Oil Painting Questions
I've never used oil paint.
I really want to but I'm super concerned about health impact.
The only place I have to paint is where I sleep and I'm concerned about the fumes etc?
How bad is this and how can I get around it?
Hi Twist,
This forum is for 'paint.net' computer software not 'real' paint.
However, I have painted in oils since I was a child, often in the same room as where I sleep.
I'm still alive!
If you must paint where you sleep. Do open up the windows and use minimal solvent (turpentine or mineral spirit).
Good quality pigments are toxic too - don't eat them, or allow children or animals to either.
Washing brushes uses the most solvent - do this outside.
There are many forums on the net that do discuss oil paint (with dubious advice). Manufactures (eg Windsor & Newton) and online retailers
(eg. Jackson's) have good information and advice about their products.
Hope that helps - good luck and enjoy!:)
  • Upvote 3
13 hours ago, Red ochre said:
嗨,
这个论坛是为“paint.net”计算机软件不是“真实”的油漆
然而,我已经画油自从我还是个孩子的时候,经常在我睡觉的房间一样。
我还活着!
如果你必须油漆你睡觉的地方。 打开窗户,用最小的溶剂(松节油或石油溶剂油)。
优质颜料是有毒的,不吃他们,或让儿童或动物。
清洗刷子使用以外的大多数溶剂——这样做。
有许多网上论坛,讨论油漆(可疑的建议)。 生产(如温莎&牛顿)和在线零售商
(如。 杰克逊)对他们的产品有很好的信息和建议。
希望帮助,祝你好运,享受!:)
Thank you for you sharing.
