gondracorn Posted November 22, 2017 Share Posted November 22, 2017 (edited) Hello. I'm trying to make a circle with anti-aliasing and 6 width with the shape. But when I place it, it seems to be just 2 individual circles overlapping each other. I'm using paint.net 14.0.9 Here's an image of what is happening. You'll need to open it and inspect it zoomed in to see the problem. I can't really give an example of what it should look like. All I know is that the outer should be darker, and the inner ring shouldn't exist I've Uploaded an additional document with my PC specs from Paint.net Specs.txt Edited November 22, 2017 by gondracorn Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted November 22, 2017 Share Posted November 22, 2017 Yeah, a double outline. That's odd. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
gondracorn Posted November 22, 2017 Author Share Posted November 22, 2017 (edited) It wasn't doing it before, just today it started. I haven't installed anything, and no viruses seem to be present. Was there an update with paint.net that I wasn't aware of today? Problem started occuring about an hour ago. I just tried restarting, and it didn't solve the issue. Edited November 22, 2017 by gondracorn Quote Link to comment Share on other sites More sharing options...
Eli Posted November 22, 2017 Share Posted November 22, 2017 That is because you have changed the opacity. 1 Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 27, 2017 Share Posted November 27, 2017 Yes this is actually normal if you specify a non-opaque (non-255) alpha value for the outline's color. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
