madog31 Posted November 10, 2017 Share Posted November 10, 2017 Hi all. I'm trying to create greeting cards and I've been having challenges finding an effective and efficient way to create text that is centered both vertically and horizontally. I've tried using plugins that are supposed to do it, but they don't seem to align properly. Once created, does paint.net allow templates to be created and if so how? Thank you. Quote Link to comment Share on other sites More sharing options...
Eli Posted November 10, 2017 Share Posted November 10, 2017 Templates : If you mean creating templates as in Powerpoint or Publisher the answer is NO. Paint.net does not create text or image boxes. What I mean is that you can not just change the image or text by clicking their boxes. Alignment : What alignment pluging are you using? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted November 10, 2017 Share Posted November 10, 2017 If these are physical cards that are going to be printed, I don't recommend using paint.net for this task. By all means use paint.net on the images that may be used on the cards, but everything else should be done in a different program. At least in my opinion. 45 minutes ago, madog31 said: I've tried using plugins that are supposed to do it, but they don't seem to align properly. Please elaborate. Perhaps you're not using the plugins correctly. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
MJW Posted November 10, 2017 Share Posted November 10, 2017 32 minutes ago, toe_head2001 said: If these are physical cards that are going to be printed, I don't recommend using paint.net for this task. I've used Paint.Net for quite a few printed greeting cards. Seems to work fine for me. Quote Link to comment Share on other sites More sharing options...
mottoman Posted November 10, 2017 Share Posted November 10, 2017 1 hour ago, madog31 said: Once created, does paint.net allow templates to be created and if so how? Once you have made and are happy with your text, you can save this "text layer" as a .png and use it again in another card project, by simply importing it as a new layer. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted November 10, 2017 Share Posted November 10, 2017 (edited) 16 minutes ago, MJW said: I've used Paint.Net for quite a few printed greeting cards. Seems to work fine for me. Sure it will work, but there are programs that are much better suited for printing tasks. Makes it easy for the layman. Vector based text... even at 600 dpi, raster text can still have fuzzy borders. Automatic bleed margin configurations. Templates ect. Edited November 10, 2017 by toe_head2001 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
