Need help moving to Visual Studio
Hello,
I've been following the CodeLab tutorials, and they are awesome! I'm currently at the 'Moving beyond CodeLab to Visual Studio' tutorial, but I'm currently stuck at generating the DLL file. Basically, I am able to build the program without an errors, but when I check my /bin/debug/ folder, there's no DLL file that is generated.
This is the source code that I get when I check the 'View Source' box in CodeLab:
// Compiler options:  /unsafe /optimize /res:"C:\Users\william.huang\Documents\Paint.NET Plugins\Tutorial\ColorBalanceOld.png","MyScriptEffect.ColorBalanceOld.png"  /debug- /target:library /out:"C:\Users\william.huang\Desktop\MyScript.dll"
using System;
using System.IO;
using System.Linq;
using System.Drawing;
using System.Threading;
using System.Reflection;
using System.Drawing.Text;
using System.Windows.Forms;
using System.IO.Compression;
using System.Drawing.Drawing2D;
using System.Collections.Generic;
using System.Text.RegularExpressions;
using System.Runtime.InteropServices;
using Registry = Microsoft.Win32.Registry;
using RegistryKey = Microsoft.Win32.RegistryKey;
using PaintDotNet;
using PaintDotNet.Effects;
using PaintDotNet.AppModel;
using PaintDotNet.IndirectUI;
using PaintDotNet.Collections;
using PaintDotNet.PropertySystem;
using IntSliderControl = System.Int32;
using CheckboxControl = System.Boolean;
using ColorWheelControl = PaintDotNet.ColorBgra;
using AngleControl = System.Double;
using PanSliderControl = PaintDotNet.Pair<double,double>;
using TextboxControl = System.String;
using DoubleSliderControl = System.Double;
using ListBoxControl = System.Byte;
using RadioButtonControl = System.Byte;
using ReseedButtonControl = System.Byte;
using MultiLineTextboxControl = System.String;
using RollControl = System.Tuple<double, double, double>;
[assembly: AssemblyTitle("MyScript Plugin for Paint.NET")]
[assembly: AssemblyDescription("MyScript selected pixels")]
[assembly: AssemblyConfiguration("myscript")]
[assembly: AssemblyCompany("William")]
[assembly: AssemblyProduct("MyScript")]
[assembly: AssemblyCopyright("Copyright © William")]
[assembly: AssemblyTrademark("")]
[assembly: AssemblyCulture("")]
[assembly: ComVisible(false)]
[assembly: AssemblyVersion("1.0.*")]
namespace MyScriptEffect
    public class PluginSupportInfo : IPluginSupportInfo
        public string Author
            get
                return ((AssemblyCopyrightAttribute)base.GetType().Assembly.GetCustomAttributes(typeof(AssemblyCopyrightAttribute), false)[0]).Copyright;
        public string Copyright
            get
                return ((AssemblyDescriptionAttribute)base.GetType().Assembly.GetCustomAttributes(typeof(AssemblyDescriptionAttribute), false)[0]).Description;
        public string DisplayName
            get
                return ((AssemblyProductAttribute)base.GetType().Assembly.GetCustomAttributes(typeof(AssemblyProductAttribute), false)[0]).Product;
        public Version Version
            get
                return base.GetType().Assembly.GetName().Version;
        public Uri WebsiteUri
            get
                return new Uri("http://www.getpaint.net/redirect/plugins.html");
    [PluginSupportInfo(typeof(PluginSupportInfo), DisplayName = "My effect")]
    public class MyScriptEffectPlugin : PropertyBasedEffect
        public static string StaticName
            get
                return "My effect";
        public static Image StaticIcon
            get
                return new Bitmap(typeof(MyScriptEffectPlugin), "ColorBalanceOld.png");
        public static string SubmenuName
            get
                return SubmenuNames.Artistic;
        public MyScriptEffectPlugin()
            : base(StaticName, StaticIcon, SubmenuName, EffectFlags.Configurable)
        private void OnWindowHelpButtonClicked(IWin32Window owner, string helpContent)
            if (helpContent.ToLower().StartsWith("http://") || helpContent.ToLower().StartsWith("https://"))
                PaintDotNet.ServiceProviderExtensions.GetService<IShellService>(Services).LaunchUrl(null, helpContent);
        public enum PropertyNames
            Amount1,
            Amount2,
            Amount3
        protected override PropertyCollection OnCreatePropertyCollection()
            List<Property> props = new List<Property>();
            props.Add(new Int32Property(PropertyNames.Amount1, 0,-100,100));
            props.Add(new Int32Property(PropertyNames.Amount2, 0,-100,100));
            props.Add(new Int32Property(PropertyNames.Amount3, 0,-100,100));
            return new PropertyCollection(props);
        protected override ControlInfo OnCreateConfigUI(PropertyCollection props)
            ControlInfo configUI = CreateDefaultConfigUI(props);
            configUI.SetPropertyControlValue(PropertyNames.Amount1, ControlInfoPropertyNames.DisplayName, "Cyan - Red");
            configUI.SetPropertyControlValue(PropertyNames.Amount2, ControlInfoPropertyNames.DisplayName, "Magenta - Green");
            configUI.SetPropertyControlValue(PropertyNames.Amount3, ControlInfoPropertyNames.DisplayName, "Yellow - Blue");
            return configUI;
        protected override void OnSetRenderInfo(PropertyBasedEffectConfigToken newToken, RenderArgs dstArgs, RenderArgs srcArgs)
            Amount1 = newToken.GetProperty<Int32Property>(PropertyNames.Amount1).Value;
            Amount2 = newToken.GetProperty<Int32Property>(PropertyNames.Amount2).Value;
            Amount3 = newToken.GetProperty<Int32Property>(PropertyNames.Amount3).Value;
            base.OnSetRenderInfo(newToken, dstArgs, srcArgs);
        protected override void OnCustomizeConfigUIWindowProperties(PropertyCollection props)
            // Add help button to effect UI
            props[ControlInfoPropertyNames.WindowHelpContentType].Value = WindowHelpContentType.CustomViaCallback;
            props[ControlInfoPropertyNames.WindowHelpContent].Value = "http://www.getpaint.net/redirect/plugins.html";
            base.OnCustomizeConfigUIWindowProperties(props);
        protected override unsafe void OnRender(Rectangle[] rois, int startIndex, int length)
            if (length == 0) return;
            for (int i = startIndex; i < startIndex + length; ++i)
                Render(DstArgs.Surface,SrcArgs.Surface,rois[i]);
        #region User Entered Code
        #region UICode
        int Amount1=0;   //[-100,100]Cyan - Red
        int Amount2=0;   //[-100,100]Magenta - Green
        int Amount3=0;   //[-100,100]Yellow - Blue
        #endregion
        private byte Clamp2Byte(int iValue)
            if (iValue<0) return 0;
            if (iValue>255) return 255;
            return (byte)iValue;
            ColorBgra CurrentPixel;
            int R, G, B;
                    CurrentPixel = src[x,y];
                    R = (int)CurrentPixel.R;
                    G = (int)CurrentPixel.G;
                    B = (int)CurrentPixel.B;
                    // Cyan - Red adjustment
                    R = R + Amount1;
                    G = G - (Amount1 / 2);
                    B = B - (Amount1 / 2);
                    // Magenta - Green adjustment
                    G = G + Amount2;
                    R = R - (Amount2 / 2);
                    B = B - (Amount2 / 2);
                    // Yellow - Blue adjustment
                    B = B + Amount3;
                    R = R - (Amount3 / 2);
                    G = G - (Amount3 / 2);
                    // Reassemble the color from R, G, and B
                    CurrentPixel = ColorBgra.FromBgra(Clamp2Byte(B),Clamp2Byte(G),Clamp2Byte(R),CurrentPixel.A);
                    dst[x,y] = CurrentPixel;
        #endregion
And I am using Visual Studio 2017.
