FF33CC in the BMP might be #FF30CD in the PNG, while in PdN, they are the same (#FF33CC). Here are the 2 images: BMP: PNG: I have not dug too deeply, but in cases where I use html and need png for with its size it is easy to download, I need that the color of the png go with the background or something else. Quote ~~ Link to post Share on other sites
Rick Brewster 1,754 Posted May 17, 2006 Report Share Posted May 17, 2006 Ok but if you load the PNG in Paint.NET, what is the color value? If the color value is correct in Paint.NET, then IE is just rendering it wrong. Heck, it renders the Paint.NET logo with the wrong gamma (it looks darker), so this wouldn't surprise me at all. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
Illnab1024 11 Posted May 17, 2006 Author Report Share Posted May 17, 2006 Well, I'll be! duh... The fight in my brain: "Maybe it's Microsoft!" "It can't be Microsoft, they're perfect!" "But it wouldn't be Paint.NET!" Quote ~~ Link to post Share on other sites
