loggie Posted August 4, 2008 Share Posted August 4, 2008 First off, hello to everyone. You people sure know your stuff. I am at my wit's end. I am trying to blurr the edges of a photograph and I am using Paint.net to try to do this. I am definiately not knowledgeable on the computor. I am making my daughter's wedding invitation and I am trying to come up with a picture of them that is suitable. I would like to make the picture into a black and white which I have done already, but blurring the edges is quite a different thing. I have really been trying to find out how to do this, but I'm really having trouble. I have been to forum after forum, tutorial after tutorial. I do know that it has something to do with layers, masking, gradients, transparency mode, or feathering...keywords i guess but can't seem to make any sense, I would be very grateful for any help, if I am in the wrong place to ask this question, I'm sorry. Maybe someone could kindly direct me in another direction. Peace and Happiness to you, best regards....Loggie (I would also really like to know how to make a monogram, as well...much later) Quote Link to comment Share on other sites More sharing options...
david.atwell Posted August 4, 2008 Share Posted August 4, 2008 Well, it's not nearly as difficult as it sounds. Don't worry. :-) If you want the edges blurred but the image still square, try this tutorial: viewtopic.php?t=2298 If you want the image to be cropped into an oval with faded edges, use the "vignette" feature of this plugin pack: viewtopic.php?f=16&t=23885 Hope this helps! Let me know if it doesn't. Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
Crimson Posted August 4, 2008 Share Posted August 4, 2008 KrisVDM has written a plugin that does (sort of) what d.a suggested as a tutorial. It's called Fade Edge. Quote Create A Professional-Looking Product Advertisment Mockup flickr | Deviant Art Link to comment Share on other sites More sharing options...
loggie Posted August 4, 2008 Author Share Posted August 4, 2008 Hi David, Thanks so much I think I downloaded both plugins, if I'm not mistaken you save them to the effects folder? I can see in Paint.net where the first plugin in is, but I can't see where the "vignette" plugin in is. I think I will go that route, the blurred oval. Can you tell me where to find it? Thanks Quote Link to comment Share on other sites More sharing options...
Crimson Posted August 4, 2008 Share Posted August 4, 2008 Vignette isn't a plugin, it comes with Paint.NET. It should be under Effects > Photo. Quote Create A Professional-Looking Product Advertisment Mockup flickr | Deviant Art Link to comment Share on other sites More sharing options...
BoltBait Posted August 4, 2008 Share Posted August 4, 2008 Vignette isn't a plugin, it comes with Paint.NET. It should be under Effects > Photo. Hmmm... not according to the help file: http://www.getpaint.net/doc/latest/en/E ... oMenu.html Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
loggie Posted August 4, 2008 Author Share Posted August 4, 2008 I checked the effects and then photo, vignette does not show up at all. Quote Link to comment Share on other sites More sharing options...
Saabo Posted August 4, 2008 Share Posted August 4, 2008 It is a plugin because i never had it and i installed a few plugin packs and there it was .. Quote My Gallery Link to comment Share on other sites More sharing options...
loggie Posted August 4, 2008 Author Share Posted August 4, 2008 I have downloaded the plugin, but cannot find it under effects or anywhere else??? Quote Link to comment Share on other sites More sharing options...
