null54 Posted September 28, 2017 Share Posted September 28, 2017 This is a hack that is probably not relevant to 99% of plugins, but it may be useful for plugins that allow the user to select folders containing brushes or other data files outside of the Paint.NET User Files. I wanted to have a way to disable the selection of external plugin folders in PSFilterPdn when Paint.NET is running in portable mode. To maintain compatibility with 3.5.11 the following code reads the value of the IAppInfoService InstallMode property via Reflection. Spoiler internal static class PdnInstallModeHelper { private static PropertyInfo installTypeProperty; private static bool initializedInstallTypeProperty; private static bool isPortableMode; public static void Initialize(IServiceProvider serviceProvider) { isPortableMode = false; if (serviceProvider != null) { IAppInfoService appInfo = serviceProvider.GetService<IAppInfoService>(); if (appInfo != null) { try { if (!initializedInstallTypeProperty) { initializedInstallTypeProperty = true; installTypeProperty = appInfo.GetType().GetProperty("InstallType"); } if (installTypeProperty != null) { object appInstallMode = installTypeProperty.GetValue(appInfo, null); if (appInstallMode != null) { isPortableMode = string.Equals(appInstallMode.ToString(), "Portable", StringComparison.Ordinal); } } } catch (Exception) { // Ignore any errors, good faith effort only. } } } } public static bool IsPortableMode { get { return isPortableMode; } } } There probably is a better way to detect portable mode when referencing the 3.5.11 DLLs, but if there is I have not found it. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 28, 2017 Share Posted September 28, 2017 Why would you need this information in the first place though? edit: you stated why above Also, you have no error handling code. Your code could easily crash if, for example, the property doesn't exist. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 28, 2017 Share Posted September 28, 2017 I'd still prefer you just compile against the latest binaries. 3.5 is dead. Please, don't encourage its use. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
null54 Posted September 29, 2017 Author Share Posted September 29, 2017 20 hours ago, Rick Brewster said: Also, you have no error handling code. Your code could easily crash if, for example, the property doesn't exist. Added. 20 hours ago, Rick Brewster said: Why would you need this information in the first place though? edit: you stated why above After thinking about it some more, I am not convinced that arbitrarily disabling plugin functionality based on the type of Paint.NET install is a good idea. My original reasoning was that allowing the user to add search directories would not make sense as there is no guarantee that two systems would have the same folders, but the current "portable" installs already have that issue and if a folder does not exist or gets deleted when the effect is executing my code would still have to handle that case (to quote Raymond Chen "You just have to accept that the file system can change"). Another reason was to reduce the number of writes to disk if the Paint.NET User Files is stored on a flash drive. 20 hours ago, Rick Brewster said: I'd still prefer you just compile against the latest binaries. 3.5 is dead. Please, don't encourage its use. The reason I compile against 3.5.x is that I do not want to prevent users on older OSes from using my plugins, and supporting multiple versions is too much work. The DX10 DDS file type only supports 4.0.17 and later. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
