Fill from clipboard to enhance sword blade
Alright, after trying to use the Fill From Clipboard function, I've come to the conclusion that this plugin is either useless or I'm using it wrong. Since it's most likely the latter, could someone explain to me how you center the pasted image into the selection? I'm trying to use the Fill function to add an electrical effect onto another object and while I've got the selection, transparency, etc, down right, I just can't center the effect into the selection correctly.
It pastes outside the selected area, so it's invisible until I use the slider to adjust it's position, but even using the slider, I just get a part of the image, usually the corner or upper half of it. The sliders stop at -2 or 2 and that's simply not enough.
What exactly am I messing up here?
Edited by Calciborite
Unnecessary emoji
How big is the image you are trying to paste?
How big is your canvas that you are trying to paste to?
and - if you are pasting into a selection box - How big is the selection box?
And yes I see the sliders have a -2 to +2 but that is just relative from the top left corner of the canvas
If you want to reduce the size of image of you are trying to paste - try the tiling option
Posting an image will get better advice
@AndrewDavid
Alrighty then. Please bear with me, as I am the noobiest of noobs with paint.net. The image is 1600 pixels wide and 235 high.
Pardon the absolutely godawful pictures, they're something I threw up right quick as an example, nothing more. They match the general size and appearance of the actual image I worked on, though. :P
First is the sword in its unaltered state. Second is the sword with the effect added to it via transparent layer. Third is a screenshot showing the effect + sword and the Fill From Clipboard slider. Fourth is the actual effect I used, some stock lightning effect I found somewhere a while ago (I had to re-save it as a crappy jpeg to not break the upload limit, sorry). The white center of the effect is what I'm trying to center onto the selection. Said selection is the blade of the sword only (on layer 2 with some transparency), selected with the magic wand tool.
As I hope I've been able to show, you can see how the lightning effect refuses to be centered onto the selection and how you can only ever see the uppermost half/corner of it, since it pastes way out of focus for some reason my nooby self can't discern.
blade_default.thumb.png.899ae1ab89494dd358ff5984d79b6a8f.pngblade_example.thumb.png.8ff0c14ee64167d137eaabd6e1444239.pngblade_example2.thumb.png.7130178f06e00c760eb1f43ccb1aed43.pngLightning.thumb.jpg.fa429353aa327138aa08e5bbdcd4b1f9.jpg
@Eli
Thank you for the suggestion, but that solution sacrifices image quality and doesn't actually produce the visual result I'm looking for.
I suppose chopping the effect image into chunks and basically using them like puzzle pieces might work, but while that would preserve image quality, it'd also complicate the process and I had hoped to avoid precisely that.
I'd really just like it if the function simply pasted the image into the approximate center of the selection instead of doing so practically offscreen (why does it do that, anyway? I literally cannot see any reason why anyone would want that to happen, though I assume there must be one) or at least allowed the sliders to go further than -2 / 2.
Guess we can't always get what we want. Still, I appreciate the advice.
@Calciborite I better understand your dilemma. Fitting a large image into a small area never seems to turn out well.
There is another plugin I use  PasteWarp+
Because your sword blade is only 11 pixels high - have you tried just selecting 11 pixels from your lightning image?
Your sword image is 146 high - so try and select 146 pixels of the lightning effect and run pastewarp# to get this effect.
https://picload.org/thumbnail/rigcrala/sword.jpg
The effect is centered on the blade by just selecting the center of the lightning (146 Pixels).
The best you might do is using zoom to reduce the size of the lightning to the width of the blade but again you would loose that quality.
Here's another way of creating a blade for your sword that you might find interesting.
https://forums.getpaint.net/index.php?/topic/14081-sword-beyond-beginners-level-image-heavy/&
Hope this helps you
  • Upvote 2
@AndrewDavid
Thank you. I think this might be what I need, though the automatic "warp to fit the selection" function is a bit of an issue; even with distortion set to zero there's some twisting going on if the image is larger than the selection area. Guess I'll have to fiddle a bit with the settings and see if I can reduce it further... Or just stop being a lazyass and start cropping, I guess? Heh.
Anyway, thanks again for your help.
I've split this conversation out of BoltBait's plugin pack thread.
I can suggest another method to paste the clipboard into selections, though it isn't pretty -- which is to say, it seems a bit overly complex, not that the image is bad.
Use my Texture Shader plugin. Set the Image to one of the clipboard selections, such as Clipboard (Tiled). Then -- and this is key -- set the Texture Height Scale to 0.0, the Ambient Light Color to White, and the Directional Light Color to Black. You can then move, scale, and rotate the clipboard image, and use the antialiasing. The range of the Offset control should allow the clipboard image to be moved through the entire range of the selection.
  • Upvote 2
