Rage Quan Posted August 1, 2008 Share Posted August 1, 2008 is there a way to put a texture in the palet? ie a metal or wood texture? Quote Link to comment Share on other sites More sharing options...
Curmudgeon Posted August 1, 2008 Share Posted August 1, 2008 Not in the color palette if that's what you mean. You can open the texture and adjust it in Paint.NET quite easily though. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted August 1, 2008 Share Posted August 1, 2008 Try this plugin: viewtopic.php?f=16&t=1577 You keep your textures in separate files. Then, use the plugin to fill a selected area with them. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Curmudgeon Posted August 1, 2008 Share Posted August 1, 2008 Try this plugin: viewtopic.php?f=16&t=1577 That works great for tiling the texture over and over in a selection...but it doesn't like Targa files (it crashes every time I've tried using it with a .tga), so if your texture is a .tga then convert it first to a .png Quote Link to comment Share on other sites More sharing options...
