null54 Posted February 21, 2018 Author Share Posted February 21, 2018 5 hours ago, M0lz said: Full answer and a couple of test results on github My reply on GitHub. https://github.com/0xC0000054/pdn-ddsfiletype-plus/issues/2#issuecomment-367324692 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
M0lz Posted February 22, 2018 Share Posted February 22, 2018 Looks good to me. Thank you for the research put into that. Quote Link to comment Share on other sites More sharing options...
null54 Posted February 23, 2018 Author Share Posted February 23, 2018 Added 'Linear' to the non-sRGB format descriptions. Renamed the BC7 Compression Mode Quick and Max values to Fast and Slow. File version updated to 1.7.1.0. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted May 15, 2018 Author Share Posted May 15, 2018 Added BC6H to the BC7 Compression Mode description. Always use multi-threaded compression when saving. Upgraded to the May 11 2018 release of DirectXTex. File version updated to 1.8.0.0. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted June 3, 2018 Author Share Posted June 3, 2018 Upgraded to the May 31 2018 release of DirectXTex, file version updated to 1.8.1.0. 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
TKGP Posted June 4, 2018 Share Posted June 4, 2018 Had to make an account just to say thank you very much, this plugin really saved my bacon. Quote Link to comment Share on other sites More sharing options...
Seerose Posted June 4, 2018 Share Posted June 4, 2018 @null54! Thank you so much for your effort. Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
dirtycopgangsta Posted June 28, 2018 Share Posted June 28, 2018 Hi, Please excuse me if I posted in the wrong thread and should have made a different thread for my question. I have extracted some textures from a Directx11 game, but whatever format I use, even when adding the mipmaps, the texture is rendered extremely bright ingame. I suspect it's because of the format I'm saving as, but I can't figure out what to do. Do you have an idea? Quote Link to comment Share on other sites More sharing options...
null54 Posted June 28, 2018 Author Share Posted June 28, 2018 1 hour ago, dirtycopgangsta said: Do you have an idea? I do not. You should ask your question on a forum for the game you are trying to modify. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted July 9, 2018 Author Share Posted July 9, 2018 Upgraded to the July 3 2018 release of DirectXTex, file version updated to 1.8.2.0. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
cardamom Posted July 24, 2018 Share Posted July 24, 2018 Hi. I put the dlls in paint.net and then repaired the program to make sure it could load plugins. I started the program and then I opened some textures. Saving only allows up to Bc5. I tried running it in administrator and same thing. I tried renaming the files to .dds2 file extension but the program doesn't recognize in or out of administrator mode, so I can't try compressing it. Solution? Quote Link to comment Share on other sites More sharing options...
null54 Posted July 24, 2018 Author Share Posted July 24, 2018 26 minutes ago, cardamom said: Hi. I put the dlls in paint.net and then repaired the program to make sure it could load plugins. I started the program and then I opened some textures. Saving only allows up to Bc5. I tried running it in administrator and same thing. I tried renaming the files to .dds2 file extension but the program doesn't recognize in or out of administrator mode, so I can't try compressing it. It sounds like the plugin is not installed correctly. Do you see the dds2 extension in the open file dialog? 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
cardamom Posted August 2, 2018 Share Posted August 2, 2018 Thank you, I found the location to install as per your advice. It's working now and is giving me permission to open .dd2. Quote Link to comment Share on other sites More sharing options...
null54 Posted August 6, 2018 Author Share Posted August 6, 2018 Upgraded to the August 5 2018 release of DirectXTex, file version updated to 1.8.3.0. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted August 18, 2018 Author Share Posted August 18, 2018 Upgraded to the August 17 2018 release of DirectXTex, file version updated to 1.8.4.0. 1 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Seerose Posted August 19, 2018 Share Posted August 19, 2018 @null54! Thank you so much. Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
null54 Posted October 11, 2018 Author Share Posted October 11, 2018 Reduced memory usage when loading and saving images. Fixed a crash if the save progress callback is null. File version updated to 1.8.5.0. 2 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Seerose Posted October 11, 2018 Share Posted October 11, 2018 @null54! Thank you so much for your effort. Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
null54 Posted November 2, 2018 Author Share Posted November 2, 2018 Upgraded to the October 25 2018 release of DirectXTex, file version updated to 1.8.6.0. 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Seerose Posted November 2, 2018 Share Posted November 2, 2018 @null54! Thank you very much. Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
null54 Posted November 11, 2018 Author Share Posted November 11, 2018 2 hours ago, Someguysnickname said: The paint.net devs stated the intent to integrate this over a year ago, but it has yet to happen. I don't suppose you've heard anything about that in the meantime? I do not have any information about when this plugin will be integrated into Paint.NET. 3 hours ago, Someguysnickname said: Btw, your readme does not mention the need to rename .dds to .dds2. I added the line from the first post in this thread to the readme, and updated the project readme on GitHub. 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted November 18, 2018 Author Share Posted November 18, 2018 Upgraded to the November 16 2018 release of DirectXTex, file version updated to 1.8.7.0. 1 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Seerose Posted November 18, 2018 Share Posted November 18, 2018 @null54! Thank you very much for your effort. Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
Asken Posted November 23, 2018 Share Posted November 23, 2018 Hey, I can't get the paint.net to show all the layers in the dds2-file I'm opening. Am I missing something? Quote Link to comment Share on other sites More sharing options...
null54 Posted November 23, 2018 Author Share Posted November 23, 2018 17 minutes ago, Asken said: Hey, I can't get the paint.net to show all the layers in the dds2-file I'm opening. Am I missing something? Editing DDS Files with multiple images (such as cube maps) is not currently supported. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
