dirty dan Posted June 27, 2017 Share Posted June 27, 2017 You know how a lot of ghetto memes like the one below feature extremely distorted, noisy graphics? I'm trying to reproduce that. Suggestions? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted June 27, 2017 Share Posted June 27, 2017 Try this: - Open image (It helps if the image is a jpg format.) - Effects > Photo > Sharpen (Amount 20) Click OK. - Ctrl+F (Repeat until it looks like the photo above.) 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
AndrewDavid Posted June 27, 2017 Share Posted June 27, 2017 (edited) Hi @dirty dan Welcome to the forum Here's my suggestion Take your original photo. Duplicate it three times Bottom layer additive Middle layer additive Run Artistic/Color sketch on top layer Duplicate that layer three times Top - Overlay 2nd - Color dodge 3rd - Difference 4th Normal Here's what you get Move your original image from second last position to 2nd position (Multiply layer) and you get better colorization Edited April 14, 2018 by AndrewDavid added last step - changed attachment to link 3 Quote Link to comment Share on other sites More sharing options...
Red ochre Posted June 27, 2017 Share Posted June 27, 2017 Quote Try this: - Open image (It helps if the image is a jpg format.) - Effects > Photo > Sharpen (Amount 20) Click OK. - Ctrl+F (Repeat until it looks like the photo above.) Try my Overblur for a more extreme way (it too can be used repeatedly producing concentric 'halo' type effects). PolyGlitch may also be useful. 1 Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
