brys Posted March 11, 2017 Share Posted March 11, 2017 I noticed each tool you select is used differently when you right click or left click, like with different colors, which is pretty standard. This never bothered me before but I'm trying different apps for stylus drawing on a surface 3 pro tablet and paint.net actually looks promising, but I would really like being able to use one of the stylus buttons as a shortcut for the eraser for example. Turns out I can set one to be the right click, so if I could set the left clic to the pen and the right clic to the eraser I'd have solved my predicament. If you see a different way to accomplish something similar too, I'd be interested. Thanks for reading Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted March 11, 2017 Share Posted March 11, 2017 Hey there brys - welcome to the forum Try setting the Primary color to your drawing color, and the Secondary color to fully transparent (tip: expand the Colors Window). With the Pencil tool active you now have left-click for drawing and right-click for erasing. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Rick Brewster Posted March 13, 2017 Share Posted March 13, 2017 Unfortunately that won't work well unless you're also switching between Normal and Overwrite blending modes 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
