KittenKatja Posted October 23, 2017 Share Posted October 23, 2017 I am unable to descripe the problem in words, the reason also can't find it in the search... I'm editing some textures in a game, the problem is, i want to change the colour of something see through sticking to another object. There is the base texture and the other texture with that jelly on it. I put both each on a layer and diversed them. Now I'm at a dead end, because the texture is now on a black background and still not able to only edit this little part. (when done what i want, it comes on the base and save it as the original jelly texture) Quote Link to comment Share on other sites More sharing options...
IRON67 Posted October 23, 2017 Share Posted October 23, 2017 (edited) 1 hour ago, KittenKatja said: I am unable to descripe the problem in words, Then use an image instead. Edited October 23, 2017 by IRON67 Quote Link to comment Share on other sites More sharing options...
KittenKatja Posted October 23, 2017 Author Share Posted October 23, 2017 Yes, it's minecraft. I want to recolour the green slime to pink without altering the surface below. (The Piston) Quote Link to comment Share on other sites More sharing options...
IRON67 Posted October 23, 2017 Share Posted October 23, 2017 (edited) Try Conditional Hue/Saturation. My result: Edited October 23, 2017 by IRON67 Quote Link to comment Share on other sites More sharing options...
KittenKatja Posted October 23, 2017 Author Share Posted October 23, 2017 The original looks like slime on normal wood, but the pink one looks like pink slime on part normal and part pink wood. Quote Link to comment Share on other sites More sharing options...
IRON67 Posted October 24, 2017 Share Posted October 24, 2017 So do your own trial. I don't do your work. Do you expect a plugin, that can do anything you want in one single click? There are a lot color editing plugins for PDN. BTW: With such a small image where you can easily edit every single pixel maybe it's better to do this without any plugin. Quote Link to comment Share on other sites More sharing options...
