Changing colours in paint.net (Help!)
Hello @TruePaintNetFan.  Is this what you are looking for?
I used the Lasso select around the bandana, made a new layer and, keeping the selection active, filled with white.
Flatten the layers and save to .png.
On 7/25/2017 at 4:34 PM, welshblue said:
Another option to Pixey's is to Duplicate the original layer >>> go to Adjustments >>> Invert Colours.  This will turn the stripe and neckerchief white ( turning the symbols black)
You'll then have to get rid of the rest of the image though.  Use the eraser and this tutorial will help https://www.isimonbrown.co.uk/cutting-out-images/
Don't forget to add the brush/ line tool onto a New Layer and not to leave gaps in any joins
I understand how to do those but it just looks really fake if i paint it like that
i want it to be white but not look completely fake
Then you need to learn how to paint shadows and highlights, or, use a pattern instead of plain white.
Here is a tutorial which I used to first learn to paint fabric ;).
The recoloring tool is what you need. It respects the shading of the original colors as you recolor.
REF: https://www.getpaint.net/doc/latest/RecolorTool.html
