danel Posted April 26, 2017 Share Posted April 26, 2017 Hello, I love Paint.net, but there is an annoying bug. I attached a picture to show what is my problem. As you can see, I have a black coloured Background layer and above that 3 other layers: one with a white circle another with some red text white circle and red text on the same layer. On the left side, I used the Select tool on the red text and drag above the white circle. Different layers, no problem. But if I use Select on the red text, which is on the same layer as the white circle, and drag above the circle, it's override the transparent background color with the Background layer color. The result is an ugly, black rectangle around the text. How can I solve this problem? Thanks for all answers. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted April 26, 2017 Share Posted April 26, 2017 That's not a bug, that how it should work. 21 minutes ago, danel said: it's override the transparent background color with the Background layer color. No, it's not. It's overwriting part of the White circle with Transparency, and thus the Black background is showing through. 2 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
BoltBait Posted April 26, 2017 Share Posted April 26, 2017 You should have created a new blank layer on top of everything else and pasted your text on to that layer. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
danel Posted April 26, 2017 Author Share Posted April 26, 2017 Oh, thanks, now I see the difference between these methods. So, should I make a new layer for every elements which can cover (at least partly) anothers? I remember that in MS Paint there is a Transparent Selection option, which can be so useful. I hope, it will implement to Paint.net also. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted April 27, 2017 Share Posted April 27, 2017 30 minutes ago, danel said: So, should I make a new layer for every elements which can cover (at least partly) anothers? Yes. This is a very good practice, especially where text is involved. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
