claudekennilol Posted March 2, 2017 Share Posted March 2, 2017 (edited) I'm copying some images in from a pdf so I can show the image without the surrounding content. When I paste it into pdn, the transparency is showing up as black making me edit to get the picture as desired. Are there any plugins that can make this not so tedious? (plugins that will handle the alpha channel on the pasted image). Or at least a way to change the default color to white instead of black for when it decodes (or whatever it's actually doing) the alpha channel? edit: After further research, it might be that Adobe Reader DC might be putting it into the clipboard that way. I'll have to try a different tool and see if I get the same results. Edited March 2, 2017 by claudekennilol Quote Link to comment Share on other sites More sharing options...
IRON67 Posted March 2, 2017 Share Posted March 2, 2017 (edited) PDN handles very well the alpha channel of a copied image normally. The problem may be your PDF file. The plugins Color to Alpha or Color Range may help. Edited March 2, 2017 by IRON67 1 Quote Link to comment Share on other sites More sharing options...
BoltBait Posted March 2, 2017 Share Posted March 2, 2017 If you have my plug and pack installed, try affects Fill from clipboard. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
